Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Dec 2010, 10:23   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Silverstone ML03 Home Theatre PC case review
It's cheap, smart and has front-panel USB 3 ports, but is the ML03 a decent case?
http://www.bit-tech.net/hardware/cas...c-case-revie/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 28th Dec 2010, 10:46   #2
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Hmmm, If you'd install something like the passive HD5450 with just the one filtered fan in the right, upper corner... that wouldn't get any airflow at all, would it?
Have you tried looking for a less-deep DVD-drive? There's over a cm difference between brands.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 28th Dec 2010, 10:58   #3
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
With the latest CPUs/IGPs you shouldn't really need a HD 5450 to be honest, but yes it won't get any airflow to the fins, only the back of the card.
DVD drive: that's true, but how often can you find that information? Most people opt for the cheapest.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 28th Dec 2010, 11:14   #4
Boscoe
"and she'll be foamin at the vag."
Boscoe's Avatar
Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.
It's not as nice as the Lian Li HTPC cases.
Boscoe is offline   Reply With Quote
Old 28th Dec 2010, 11:53   #5
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
It's also half the price of most of them
__________________
Old 28th Dec 2010, 12:00   #6
rickysio
N900 | HJE900
rickysio has yet to learn the way of the Dremel
Oh bit, you tease.
rickysio is offline   Reply With Quote
Old 28th Dec 2010, 12:02   #7
Fordy
Multimodder
Fordy has yet to learn the way of the DremelFordy has yet to learn the way of the DremelFordy has yet to learn the way of the Dremel
Double post.. apologies.
__________________
Fordy
HTPC Project Log
Fordy is offline   Reply With Quote
Old 28th Dec 2010, 12:04   #8
Fordy
Multimodder
Dimensions? Most HTPC cases wouldn't $it in my rack, have to be selective!
It's low profile, so height should be fine as i can for some full height models. But I'm still worried about the depth.
__________________
Fordy
HTPC Project Log
Old 28th Dec 2010, 12:58   #9
Burdman27911
Modder
Burdman27911 has yet to learn the way of the Dremel
And I'm worried about width for my entertainment system racks. Additionally, I wish that the dvd drive was stealth and there was a mounting spot for an internal IR receiver... a man can dream.
PS - Honestly, the GD04 case tempts me a little more than this one. It has better looks and the price isn't much more (at least in the US).
Burdman27911 is offline   Reply With Quote
Old 28th Dec 2010, 13:34   #10
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
Are there rack ears for it?
Use quite a lot of things like this building porta-puters which then get put in flight cases in order to travel around.
Phil Rhodes is offline   Reply With Quote
Old 28th Dec 2010, 14:27   #11
Fordy
Multimodder
No need to worry about width, it won't be more than 19" and any non mini-model rack will hpuse 19" equipment.
As for the UK price, Scan have it at 46.28.
__________________
Fordy
HTPC Project Log
Old 28th Dec 2010, 14:56   #12
Xir
Xir's Avatar
You're right off course, I just thought in case of reusing old hardware.
DVD Drive: wel, reading technical Specifications helps Us users of Shuttles know all about size limitations (Pun intended)
Seriously, the websites where I buy show the dimensions...don't the British ones?
__________________
SN25P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
