#1 | |
Folding in memory of my mum
Is my Q6600 sulking?
I noticed MrGumby saying this on another post:
![]() I figure I am not getting the best out of it? Could I have said something to upset it? Has it realised it has rivals for my affections? It is currently running P6701 (R167, C32, G3) worth 3826pts and HFM claiming 2683ppd - that's 24/7 running with generally over 90% of the CPU's attention. Any comments welcome! |
#2 |
Aggressive PC Builder
That does seem low
I was getting 2-2.5k on my e6600 when I was running it.
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Splooshiba My flickr - My blog it'sfilmnotmovie - hwbot |
#3 |
Supermodder
Have you tried running it at 3.2?
#4 |
I DID try overclocking it a few months ago, but it became unstable. The cores are around 68 to 73 celsius. The air cooler is effin useless though and sounds too loud - running at around 3700rpm. I seemed to recall summat in CPC about overclocking this chip, but I cannot remember which issue
![]() I also looked at database on overclock.net and there was only single entry for Q6600 at 2.4GHz and that was 4k ppd. According to CPU-Z, it is plodding along on 266.9MHz bus on x9 multiplier, it is a B3 rev chip with 1.208V core. It is sat in a Foxconn P35A01 mobo. |
#5 |
CPC 464 User
B3s do run hotter than the GO that i use. I have my cpu under a titan fenrir. Make sure your ram is set to the correct voltage and that its running to its full potential.
__________________
#6 | |
What's the 'right' voltage & full potential? Sounds like the sort of stuff teachers used to say to me at school! (Well, not the voltage thing ...) |
#7 |
It is 2GB of DDR2 DRAM freq 333.7MHz FSB : DRAM 4:5. Would have to go into BIOS to see much more that that. There are a load of timings too - in order 5,5,5,15,36. It is OCZ26671024V max BW 5300 (333MHz) at 1.8V allegedly - didn't appreciate all that was in CPU-Z!
#8 |
CPC 464 User
I mean that you go into the bios and make sure your memory modules are set to theier correct voltage. This depends on the make and model of the ram. Also instead of running 9x266 try a different memory divider depends on the speed of your ram.
And yes wakey is as shakey as ever although i live in ossett these days
__________________
#9 | |
#10 | |
Multimodder
it could be that the project is a 'big' one. what ppd's do you get on other projects? |
#11 |
CPC 464 User
Good point on the work unit. Im sure with a little bit of tweaking tho he should get some extra speed out of his Q6600
__________________
#12 | |
Folding in memory of my father
Are all the cores running flat out in Task Manager? Is that 90% something you set in config? I could ask for OS and client version, though I doubt they would cause such a big difference. Good practice though.
__________________
#13 |
CPC 464 User
Not to side track the thread but than christopher for your help. First SMP WU folded should appear on my stats soon.
__________________
#14 | |
Project averages on this machine: P6701 2,742ppd P6702 2,478ppd P6077 3,298ppd P6075 3,594ppd P6073 3,878ppd P6071 3,843ppd P6070 3,096ppd P6069 3,298ppd P6068 3,334ppd P6067 3,003ppd P6066 3,635ppd P6064 3,832ppd P6062 3,289ppd P6061 3,809ppd P6060 3,710ppd P6059 3,553ppd Of tasks presently running A3 core 25h 23m, system idle 4h 23, explorer 1h 00m, services 51m etc. I will try with later client and see how I go on ... |
#15 |
I have installed client 6.30 and set smp advmethods and big flags. It has started again on P6701 Run 167, Clone 32 and Gen 3 so will get a fair comparison. btw, I have persuaded the whippet to walk a little faster in't 'leccy generating wheel, so have cranked up the CPU from 2400MHz to 2519MHz!
#16 |
CPC 464 User
Yeh ive just got a P6701 and my ppd has dropped below 6K.
__________________
#17 |
You can find some details of the projects here. P6701 seems to have lots of atoms, but a rather low credit.
If you really wanted to, you could avoid being given them by omitting the -big flag once this unit is completed and returned. Stanford's policy is that if you keep missing deadlines, you should stop running those units, but otherwise they never comment on the credits for individual projects. No doubt projects will get larger and larger over time, and have shorter deadlines. All of the PPD numbers you report seem a little low. Have you benchmarked your machine? I accidentally run mine with the memory configured in single, rather then dual, slot configuration. It makes a noticeable difference.
__________________
#18 | |
__________________
#19 |
I have just got a Thermaltake Frio CPU cooler, so will try and check out the config in next few days whilst fitting it, thanks
#20 |
I *am* a Dremel
Have you got a passkey so you are getting your bonus's?
PS skim read this thread, but with decent cooling you should easy hit 3ghz......
__________________
Corsair 650D 3770K @ 4ghz LCS Cooled ROG Maximus Formula V 32 GB Ballistix Tracer EVGA Titan 256GB Samsung PRO | 480GB SANDISK Extreme |
| Thread Tools | |
