Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Dec 2010, 17:21   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Asetek launches compact liquid coolers
http://www.bit-tech.net/news/hardwar...quid-coolers/1
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 1st Dec 2010, 17:38   #2
Lord-Vale3
His Tremendousness
Lord-Vale3's Avatar
Lord-Vale3 has yet to learn the way of the DremelLord-Vale3 has yet to learn the way of the Dremel
Its a tick box thing.
Throw in one of these and an OEM can charge another $500 because all of a sudden its a 'premium watercooled pwnage rig'
Lord-Vale3 is offline   Reply With Quote
Old 1st Dec 2010, 18:07   #3
DwarfKiller
Multimodder
DwarfKiller's Avatar
DwarfKiller has yet to learn the way of the Dremel
"Do you think that factor-sealed systems"... factory-sealed maybe?
Being 92mm seems odd to me, don't know what to think of it at the moment. More details please?
__________________
i7 930 @3.8 + Titan Fenrir | Asus P6T SE | HD5870 PCS+ | Corsair XMS3 Classic DDR3 @1600 | CM690-II Adv. | 750W Seasonic-X |
DwarfKiller is offline   Reply With Quote
Old 1st Dec 2010, 18:17   #4
Lord-Vale3
His Tremendousness
Lord-Vale3's Avatar
They explained why its 92mm - so OEMs can fit it on smaller fan mounts
Old 1st Dec 2010, 18:40   #5
Jasio
Made in Canada
Jasio has yet to learn the way of the DremelJasio has yet to learn the way of the DremelJasio has yet to learn the way of the Dremel
That's a very decent looking Corsair... I mean Asetek ... I mean Corsair... I mean Cortek...
__________________
[[Asus Z97 Maximus Hero VII | Intel Core i7 4790k @ 4.4 Ghz | Corsair H70 | 16GB DDR3-1600 G.Skill | EVGA 980 Ti Superclocked+ 6GB | Corsair AX750 PSU | 1 x Samsung 850 Pro + Crucial C300 128GB SSD + 2 x Samsung F1 1TB | Silverstone Fortress FT02B]]
Jasio is offline   Reply With Quote
Old 1st Dec 2010, 20:02   #6
Woodspoon
Supermodder
Woodspoon's Avatar
Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.
Agreed
Most of these factory made setups are pretty crap, a good air cooler surpasses most of these style things let alone a good custom wc setup.
Woodspoon is offline   Reply With Quote
Old 1st Dec 2010, 21:13   #7
Lazy_Amp
Entry AMD Engineer
Lazy_Amp has yet to learn the way of the Dremel
When I heard 'Dual Fan', I thought it referred to a dual fan radiator, which I thought would be quite interesting for some sort High Performance slim/small box. But no, it's just going to be boring Push-Pull.
Lazy_Amp is offline   Reply With Quote
Old 1st Dec 2010, 22:01   #8
DBA
I do my modding with a spoon
DBA's Avatar
DBA has yet to learn the way of the Dremel
As far as I understand, they will build a dual fan radiator version (i.e. not a push pull) I remember seeing a picture of it on another site, can't seem to remember where though.
DBA is offline   Reply With Quote
Old 1st Dec 2010, 23:06   #9
Lazy_Amp
Entry AMD Engineer
http://www.asetek.com/products/oem-s...cts/565lx.html
Ah... you're absolutely right... might be useful then.
They even have a workstation model: http://www.asetek.com/products/oem-s...cts/585lx.html
Old 1st Dec 2010, 23:39   #10
cgthomas
Cpt. Handsome
cgthomas's Avatar
cgthomas has yet to learn the way of the Dremel
This means we will see more small-form-factor performance pc's with closed loop water cooling (since most of today's desktop pc's come with 90mm fans)
__________________
Iím an AquaTuning product tester - I am........ honestly
cgthomas is offline   Reply With Quote
Old 2nd Dec 2010, 02:04   #11
ninong
What's a Dremel?
ninong has yet to learn the way of the Dremel
will the 2x92mm rad fit on the tj07 rear exhaust slots? for those who are too lazy to watercool their tj07s
ninong is offline   Reply With Quote
Old 2nd Dec 2010, 11:50   #12
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Corsair buys their coolers from Asetek and only slap a sticker on it. Asetek is the original manufacturer for all of these.
With that said, I still prefer the 120mm-option H50 from Corsair.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
