Old 27th Jul 2011, 18:42   #901
gilljoy
I *am* a Dremel
gilljoy's Avatar
gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!gilljoy - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by philheckler View Post
so how do you find the detail level on resin compared to metal? back in the late eighties when i used to paint - most of the miniatures were metal , resin was just coming in...
I've only got one finecast mini.
Seems really really detailed but I dont have the metal version of the same mini to compare. Still very very detailed
__________________
Intel Core i7 3770K ||H100i || Gigabyte Z77X-UD3h||16gb Corsair XMS3
Gigabyte 7970 Ghz edition ||1tb Samsung HDD + Crucial M4 64Gb|| Xigmatek Midgard
gilljoy is online now   Reply With Quote
Old 27th Jul 2011, 19:32   #902
ccxo
On top of a hill
ccxo has yet to learn the way of the Dremelccxo has yet to learn the way of the Dremelccxo has yet to learn the way of the Dremelccxo has yet to learn the way of the Dremelccxo has yet to learn the way of the Dremelccxo has yet to learn the way of the Dremel
First batch of resin (finecast what gw calls it) had issues, though they have cleared up, the detail is alot clearer and stands out well.
Plus side with resin the models stand up on their own as most metal ones always fell over, best to go into you're local gw and see what you think for you're self.
http://www.games-workshop.com/gws/ca...d=prod1250014a
Is the latest finecast minature, brand new so would see what you think of that one.
ccxo is offline   Reply With Quote
Old 27th Jul 2011, 20:04   #903
Cerberus90
petrolhead
Cerberus90's Avatar
Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!
Something I've been meaning to ask.
In my chaos codex, for the marines, their wargear is listed as :
Power Armour
Bolt Pistol
Frag Nades
Krak Nades
CC Wep
Bolter
Does this mean that they always have all of these, unless they've been replaced by other weapons as described in the upgrade bits?
So I've got marines that are modelled with pistol + CC wep, do these not have a bolter to use?
__________________
Steam: Cerberus90
| Q6600 @ 3.2GHz | Asus P5K Premium | 4GiB Patriot 1000MHz | 256GB Samsung 830 |
| Gigabyte GTX460 @ 830/2000 | Fractal Core 3000 | 24" BenQ G2420HD |
Cerberus90 is offline   Reply With Quote
Old 27th Jul 2011, 21:04   #904
gilljoy
I *am* a Dremel
gilljoy's Avatar
Power Armour
Bolt Pistol
Frag Nades
Krak Nades
CC Wep
Bolter
Thats there standard wargear loadout.
I think they'd have both if it was me
__________________
Old 28th Jul 2011, 00:33   #905
dave_salmon
Supermodder
dave_salmon's Avatar
dave_salmon has yet to learn the way of the Dremeldave_salmon has yet to learn the way of the Dremeldave_salmon has yet to learn the way of the Dremeldave_salmon has yet to learn the way of the Dremeldave_salmon has yet to learn the way of the Dremel
Thought you guys would like this:
http://www.dakkadakka.com/dakkaforum...st/384577.page
It's a friggin shame the guy doesn't have any intention of painting these any time soon.
__________________
Bessie 1.3 - CPU: E6750 @2.67ghz+Arctic freezer 7pro| Mobo: Asus P5kc | Ram: 4gig OCZ Reaper | GPU: ATI Saphire 4890 1gig | PSU: Antec tru power trio 650w | Case: Antec P180b | 2x Scythe GT 1450rpm & 2x Antec tri-cool
dave_salmon is offline   Reply With Quote
Old 28th Jul 2011, 00:39   #906
dave_salmon
Supermodder
Any of your guys got any experience with Vallejo Model Air paints?
I've been having a few issues with my airbrush and have decided to grab some Grey primer and White for basing which should arrive tomorrow.
__________________
Old 28th Jul 2011, 07:18   #907
gilljoy
I *am* a Dremel
gilljoy's Avatar
Mind if i get some airbrush advice off you?
Any low price ones you'd recommend?
__________________
Old 28th Jul 2011, 08:31   #908
liratheal
Sharing is caring
liratheal's Avatar
liratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpit
I don't own many, but the finecast models I do own are far superior to the metals in just about every way. In fact, the only niggle I have with them is that you can't really cram them into smaller troop slots in foam trays - They will bend.
Comparing Abaddon (Resin) to Abaddon (Metal) is like comparing a bucket of rust to a new car - It's worlds apart.
