Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 12th Jan 2011, 22:45   #1
EdwardTeach
Multimodder
EdwardTeach has yet to learn the way of the Dremel
Problems with a new Samsung F4 2tb
I recently bought a Samsung F4 2tb drive, and before I started moving serious amounts of data across to it, I thought I would run ES-Tool to check everything is healthy.
I was disappointed and surprised to see that there was an error detected. I am wondering what the chance are that this could be a false alarm.
This is the report from ES-Tool:
Total Loop Number 1/1
[Notice] Errors was detected in this Test!!!
It’s recommended to do Erase HDD!
(All Data Will be lost!
You must backup before running erase HDD)
Then run this Test programme again.
If errors still happen, please consult to service centre.
Read DMA: Pass
Check S.M.A.R.T: Pass
Spin Down/UP: Pass
Write Verify: Pass
Random Surface Scan: Pass
RAM verify Test: Testing ..........-
Busy Not Clear
Multiple Read Test: Testing Pass
Service Code => AJ41: RAM Error
Total Elapsed Time: 05:51:33
I am going to follow the suggestions -> move all my data off it -> perform Erase HDD and run the scan again.
I am wondering whether there is any likelihood the second scan will be ok?
__________________
Intel Core i7 930, Gigabyte GA-X58A-UD3R, Asus ATI Radeon HD 5850, Patriot Viper 6GB, Intel X25-M Mainstream 80GB, Samsung SpinPoint F3 1TB, Corsair HX 750W, Fractal Design Define R2 Midi Tower Case - Silver Arrow
EdwardTeach is offline   Reply With Quote
Old 12th Jan 2011, 23:46   #2
Deders
I Mod, Therefore I Own
Deders's Avatar
Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.Deders is a hoopy frood who really knows where their towel is.
It could possibly an error with the file system in which case it could be ok, even if it has to mark a few bad sectors off. On the other hand it could be a physical error on the hardware itself.
Either way the only way to find out is try it and see...
__________________
i5 750@3800 - MSI P55 GD65 - Asus GTX670 DirectCU II - 4GB OCZ DDR3 @1440 7-7-7-18 - Be Quiet! Straight Power E9 500W - Nanoxia Deep Silence One - X-FI Xtreme Gamer - Samsung 830 128GB - Spinpoint F3 1TB - WD Caviar Blue 640 - LG Flatron W2252TQ - Razer Deathadder - Thermaltake Contac 29.
Deders is offline   Reply With Quote
Old 12th Jan 2011, 23:56   #3
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
It happens... HDD can break just by transportation...
I would RMA it or perform a store exchanged.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 13th Jan 2011, 02:46   #4
EdwardTeach
Multimodder
What exactly is meant by "erase hdd". I.e specifically what is it samsung intend me to do here.
I had assumed that this was going to be one of the menu options in es-tool but it is not.
There is a low level format option in the menu, but if they wanted me to do that presumably they would have used the same term.
__________________
Old 13th Jan 2011, 09:28   #5
EdwardTeach
Multimodder
I have ran the es-tool diagnostic a few times subsequently and the drive has passed without any problems.
How likely is it that the errors detected first time around were a false alarm?
I never performed "erase hdd" - not knowing what was intended. I did however move ~100gb of data off the drive prior to running the subsequent tests. I can't see how this would have any bearing on a ram test though?
__________________
Old 13th Jan 2011, 11:01   #6
EdwardTeach
Multimodder
Ok - it has just failed the diagnostic again.
Last night I ran the diagnostic a couple of times, but skipped the full surface scan, and it passed the ram Verify test fine.
I then set it up to do the diagnostic test with a full surface scan. This was what I had done when it failed initially. And once again the drive failed the test with the same error code.
I can see any logic in this - how would a full surface scan affect the ram verify test?
__________________
Old 13th Jan 2011, 11:53   #7
Deders
Deders's Avatar
What do you mean by ram test? looking at the es-tool download page I can't see any reference to any ram test in the text or pictures.
__________________
Old 13th Jan 2011, 12:57   #8
EdwardTeach
Multimodder
If you look in the first post - I am referring to the ram verify test.
It is the final stage of the diagnostic.
__________________
Old 13th Jan 2011, 13:01   #9
Deders
Deders's Avatar
Have you tried the windows ram test or prime95 blend to see if your ram is fully stable?
__________________
Old 13th Jan 2011, 13:10   #10
EdwardTeach
Multimodder
I am presuming that this "ram verify" test is not actually tasting my main ram modules, but is instead referring to the hd's cache.
I can't see any reason es-tool would be testing my normal ram. It is a diagnostic tool solely for samsung hd's
__________________
Old 13th Jan 2011, 13:15   #11
Deders
Deders's Avatar
neither would I but I would have thought they would've used the term cache, never hurts to double check I guess, maybe the cache is unreliable?
__________________
Old 13th Jan 2011, 21:57   #12
EdwardTeach
Multimodder
It seems that the problem may lie with the version of ES-Tool I am using.
http://forums.overclockers.com.au/sh...&postcount=176
I have downloaded version 3.01v and I am going to run a new diagnostic scan tonight, so fingers crossed.
__________________
Old 15th Jan 2011, 22:33   #13
EdwardTeach
Multimodder
Just an update - the drive passed th diagnostic fine with 3.01v, therefore it seems the problem was es-tool giving false positives.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
