Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st Dec 2010, 11:36   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Fractal Design launches Define Mini case
Need a quiet home for a micro-ATX build? Fractal Design thinks it's got your needs sorted.
http://www.bit-tech.net/news/hardwar...ne-mini-case/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 31st Dec 2010, 11:40   #2
FelixTech
Robot
FelixTech's Avatar
FelixTech has yet to learn the way of the DremelFelixTech has yet to learn the way of the Dremel
How does this compare size wise with that 'Beast' PC Custom PC made?
__________________
Use ClickMechanic for car repairs and servicing!
Play Animal Shogi for free on Android!
FelixTech is offline   Reply With Quote
Old 31st Dec 2010, 11:47   #3
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming Saiyan
Fractal Define Mini: 210 x 395 x 490mm (WxHxD)
Beast (Antec P180 Mini): 283 x 510 x 515 mm (WxHxD)
So smaller than the Beast all round.
The Define Mini looks great, can't wait for a review.
__________________
Gaming: [Silverstone TJ08-E][Asus Z170M-PLUS ][i5-6600K][Tundra TD03][16GB 2666MHz][Asus 7970 DCUII TOP][Samsung 850 Evo 500GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus Z97M-Plus][i7-4770K][Corsair H55][16GB 1600MHz][iGPU][Samsung M.2 NVMe 256GB][Seasonic X-650 Gold]
Kids: [Silverstone SG05B][Asus H87I-Plus][i3-4330][8GB 1600MHz][Asus 6850 DirectCU][Crucial M4 256GB][ST45SF 450w][Dell E207WFP]
NAS 1:[Synology DS211j] NAS 2:[Homebrew OMV]
Fingers66 is offline   Reply With Quote
Old 31st Dec 2010, 12:42   #4
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Nice looking case. Can't wait to see some numbers!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 31st Dec 2010, 13:01   #5
maximus09
Forever n00b
maximus09's Avatar
maximus09 has yet to learn the way of the Dremel
SOLD! Will by this as soon as it comes out, thanks Fractal!
__________________
MAIN: Fractal Design Define R2 - MSI P67A GD53 - i5 2500k@4.5GHz - Corsair H60 - Corsair Vegence 4GB - MSI 560 GTX TI Twin Frozr II - OCZ Vertex 2 120 Sandforce - Samsung F1 500GB
HTPC: Antec Fusion V2 - Abit I-N73HD - E2200@2.4GHz - Zalman ALCU - Corsair XMS 2GB - Sapphire HD5450 - 2x Samsing F1 1TB - 1x Samsung F3 1.5TB
maximus09 is offline   Reply With Quote
Old 31st Dec 2010, 13:07   #6
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
Looks like an improvement over the Mini P180 in every way.. It's a shame that the only way for me to get one is to order from Canada (Is NCIX still the only place selling Fractal Design products to Americans?)
docodine is offline   Reply With Quote
Old 31st Dec 2010, 13:10   #7
HyBry
Minimodder
HyBry has yet to learn the way of the Dremel
I am not fully sold that a full length GPU can fit there comfortably even after removing the top HDD cage.
But I am sure they have thought of that. Looking at it for a potential next upgrade..
__________________
S**t happens... Life goes on...
HyBry is offline   Reply With Quote
Old 31st Dec 2010, 13:10   #8
hbeevers
Yes, it can play crysis!
hbeevers has yet to learn the way of the Dremel
they know that cooling is an issue with small cases so they put in 6 fan mounts but i don't see any dust filters? If it's a bottom mounted PSU with no dust filter then they're mad.