Not to mention that they're an absolute joy to put together, and so much easier than their metal counterparts.
I've started work on a Castellan for my Black templars. Still got a fair bit of GS work to do in terms of cloaks, tabbards etcetera. Shoulder pads too, actually. So far there's actually a lot of Dark Angel parts on there.
Incidentally, that's a standard troop head on a terminator sized body - And is it just me or does it look fine?
Still undecided about the sword.
__________________
Desktop: Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, 2x XFX 6870 1gb's, Corsair 1kw
Laptop: Alienware M15x, 5730 1gb, 8gb DDR3, i5 520M, Samsung 830 256gb, Seagate Momentus XT 500gb
WHS: Gigabyte Z77-D3h, i3 2100, 16gb DDR3, 5xWD 1tb, 5x Seagate 1tb
I game, Do you?
liratheal is offline   Reply With Quote
Old 28th Jul 2011, 08:43   #909
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!!
Can't really make out the sword too well, post up a few more shots perhaps? Otherwise looking quite good.
I need to sort out paints again as I think most of my old stuff has dried up or separated out too much to be of any use. That and the lids have welded shut
I want to paint Ghazghkull and Nightbringer. They're sitting on my table undercoated and ready to go...
__________________
ZiiP Gamestore
[ZiiP] Gaming Community - IW BlackMailers and loonies abound!
Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350.
[ZiiP] NaloaC is online now   Reply With Quote
Old 28th Jul 2011, 10:09   #910
dave_salmon
Supermodder
Firstly, over this side of the pond, the best option is Badger brushes.
Getting advice on an airbrush is worse than getting advice on a PC build. There are just so many differing opinions it becomes a nightmare to try and pin something down to make a decision.
I ended up just buying one because I'm sick of using GW spray cans to base and simply don't have enough time to base all 150 of the models I have to paint by hand.
I got pretty frustrated and bought an intermediate brush kit without compressor:
http://www.ebay.co.uk/itm/BADGER-200...item336948ba5d
I ended up picking up a compressor on a long term loan thing from a friend of the family for free after balking at the minimum £150 price tag for an entry level compressor.
The brush is nice, comfortable to hold and a piece of cake to clean. I do wish now that I'd gone with the first brush I was recommended simply because the one I got was a big investment (£85 for the kit) and if it turns out it's not for me or whatever it's a lot of money down the pan.
The original one I was recommended was this one:
http://www.amazon.co.uk/Badger-Airbr...1846367&sr=8-1
Supposed to be perfect for beginners deciding if airbrushing is the way to go for them and all the main airbrushing techniques are perfectly do-able with this brush (gradients, shading, etc)
Getting started you'll also need this:
http://www.amazon.co.uk/Badger-Airbr...sim_k_h_b_cs_1
and some of this:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
For a full intermediate level kit, you'll be looking at £200 for a single action, bottle fed airbrush, hose and socket, with a basic level compressor from a hobby shop (You could probably knock a decent chunk off by grabbing it all on eBay though). If the compressor doesn't come with moisture filters, you can add another £10/30 on to that for the 1/2 that are recommended (I only have the one).
Here's where I started with advice and such:
http://www.dakkadakka.com/dakkaforum...2.page#2899102
The gravy of airbrushes are the dual action, gravity fed models on compressors with two moisture filters
Brush:
http://www.ebay.co.uk/itm/BADGER-AIR...item3cba188956
Edit: I did spot a kit on eBay which had two brushes and a compressor with one moisture filter but it is a chinese made one that doesn't seem purpose made for minatures (although modelling is listed under the uses) and I couldn't tell you much at all about it:
http://www.ebay.co.uk/itm/AIRBRUSH-K...item5635b6fe82
__________________
Old 28th Jul 2011, 10:31   #911
gilljoy
I *am* a Dremel
gilljoy's Avatar
Snip!
Cheers man, I actually got a free Badger Model 200 airbrush off my uncle, shame is its missing the jar so need to get one
As for thinning paints what do you use?
__________________
Old 28th Jul 2011, 10:44   #912
dave_salmon
Supermodder
I was trying to use screen wash on recommendation from another site but this is an absolute no-no. Simply doesn't work. I started by using Vallejo thinner which worked really well but is a little expensive for what you get and how quickly you got through it.
