Reply
Thread Tools View Mode
Old 17th Jan 2011, 21:42   #1
Bl00m
Modder
Bl00m has yet to learn the way of the Dremel
Project: Silent Shadow
Hi all here at Bit-Tech!
Iīm new here and have a project that I would like to present to you!
Let me introduce Project Silent Shadow, This is my first Modding project.
The main thing with this project is that Iīm going to build a computer chassi from ground up.
The color theme that the build have is Black and Red, I will also try to keep it as clean as possible. I will also make this an all watercooled build.
The chassi is going to be made out of aluminum, what methods I will be using to get all the cheetmetal as I want, I will have to figure that out as I go.
The hardware That is going in to this build will come during everything but I know one thing and that is the PSU that the Swedish company Fractal Design is sponsoring with, itīs an Newton R2 800W, witch I will be sleeving.
Hope that this is making some Bit-Tech members interested in following my journey.
Keep in touch updates is coming soon
Excuse my English, itīs not all good but I hope you understand what Iīm writing.
Big thanks to:
Bl00m is offline   Reply With Quote
Old 22nd Jan 2011, 09:29   #2
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
Can't wait to see this started. Mod on mate!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 22nd Jan 2011, 10:22   #3
Hannes
Design | Art | Performance
Hannes's Avatar
Hannes has yet to learn the way of the DremelHannes has yet to learn the way of the DremelHannes has yet to learn the way of the Dremel
Hi bro! be sure to get those pictures I know you have uploaded in this thread! It's against the Bit-tech rules to start a worklog without a build, and the only way for us to know you have one is from pictures. :-D
Hannes is offline   Reply With Quote
Old 4th Feb 2011, 10:08   #4
Bl00m
Modder
It will come soon now! I forgott this one sorry but like aI said it will come maybe tonight
Old 4th Feb 2011, 10:25   #5
Bl00m
Modder
Okey so here the long expected update:
there will be more of them soon
Fractal Designs Newton R2 800W:
Some pictures when I was sleeving the 24 pin:
24 pin done:
And now some PCI-E kabels have to be sleeved:
In lack of real tools a couple of staples had to do the trick:
Now to some pictures of the finished cables.
And here we have the aluminum that will become the case
Stay tuned more is coming!
/Patrik
Old 4th Feb 2011, 15:34   #6
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Nice shots for a first timer, cant wait to see what you up to!! Mod on!
AnG3L is offline   Reply With Quote
Old 5th Feb 2011, 19:06   #7
that_du^de
give your head a wobble
that_du^de's Avatar
that_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpit
nice bit of sleeving that mate,what do you have in mind for the case shape,square,rectangle?also how thick is that alu? ill be pulling up a chair for this.....mod on bro!
__________________
mozart tx case(11x120mm fans),intel i7 920@4ghz(20x200)1.28v,asus rampage extreme 2,6gig corsair ram(3x2gig),2xati hd5870 crossfire,titan fenrir hsf,enermax revolution 1250w psu,1x120gig ssd 4x1tb hdd,x-fi elite pro soundcard,dell 2405fpw 24"lcd,zboard merc k/board,cyborg rat 7 mouse,win7 64bit
that_du^de is offline   Reply With Quote
Old 6th Feb 2011, 12:15   #8
Bl00m
Modder
Thanks
Thanks It will be like an ordinary case since this is my first build
I will be using 2 and 5 mm aluminium to form the case
And here is a drawing from Solidworks:
Old 6th Feb 2011, 13:40   #9
that_du^de
that_du^de's Avatar
looking good
__________________
Old 9th Feb 2011, 07:20   #10
Bl00m
Modder
Okey time for an update.
Here we have The beautiful things that Aquatuning.se Sponsored me with:
Sorry but the pictures are quite bad, I think I got some Dubai dessert sand in the camera from my vacation.
Here are some things that I ordered from coolingstuff.se
Old 9th Feb 2011, 08:10   #11
Bl00m
Modder
OH what is this?
Another update so soon?
