Old 14th Apr 2012, 09:20   #2341
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
crazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremelcrazyg1zm0 has yet to learn the way of the Dremel
Originally Posted by Smellyhead View Post
Can anyone recommend a good HQ choice for Dark Eldar?
I've got a £25 voucher to spend on their online store.. and I can't decide what to get.
I was thinking some Scourges (£15.50) so I've £9.50 left, which is enough for a HQ model but not much else.
Haemonculus Is a great choice and fits in most armys happily I would suggest that untill you know fully what type of DE army you are going for.
__________________
Originally Posted by GreatOldOne View Post
That just made me LOL my coffee over my keyboard....
Intel i7 2600k | Be Quiet Dark Rock Advanced | ASUS P8P67 pro | Patriot 1600 6GB | XFX 6870 Twin fan | corsair 650W | OCZ Vertex II 30gb | Samsung SP 1TB, Samsung 1.5TB, Samsung 500GB | Lian Li V-1000 | 2x23" screens
crazyg1zm0 is offline   Reply With Quote
Old 14th Apr 2012, 09:43   #2342
Cerberus90
petrolhead
Cerberus90's Avatar
Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!
I think that power sword looks great, its different to the normal lightening down the blade, but still gives the right look to it.
Nearly finished my first Ultramarines tactical squad (about time, ).
Got another one sat on the shelf waiting to be base coated, and my chaplain which I'm keen to get started, as the finecast quality is a damn site better than my Imohtek one (which to be honest I think was a reject, ).
__________________
Steam: Cerberus90
| Q6600 @ 3.2GHz | Asus P5K Premium | 4GiB Patriot 1000MHz | 256GB Samsung 830 |
| Gigabyte GTX460 @ 830/2000 | Fractal Core 3000 | 24" BenQ G2420HD |
Cerberus90 is offline   Reply With Quote
Old 14th Apr 2012, 09:50   #2343
philheckler
Used to be a pc enthusiast
philheckler's Avatar
philheckler has yet to learn the way of the Dremelphilheckler has yet to learn the way of the Dremelphilheckler has yet to learn the way of the Dremel
Thanks guys.. im thinking broken concrete slab with bits of rebar poking out , but i'm going to have to get the figure off the base to do it....
__________________
i5 750 currently @ 3.6ghz / p7p55d pro / 4 gb gskill ripjaw 1600mhz cas 8 (@1440mhz) / freezer 7 pro rev2 / gtx470 sli / Corsair hx850 psu / coolermaster cm690 v2 advanced
philheckler is online now   Reply With Quote
Old 14th Apr 2012, 11:25   #2344
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
That sounds like a great idea phil. you could even have a impact point under his back foot spreading to a big crack with the rebar in or something.
Why not look into some of the resin bases phil? theres quite alot of different ones I put my ork warboss on a stone one i had spare.
if you haven't pinned him yet i usually glue my guys to a base then break them off gently when i am finished the painting so that i can work on the base or transfer to another base
Originally Posted by RedFlames View Post
space hulk style deck plating or something urban [if only for no other reason than so i can see how to do that kind of base myself... grass has no place in 40k imo]
I don't agree here, certain units and certain armies suit different bases, Orks i think can get away with grass and greenery on the bases, space-marines cant they need something more man-made or industrial.
__________________
Old 14th Apr 2012, 11:28   #2345
gilljoy
I *am* a Dremel
gilljoy's Avatar
gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!
from my experiences playing against dark eldar the archon is really good, so are the hameonculus, especially the special character one who makes wracks troops.
Also troop wise, wytches are cool too, they just wipe my space wolves away most times
__________________
Intel Core i7 3770K ||H100i || Gigabyte Z77X-UD3h||16gb Corsair XMS3
Gigabyte 7970 Ghz edition ||1tb Samsung HDD + Crucial M4 64Gb|| Xigmatek Midgard
gilljoy is online now   Reply With Quote
Old 14th Apr 2012, 13:52   #2346
philheckler
couldn't get the figure off the base - curse you wilko super glue gel! so i had to improvise around the feet of the figure , green stuff flag stones / pva sharp sand and fine sand mix to form small rubble mounds... oh and the obligatory skull from my ogres bitz box...
__________________
Old 14th Apr 2012, 14:23   #2347
liratheal
Sharing is caring
liratheal's Avatar
liratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpit
Looking good, Phil.
Nearly done with the first squad of Scorpions:
And Gilljoy, Khorne Red on paper:
http://i.imgur.com/ObAmY.jpg
__________________
Desktop: Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, 2x XFX 6870 1gb's, Corsair 1kw
Laptop: Alienware M15x, 5730 1gb, 8gb DDR3, i5 520M, Samsung 830 256gb, Seagate Momentus XT 500gb
WHS: Gigabyte Z77-D3h, i3 2100, 16gb DDR3, 5xWD 1tb, 5x Seagate 1tb
I game, Do you?
liratheal is offline   Reply With Quote
Old 14th Apr 2012, 14:57   #2348
philheckler
Thats a fine looking squad!