Here are the most common ones:
Thinning solution made of 50/50 windex to distilled water and then mixed thinner to paint 60/40.
Vallejo paint thinner - How much you use differs from one colour/brand of paint to another
Isopropyl alcohol - Usually used along with distilled water and not recommended for beginners because it can actually destroy some brands of paint.
Plane water is also a no-no when thinning paint for an airbrush. Too thick apparently.
I've gotten fed up with trying out the voodoo thinning mixtures and bought some Vallejo Model Air which I'm told can be sprayed right from the bottle, just waiting for it to arrive:
The main reply I get when I ask about thinning is essentially: Look what other people do, try everything, see what works best for you. Which is really helpful /sarcasm.
__________________
Old 28th Jul 2011, 10:50   #913
liratheal
Sharing is caring
liratheal's Avatar
I'd suggest grav feed being a primary concern, given the small volumes of paint we mix/use in this hobby - The syphon bottles I've seen floating around aren't exactly designed for small quantities
That said, I'm no airbrush expert, so I could be talking out of my arse!
I'll get some more pictures of the Castellan when I get a chance, what with it being at home atm and me going out for a game with my Deathwatch army tonight.
Gonna be weird shooting things >.>
__________________
I game, Do you?
Old 28th Jul 2011, 12:14   #914
Almightyrastus
Bringing the awesome
Almightyrastus's Avatar
Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!Almightyrastus - it's over 9000!!!!!!!!1!1!1!!!
I have an airbrush kicking about somewhere (must dig it out and see if it still works) and as far as I can remember it is a dual action Airfix one which can do either gravity feed or suction as the front end rotates.
The suction feed is great for large area spraying such as base coating a tank as you can just load it up without worrying about having to remix and get the shades right again.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 29th Jul 2011, 08:26   #915
liratheal
Sharing is caring
liratheal's Avatar
Apologies for the shitty picture, but it was spinning on the thing at the store, and I couldn't find the off switch >.>
__________________
I game, Do you?
Old 29th Jul 2011, 08:29   #916
gilljoy
I *am* a Dremel
gilljoy's Avatar
I hate this hobby,
went into GW to get some metalics, ended up buying a librarian and a venerable dread..
__________________
Old 29th Jul 2011, 11:43   #917
Almightyrastus
I know what you mean, I popped in to my local one last night just because I was passing and thought I would have a quick nosey what was going on.
Came out with a Dreadknight......
__________________
Old 29th Jul 2011, 11:56   #918
liratheal
Sharing is caring
liratheal's Avatar
And now you both know how I end up with so much.. Everything.
__________________
I game, Do you?
Old 29th Jul 2011, 12:50   #919
ccxo
On top of a hill
You all need to learn to resist- the easiest way is to think of how much you have to do already- i think it helps when ive got boxes of un-opened models at home as well.
Airbrushes look good, have seen some nice work with them on models, just money to invest into them.
Still waiting on my 3rd yellow paint pot to arrive, will use as a extreme highlight once weyland games gets some stock in.
http://www.dakkadakka.com/dakkaforum...st/384939.page
Shows whats coming out next for relases and finecast, pics from latest gw mag that goes on sale saturday- next Fantasy army is Ogres is confirmed as back page of tomorrows WD.
Will put Ogres coming out in 2 months time, then see Necron's as a Christmas release, Ogres will be at Games day this year.
Old 29th Jul 2011, 13:31   #920
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.Krikkit is the Cheesecake. Relix smiles down upon them.
I bought the same kit from eBay several years ago when I had a revival of model making, and it's a good bit of kit in some ways.
Firstly the reservoir-less diaphragm compressor can make fine work very tricky, you get paint pulsing at low pressures. I bought a single airbrush which was cup-fed, and those are rather a large ballache, I'd say gravity-fed is a must have if you are painting miniatures like GW, even on full-scale models I'd be tempted to suggest getting gravity fed just for the ease of use and suitability for small amounts of paint.
If I were to go for an upgrade on the eBay kit I'd say the biggest thing is a reservoir for the pump and a set of different sized nozzles (fine especially).
All that said I'd highly recommend that kit for the money, the compressor is pretty hardy and 0 maintenance, the brushes are reasonable and double action for extra flexibility, and in the end the kit is cheap enough that if you don't use it often/hate airbrushing, you've not lost out that much.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Reply
Tags
40k, games workshop, no skimlinks, say no to skimlinks, white dwarf
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