Yes Here are some more sleeve for the tubing and the color-x delivered from MDPC-X,
And oh another package! From QuietPC! The nice people at QuietPC are the newest of sponsors and contributes with some Himuro HDD coolers and PCI brackets.
//Bl00m
Old 12th Feb 2011, 01:43   #12
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Subscribed should be good Bl00m .
Waynio is offline   Reply With Quote
Old 12th Feb 2011, 02:44   #13
Shael
Multimodder
Shael's Avatar
Shael has yet to learn the way of the Dremel
Ahh another scratch build to watch I like the case design - Subscribed
Shael is offline   Reply With Quote
Old 15th Feb 2011, 12:42   #14
Bl00m
Modder
New Update and New Sponsor, Bitspower
Yeah okey so now itīs time for another update, unfortunately without pictures.
But here it is Bitspower a great manufacturer of watercooling products goes in and sponsors with some fittings for the watercooling.
Here is the products:
Model name: BP-MBCPF-CC6
URL: http://www.aquacoolingtechnology.com...58874&kind2=52
Amount: 16
Model name: BP-MB45R2CPF-CC6
URL: http://www.aquacoolingtechnology.com...58838&kind2=52
Amount: 6
Model name: BP-MB90R2LCPF-CC6
URL: http://www.aquacoolingtechnology.com...58853&kind2=52
Amount: 4
Model name: BP-MBWP-C06
URL: http://www.aquacoolingtechnology.com...58924&kind2=52
Amount: 12
Model name: BP-MBWP-C04
URL: http://www.aquacoolingtechnology.com...58922&kind2=52
Amount: 2
Model name: BP-MBWP-C03
URL: http://www.aquacoolingtechnology.com...58921&kind2=52
Amount: 2
Model name: BP-LGS1-UVRD
URL: http://www.aquacoolingtechnology.com...57089&kind2=40
Amount: 1
Model name: BP-WTP-O10-DRD
URL: http://www.aquacoolingtechnology.com...57186&kind2=14
Amount: 4
hopefully this is all I need
Big thanks to Bitspower!
Old 14th Mar 2011, 09:25   #15
Bl00m
Modder
Long awaited update!:D
So it was some time since the last update in this project so itīs about time!
So what has happened since the last update?
Yeah some waterblocks from EKwaterblocks, The Bitspower fittings and even another XFX 5870 has arrived to my door.
But the biggest thing this time is that the first cuts has been done in the aluminum.
Enough Talking, time for some pictures hope they looks better then before.
We start of with the shipment from EK, the onlything that is missing is the waterblock and backplate for graficscard number 2 that arrived after the pictures was taken, so it might appear later on.
Got some fashion advise from EK:P
5870 V2 backplate:
That was the EK shipment.
Next up is Bitspower
Old 14th Mar 2011, 09:27   #16
Bl00m
Modder
The update continues!
Here we have the graphics card and The fittings that wonderful Bitspower Sponsored with
Here we have both of the graphics cards
BITSPOWER!!!!
Next up is some CNC action
//Bl00m
Old 14th Mar 2011, 09:29   #17
Bl00m
Modder
Update continues! CNC:D
Okey so now we have arrived to probably the most interesting part of this big update!
This will end this big update, but it will come some more soon
//Bl00m
Old 14th Mar 2011, 09:50   #18
chomps1891
What's a Dremel?
chomps1891 has yet to learn the way of the Dremel
nice work dude
chomps1891 is offline   Reply With Quote
Old 14th Mar 2011, 18:24   #19
KidMod-Southpaw
Haven't looked at this for ages but BLOODY HELL you've made some progress mate! Great job on the sleeving and those are some yummy orders!
Fantastic. Sums up the log.
__________________
Old 14th Mar 2011, 18:37   #20
djzic
Bokehlicious!
djzic's Avatar
djzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremel
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650.
Thermalright AXP-140. Samsung SpinPoint 1TB.
1U 300w PSU. Shuttle Case. MDPC-X Sleeving.
djzic is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
