Reply
Thread Tools View Mode
Old 14th Dec 2010, 19:42   #1
mac1as
Acid Veins
mac1as has yet to learn the way of the Dremel
Acid Veins - Cosmos S (Water Cooled, Dual Loop)
Hello to all Modders maniac, I'm new on forum and want to show You my project worklog:
code name: >> Acid Veins <<.
Main Components:
DFI DK X58-T3eH6
Intel i7 920
OCZ 6GB PC312800 CL7
HD R5850 + GeForce 9600 GT
SilverStone Strider 1000W - ST1000
WC Components:
EK Water Blocks EK-CoolStream RAD XT 240
EK Water Blocks EK-CoolStream RAD XT 360
2x Laing DDC-pump
EK-BAY Spin Res DUAL Loop - Black Acetal
"Veins" 10/13
EK Water Blocks EK-Supreme LT Acetal+Nickel
NB - EK Water Blocks EK-NB/SB 5 Acetal
EK Water Blocks EK-FC5850 Acetal + Nickel + EK Water Blocks EK-FC5850/5870 RAM Backplate - Black + EK Water Blocks EK-FC9600 SLI - Acetal VGA Block
MIPS RAM cooler 5 incl. 3 RAM Module Nickel POM Limited Edition
2l Thermochill EC-6 Clear 1000ml + Mayhems Dye
Other Components:
1x AquaComputer Aquaero
2x Lamptron Fan-Atic: 5-port
7x 120mm Enermax Magma (Green)
3x 120mm Scythe Kaze Jyuni Slip Stream 120mm Fan 1900 RPM
All closed in Cooler Master Cosmos S.
mac1as is offline   Reply With Quote
Old 15th Dec 2010, 15:38   #2
mac1as
Acid Veins
On the begining I want to apologise for my english, it isn't my primary language so please by tolerant, I won't be writing much instead of that I will try show more pictures.
How Cosmos S looks everyone know so I will skip showing it and start from naked pictures of case:
Hole for 240 radiator on bottom:
Old 15th Dec 2010, 15:39   #3
Mattmc91
LOLS I TROL YOU
Mattmc91's Avatar
Mattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run CrysisMattmc91 can run Crysis
use image tags such as
Code:
[img] [/img]
around your links, saves people clicking them each time.
edit: on topic, nice cuts on the bottom
Mattmc91 is offline   Reply With Quote
Old 15th Dec 2010, 18:34   #4
mac1as
Acid Veins
Rivets removed, case in pieces, many pieces ready to powder coat (black matt):
Visit in powder coat workshop:
couple minutes in furnace:
and we have it:
OK with pictures now?
Old 15th Dec 2010, 21:05   #5
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Off to a good start
bulldogjeff is offline   Reply With Quote
Old 16th Dec 2010, 01:18   #6
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for president
Pictures are perfect now, lookin' really nice so far.
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is online now   Reply With Quote
Old 16th Dec 2010, 16:43   #7
mac1as
Acid Veins
Putting case back together:
Old 16th Dec 2010, 17:19   #8
infekted.one
Multimodder
infekted.one's Avatar
infekted.one has yet to learn the way of the Dremelinfekted.one has yet to learn the way of the Dremel
Nice rivets!!! (that's got to be geek innuendo...)
Nice thorough work, what's your plans?
__________________
PROJECT : MONSTER
TT Kandalf * Asus P5E3 * Intel Q9550 * 4Gb G.Skill Ripjaws* XFX HD4980 X2Xfired * TT Toughpower 850w
WD Raptor 150Gb X2 * Samsung F3 2Tb X2 * Win7 Ultimate64 * Saitek Eclipse II * Saitek GM3200
PROJECT : CLU
The absolute genius that is JK quoted " You can't polish a poo, but you can roll it in glitter"
infekted.one is offline   Reply With Quote
Old 16th Dec 2010, 18:16   #9
mac1as
Acid Veins
Originally Posted by infekted.one View Post
what's your plans?
Hmmm, it won't be anything special, visit my worklog sometimes and You will see.
Back to rivets:
Old 15th Jan 2011, 16:40   #10
mac1as
Acid Veins
OK time to move on, fan mode:
Under UV light:
Few small case moddifications:
Old 16th Jan 2011, 11:02   #11
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Really nice and clean mod my friend, the attention to detail it will pay u out at the end! Mod on!
AnG3L is offline   Reply With Quote
Old 16th Jan 2011, 11:07   #12
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
This is fantastic, so are the fans, so are the LED's. Mod on!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is online now   Reply With Quote
Old 16th Jan 2011, 11:43   #13
ThirtyQuidKid
Supermodder
ThirtyQuidKid has yet to learn the way of the DremelThirtyQuidKid has yet to learn the way of the DremelThirtyQuidKid has yet to learn the way of the DremelThirtyQuidKid has yet to learn the way of the DremelThirtyQuidKid has yet to learn the way of the DremelThirtyQuidKid has yet to learn the way of the Dremel
This is looking great. Should be a great finish to it.
p.s. I especially like the use of plasticene!!!!! I would never have thought of thaty and probably used some expensive resin based putty and tried to dye it without sucess.......
Good work.
ThirtyQuidKid is offline   Reply With Quote
Old 16th Jan 2011, 12:34   #14
mac1as
Acid Veins
Thank You guys for good words.
Here You can see pump mod:
And some sleeving:
Sleeving could be better.
Cable menegment mode:
My hands was bit shaking and its not like it should be, but it not so bad.
Switch for UV Cathodes:
Block for GeForce 9600GT to PhysX:
and after nickle plating:
Mobo I/O Backplate & GFX slots after powder coating:
Old 16th Jan 2011, 15:51   #15
KidMod-Southpaw
What can I say, delicious! That's one hell of a cable management system for the 24 pin.
__________________
Old 16th Jan 2011, 18:00   #16
Mizakoto
Problematica
Mizakoto's Avatar
Mizakoto has yet to learn the way of the Dremel
One word: Whoa
__________________
- GPU: EVGA GTX 670 4GB SC - Case: Bitfenix Prodigy ITX - CPU: Intel Core i7 870 2.93GHz
- Kboard: QPAD MK-85 Pro - RAM: 8GB 1333MHz PC3-10600 DDR3 - Headset: Dr. Dre Beats Studio Red
- SSdrive: Samsung 830-128GB - Hdrive 2TB WD Caviar Green - Mboard: ZOTAC H55-ITX WiFi
- Watercooler: Corsair H100i - Mouse: Steelseries Ikari Optical - Mat: Razer Goliathus Speed - Large
Mizakoto is offline   Reply With Quote
Old 16th Jan 2011, 18:31   #17
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Looking Great Mac1as, fantastic attention to detail. Should make a great finished article
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 16th Jan 2011, 20:10   #18
mac1as
Acid Veins
I will try to put it all in to case, won't be easy:
Some stuff inside:
with cables:
it wont be easy to organize it:
Old 18th Jan 2011, 20:51   #19
KidMod-Southpaw
Whoa, this gets better and better!
__________________
Old 18th Jan 2011, 21:10   #20
mac1as
Acid Veins
I installed blocks for GPUs, MOBO & MEM:
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