__________________
Intel Core i5 4690K / Gigabyte GTX 670 / Corsair H75 / Coolermaster Advanced CM690 II / 8GB RAM / 256GB SSD / 1TB HDD
hbeevers is offline   Reply With Quote
Old 31st Dec 2010, 13:14   #9
Fingers66
Kiwi in London
Fingers66's Avatar
"Supports graphic cards with lengths up to ca 260mm when removable HDD-bay is in place"
"Supports graphic cards with lengths up to ca 400mm when HDD-bay is removed "
"No PSU included (removable filter below PSU)M/B compatibility: Mini ITX and Micro ATX "
Source: http://www.fractal-design.com/?view=...gory=2&prod=58
__________________
Old 31st Dec 2010, 13:15   #10
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
HELL YES.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 31st Dec 2010, 13:18   #11
nemo
Foregone Destruction
nemo's Avatar
nemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremelnemo has yet to learn the way of the Dremel
Nice, but the first photo of the article should have included a coke can or something to give a sense of scale
__________________
CPU : Intel Core i7 930 / Mobo: Asus P6TSE / RAM : 6gb Corsair Dominator DDR3 8-8-8-24 / Sapphire Vapor-X HD5870 1gb / CpuCool: Titan Fenrir Xmas / PSU: Antec True Power New TP-650 / 1Tb F3 / Mouse : Logitech G7 Wireless / Case : Fractal Design Define R2 Silver Arrow / OS : Windws 7 Ultimate / Firefox
nemo is offline   Reply With Quote
Old 31st Dec 2010, 13:26   #12
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
No it isn't.
There are filters.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 31st Dec 2010, 14:16   #13
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
Looks like my current F.D. "array" case is on it's way... mine has/ is having problems with the 12v line dropping to 8 V, so a bit more room for an ATX PSU is a good thing IMHO.
dunx
__________________
Gigabyte Z87x OC-Force - i7-3770k @ 4.3 GHz - 32 GB Corsair DDR3 @ 2400 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 - GTX 780 - HD 5870 - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate
dunx is offline   Reply With Quote
Old 31st Dec 2010, 14:24   #14
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
For a ATX this case is way too big compared to an Antec Threehundred with 205 x 457 x 465 mm or even better a LianLi PC-A05 with 210 x 381 x 490 mm, which are both fullATX-towers.
A Sugo SG30 is what I call a real ATX-case with 200 x 360 x 312 mm. Space for 2x 3.5"HDD + 1x 5.1/4" optical and you can even fit GPUs of up to 10.5". A H50 or H70 for cooling the CPU and voila you've even rexolved the issue of the PSU-positioning not allowing for big coolers.
I'm not impressed at all tbh and would rather buy a normal sized Define R3 instead.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 31st Dec 2010, 15:21   #15
flibblesan
Destroyer
flibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpit
Was looking at buying Mini P180 but I'll be buying this case instead. Looks a lot nicer and having the power button on top rather than behind the door seals the deal.
flibblesan is offline   Reply With Quote
Old 31st Dec 2010, 15:22   #16
13eightyfour
Formerly Titanium Angel
13eightyfour's Avatar
13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan
Aside from the array R2, ive got to say im not a fan of any of fractals cases. Its nice to see a unified look to the whole range, but id like to see something new tbh, not just smaller/bigger versions of the same case.
13eightyfour is online now   Reply With Quote
Old 31st Dec 2010, 15:51   #17
subtec
drawing boxes
subtec can run Crysissubtec can run Crysissubtec can run Crysissubtec can run Crysissubtec can run Crysissubtec can run Crysissubtec can run Crysissubtec can run Crysis
40 liters is small? If you say so...
subtec is offline   Reply With Quote
Old 31st Dec 2010, 16:31   #18
Zinfandel
I Mod, Therefore I Own
Zinfandel's Avatar
Zinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpit
As above... Pretty much bigger than most uATX cases...
__________________
I request you to interact on this forum in a streetwise style without going against the Data Protection Act.
Zinfandel is offline   Reply With Quote
Old 31st Dec 2010, 16:56   #19
Denis_iii
Ultramodder
Denis_iii's Avatar
Denis_iii has yet to learn the way of the DremelDenis_iii has yet to learn the way of the Dremel
+1 but i'm sure BT will be doing a full review ASAP.
Now just need to find a company that does nice wooden boxes for transport of full rig.
Denis_iii is offline   Reply With Quote
Old 31st Dec 2010, 20:33   #20
das_mod
Minimodder
das_mod's Avatar
das_mod has yet to learn the way of the Dremel
I hope the other side panel is removable with easy access to the CPU area...
Im sick and tired of cases that force me to remove the whole motherboard to install a bracket for cpu cooler upgrades.
__________________
PowerSpec mini ATX | Intel p4 2.4gHZ | ASUS P4b533-E | 1GB Patriot DDR | 40GB Maxtor DiamondMax HDD | MSI nVidia MX 440 | BTC DVD-RW | 420W psu | 14" LCD/TV
das_mod is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
