#1 |
I don't use Dremel.
Makeover for rental apartment
Hi!
I rented a renovated 1920's apartment with my girlfriend. I like the house but new materials used are dull and too clean. I have somewhat limited budget but I wan't to share my ideas how to furnish a home. Size of the apartment is a bit below 70m2. Things we need there are obviously somewhere to sleep and eat. Entertainment area for watching movies and a dedicated computer desk. I have some audio requirements for the computer area as I compose electronic music. Plan for reference: ![]() Empty apartment: ![]() This was the first plan for the living room. It changed a lot after I got more precise dimensions of the aparment. ![]() This second plan is a lot closer to what's about to be built. It has a steel cage to separate movie spot from rest of the living room. I'll build a plywood wall where tv will be attached. ![]() -----------building starts---------- ![]() ![]() ![]() ![]() ![]() ![]() ![]() Plywood wall is about 180cm wide and 110cm high. Tv is a 52" Sony v5500 and speakers will be moved to my music making spot. Definitely not to be left on floor More photos tomorrow, I have tons of them.
__________________
http://www.flickr.com/photos/drakmin/ Last edited by drakmin; 17th Dec 2010 at 16:25. |
#2 |
Useful
Love it - more pics needed ;-)
__________________
i7 920 : 24Gb Corsair RAM : GA-X58A-UD3R: XFX 5770 : X-25M 80Gb : 2 x Dell 24" Canon EOS 7D : 17-50mm f2.8 Tamron : 50mm f/1.8 : 70-200mm f/2.8 IS L : 430EX II's Nexxo: "Understand more, judge less."
#3 |
I don't use Dremel.
Mighty tools:
![]() ![]() First sketch of entry. I think metal grid could be used to hang clothes. ![]() About 30 meters of wood to start with: ![]() First "shoe bench":
__________________
#4 |
Can't mod my way out of a paper bag
House modding, gotta love it!
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#5 |
I don't use Dremel.
Thank you!
![]() ![]() I ran out of wood once and had to get more using bus since I don't own a car First set of wood was transported using friends car.Some space for jackets: ![]() At this point I got an idea for shoe shelf and here's the result: ![]() ![]() ![]() Still missing the jacket holder though. I think I'll leave the green neons for "party use" and normally a motion detector will light up warm white spots.
__________________
http://www.flickr.com/photos/drakmin/ Last edited by drakmin; 17th Dec 2010 at 16:17. |
#6 |
Do you even mod, bro?
Err, I think I speak for everyone when I say that is AWESOME!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#7 |
I like wood ಠ_ಠ
looks tits
are you going to paint that bare wood green like in the model? Black would look good too since you have the green light.
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#8 |
horrible horrible horrible
Don't get me wrong I think that what you've done is pretty awesome - but it looks to me like I would feel a bit enclosed and claustrophobic as I walked through the front door.
If the beams weren't above your head and only going up the walls it would be less so. The first thing I would want to experience as I walked through the front door of my home is a feeling of space, whereas what you've done would make me feel the opposite.
__________________
I'm not even supposed to be here today |
#9 |
I don't use Dremel.
I see your point Hyder! The hallway is 180cm wide and aroun 5 meters long so it was o must to divide it in order not to have a "pipe". Also the hallway was so spacious and gloomy I thought it might stand some strong modifications.
It's hard to capture the feel of space with camera even though I consider myself okay photographer. Now when I look the photos after your comments and go experiencing the hallway with my eyes they tell a bit different story. Reality looks better in this case! I'll try to get better photos maybe with a scale human ;D Also I'll try taking the photos in daylight (those are taken at night) which might help with the photos. Thanks for all comments so far! The Beast: Cage in living room is 50x50mm steel, that might get painted. Hallway cage will be left wooden to add some warmth in opposite to the metal grids.
__________________
http://www.flickr.com/photos/drakmin/ |
#10 |
Kid that won't just go away!
holy crap that looks amazing, what software are you using to do that? I've been collecting images like that for awhile now and would love to learn, Maya 3D? i'm guessing!?
and your flat looks freaking amazing!
__________________
There are two rules for success: 1. Never tell everything you know. |
#11 |
Supermodder
Sweet work dude, but I've gotta say it, you've got way to many shoes for a bloke
#12 |
I like wood ಠ_ಠ
Durr, I see it isn't colored in the model
You're right it does add some balance to the room
__________________
#13 |
I don't use Dremel.
3dstudio + mental ray for rendering
__________________
#14 |
I don't use Dremel.
More photos. Next to be built is the computer desk so don't look at it yet ;D
__________________
http://www.flickr.com/photos/drakmin/ Last edited by drakmin; 17th Dec 2010 at 16:19. |
#15 |
There be Cows.
you should check out the Av forums for ideas.
Here's a nice example: ![]() http://www.avforums.com/forums/membe...le-effort.html
__________________
11/12/2011: CPC 3 - Aria 1 19/02/2012: CPC 3 - Aria 0 すべてのあなたのチーズケーキは私たちに属している |
#16 |
I Mod, Therefore I Own
Very nice, but I have 2 very important questions.
1. What kind of music do you make? 2. Please say you are going to route that TV cable up and over the framework?
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Bert & Ernie - 2 x Linksys NMH405 with 2 x 1Tb HDD's Gonzo - Apple 15" MacBook Pro |
#17 |
I don't use Dremel.
Cookie Monster; Here's a link to some of my music, thanks for asking!
![]() Two song at youtube if you don't like high quality bandcamp ;D I'm not sure yet about routing the cable through the cage. I might get a larger diameter hose where to put all cables. I wan't a bit rough and informal feel, not overly clinical or planned. One option is to leave the cables in some hose and just attach it to loosely follow the cage. It might look bad when everything else is finished and maybe the cables end up inside the cage tubes. We'll see! MiNiMaL_FuSS: Thanks for the url! Though I try to create my own ideas but it's always great to see what other people have done.
__________________
#18 |
As long as you don't leave it on the floor I'm happy, what about using some of the mesh and making a cable tray then bolting it to the side of the framework?
Oooooof, bit to trance for me. I'm hoping to start learning Ableton in the new year then I can look at making a house track. Nice from 1min though then that bass kick goes.
__________________
#19 |
I don't use Dremel.
Trying to decide between plywood and metal for the desk under the keyboard and mouse. I think I'll go for the asymmetric design otherwise. Note the kitchen wall covered in acoustic foam trying to reduce echo.
__________________
http://www.flickr.com/photos/drakmin/ Last edited by drakmin; 17th Dec 2010 at 16:27. |
#20 |
There be Cows.
central metal design gets my vote.
Do you make a living from your music or is it more for person satisfaction? Intrusive question I know but I'm genuinely interested.
__________________
| Tags |
| apartment, architecture, diy, furniture, interior design, say no to skimlinks |
| Thread Tools | |
| View Mode | |
