#181 | ||
Ultimate Modder
#182 |
Hypermodder
Maybe I'm just dense, or too used to planning things out in Sketchup, but I'm still trying to figure out how this is all going to fit together. Looks very interesting though.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#183 |
Ultimate Modder
I used sketchup on my previous mod cause I wanted something different, more industrial, plans before mod etc. This time though I went back to my ordinary modding ! Half plans, half improvisation! I enjoy modding more that way hope it turns out good at the end! Thanks bro!
#184 |
Building Proxima
That is what is happening with CAGE now. It's drifting off my plans a bit.
__________________
Proxima - The log of Dreams
CAGE - MOTM September 2010 Winner ------------------------------------------------------ LOSIAS.net Losias.net Facebook :: Losias.net Twitter |
#185 |
Ultimate Modder
Improvise my friend and take your time. Patience is your friend, passion is your light!
#186 |
Building Proxima
Awesome!!
__________________
#187 |
Ultimate Modder
Time for a small update guys!
I added the rest of the 1 mm acrylic on the side panel. It wasnt an easy task as I had to bend a little, glue it then bend a little more etc etc. ![]() ![]() I used the mock ups for the windows to draw the outline in order to be cut later. ![]() I also draw a line in the middle of the windows to align them perfectly and also add later a wooden dowel for extra support . ![]() Next day morning I cut the windows by using the diamond disk. I finished the process with sanding drum and some filing. ![]() They might look a little ugly right now cause you can see the glue etc but I have a lot more to do like sanding adding decoration elements etc. ![]() I also glued the second department supporters which they will be used to hold the bottom plate in place. ![]() ![]() Thats all for now guys! I have to go tomorrow to purchase some more glue as I need a looooooot for this project and I will keep on working and updating! Till then, peace! |
#188 |
Keep calm & mod on. =)
Good art usually does get messy before the final product (I remember as a kid watching artists draw a picture & thinking this is crap & then boom it quickly starts turning into something awesome) (don't think I think this is like that, I understand the stages of something awesome brewing ) & to think these are side panels wow , I still don't know what to expect with this but this is going to be so far out |
#189 |
Ultimate Modder
Good point buddy, I think that too when I paint sometimes, I tell my self what if someone sees that now before its finished he will say its crap but when someone sees it finished its a whole different story! Thanks buddy, well this mod its going to change face a million times till its finished so I believe it worths the journey!
#190 |
Or in short this is freaking awesome
![]() ![]() , keep it up mate .
#191 |
Ultimate Modder
Thanks brother again!
#192 |
Modder
Dont tend to swear on forums but....HOLY SH!T
![]() You are an inspiration to wannabe modders like myself..... Love your work AnG3L - cannot wait to see this develop through to completion. ![]() ![]()
#193 |
Making You Feel Old Since 2010
These are my favourite type of builds by a long way. Keep going buddy! +rep
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#194 | ||
Ultimate Modder
![]() Quote:
#195 |
Ultimate Modder
You know what time it is! Time for an update!
Lets start with the work I did these days. Heat gun, burned fingers and the windows are bended and ready!! ![]() Next is the assembly of the second compartment which is going to house the radiators, the pump etc. I used epoxy but then I saw that it wasnt strong enough to hold these pieces together even if was going to add screws later on, so I went with Plastic Welder. ![]() Then it was time to add the screws for the main compartments angles and supporters, glue its just not enough. I also countersunk the holes by using the countersink bit for metal as it works like a charm! ![]() ![]() Also added the angle supporter on the "new!" back panel! ![]() Measuring the spot for the screw holes on the second compartment. ![]() Here is a shot of the Plastic Welder time! :P ![]() Here you can get a small clue/idea of how this mod is going to look like even if the end result will be way better lol! ![]() ![]() I also had to cut a small piece from the side panel supporters cause the panels couldnt open as it was interfering with the 5mm acrylic on the sides. ![]() The process of drilling the "led" holes for the second compartment. ![]() ![]() ![]() ![]() ![]() And the beginning of the second side panel! More to follow! ![]() Thanks for watching my work guys, till next time, peace! |
#196 |
Slacker
always a pleasure to watch mate :-)
__________________
"I have not failed. I've just found 10,000 ways that won't work," Thomas Edison ![]() |
#197 |
Saving for a desktop...
Are you doing this..... in your bedroom? :O
__________________
[Acer Aspire 5920][T5750][4GB][X3100][M4 128GB][Logitech Marble Mouse][7-Pro]
[HP Microserver N40L][Neo@1.5GHz][6GB][2x3TB in RAID1][2TB+500GB+250GB][UbuntuServer] PersonalBest: i7 2600k @5.2Ghz 1.53V on a Fenrir , GTX560 @1006Mhz, 4632Mhz [@ASUS+BT OC Summit '11][Weihrauch HW100S .22 + .177][Hawke 4-12x50 + 4-12x40] + [Weihrauch HW97K .22][Tasco 3-9x40] |
#198 |
Ultimate Modder
Thanks brother!
#199 |
Ultimate Modder
Yes, this is my working place, also a washing machine outside which I use as a bench too! Lack of space but not lack of passion! :P
#200 |
Hypermodder
I don't think you can ever really have enough room to work in. I've got about 2/3 of a 16' x 18' building/shed and I still feel cramped. I think Alex could probably mod and pull this stuff off in a closet if he had to. This is looking very interesting...
__________________
| Tags |
| awesome, plexi |
| Thread Tools | |
| View Mode | |