__________________
Old 14th Apr 2012, 15:40   #2349
Cerberus90
petrolhead
Cerberus90's Avatar
Look great lira.
My, slightly less impressive, tactical squad,
Uploaded with ImageShack.us
Still not decided on whether I want to stay with Regal blue armour or full Ultramarine blue. In some lights the regal looks really good, in others it looks very dark. Only one or two very small things left to do on the squad, like scopes and eyes, and a little left on the sergeants head.
I think I need to get a new Blood red too, as mine have lost their brightness.
__________________
Steam: Cerberus90
Old 14th Apr 2012, 15:48   #2350
Smellyhead
Supermodder
Smellyhead has yet to learn the way of the DremelSmellyhead has yet to learn the way of the Dremel
Some nice looking models Phil and Lira.
Cerberus try just highlighting them with Ultramarine blue and maybe give them a blue or black wash in recesses on the armour, should add some more depth to them. Other than that their coming along nicely.
Was at my local store today picking up a DE battle force as a birthday gift from the girlfriend and the guy talked me into buying an Archon to go with them as I was picking paints/brushes out. So now I need to figure what I can get for £25 again.
__________________
i7 2600k | Gigabyte Z68A-D3-B3 | 8GB Vengence | MSI R7870 OC | Antec VP550
Smellyhead is offline   Reply With Quote
Old 14th Apr 2012, 16:41   #2351
Cerberus90
petrolhead
Cerberus90's Avatar
Did try highlighting with ultramarines, but I think a. my highlighting skills suck, and b. its a bit of a jump from regal to ultramarine blue.
The one there that is in all ultramarine blue, is highlighted slightly with space wolf grey, which does look nice, but to my eyes, doesn't look 'Ultramarine', it looks too bright and pastel coloured.
__________________
Steam: Cerberus90
Old 14th Apr 2012, 17:39   #2352
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
again get a Hamey :P and a venom would be my suggestions both are very usefully in most if not all DE armys.
Also Do any of you have any or the ORK nob metal jaw plates? im going to be doing some customizations and need about 4 or 5 i think theres 3 diff designs too
__________________
Old 14th Apr 2012, 19:30   #2353
gilljoy
I *am* a Dremel
gilljoy's Avatar
Raiders and dark eldar troops, those guys with special weapons and raiders rip holes in everything.
__________________
Old 14th Apr 2012, 22:27   #2354
philheckler
lick of paint once it all dry'd et voila... (hope you all like it)
(couldn't resist the tuft of grass...)
__________________
Old 14th Apr 2012, 23:31   #2355
RedFlames
Chief Gorilla - CC 2013
RedFlames's Avatar
RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.RedFlames is the Cheesecake. Relix smiles down upon them.
looks good, the grass works done like that...
but in general [to me] 40k = warzone, all foliage is either dead, dying or burnt [or weird things if 'nids are involved] so having 40k stuff stood in what looks like the middle of someone's lawn just doesn't look right...
__________________
I have the heart of a child... in a jar... on my desk...
RedFlames is offline   Reply With Quote
Old 15th Apr 2012, 09:01   #2356
Almightyrastus
Bringing the awesome
Almightyrastus's Avatar
Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by liratheal View Post
Excellent, thanks for that. I used to have a great wash recipe that I used all the time but i can't remember what it was. I think it was something along the lines of a purple and brown mixed then heavily watered down as this was from before they had all the nice dedicated washes and stuff.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 15th Apr 2012, 20:04   #2357
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
Just trying my hand at gs work making an iron jaw for my warboss
__________________
Old 15th Apr 2012, 22:36   #2358
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
did some work tonight Heres the pics
2 Chaplains part of my Death company army.
My warboss on his new base and with his iron jaw still msetting at the moment
__________________
Old 15th Apr 2012, 23:00   #2359
Smellyhead
Supermodder
They look pretty nice Crazy.
Need tomorrow to come so I can start building my Dark Eldar. Though now I'm stuck on what theme to use for bases, I guess a city themed one would suit them best since I would assume they raid cities etc for their kicks.
__________________
Old 16th Apr 2012, 00:32   #2360
crazyg1zm0
I *am* a Dremel
crazyg1zm0's Avatar
yea some sorty of city type. if you dive into their history it works, or something alien
__________________
Reply
Tags
40k, games workshop, no skimlinks, say no to skimlinks, white dwarf
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
