#21 |
what was dat sandvich ?
nice cnc you've got there ! can't wait to see how this turns out!
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link |||||||||
#22 |
Supermodder
m8, just run distilled water + kill coils (or PT Nuke). You don't want something like this happening: http://www.xtremesystems.org/forums/...d.php?t=226632
I know it's different product, but after seeing that I no longer run any other stuff on my loop except for PT Nuke + distilled water. If I want color, I just run colored tubing. PrimoFlex LRT has the main colors you'll ever need (red,black,blue,green,etc). As for being "non conductive" that's not exactly true. The fluid will turn conductive after about two or three weeks of continuous use. Anyways, good work so far. |
#23 |
Modder
Thanks for all the awesome words!
I will try to not disappoint you guys! Okey so you dont recommend me using PC-ICE? because of the Color in the liquid? but doesnīt that happen to every color that you ad to the water that it faints away and clogs up the blocks? The thing is that I would really want the color in the water to give it a nice effect in the reservoir. I got recommended this coolant from other people in other forums:/ I have no experience with watercooling from before so all the feedback is great. I have another thing to ask, Iīm in a bit of an dilemma, I donīt know if I the tubing would look nice clear with the color of the water or if I should sleeve it instead ![]() I know what the use of color if i would sleeve the tubing but I what the color to show at least in the ress! ![]() Again thanks ![]() /Patrik |
#24 | ||
Supermodder
If you want to use colored dye, that is fine, however do keep an eye out for possible problems after a few weeks. Like I said, I personally stick to colored tubing over dye. Quote:
#25 |
Modder
Yep like in sleeving cables
![]() I will try and do a setup like that and see how it looks ![]() I will try to keep an eye out for problems like high temps and such, and if I see any changes or something like that I will have to take everything apart and have a look. probably I will have it to take some nice pictures and maybe later if any problems shows I will change to something else ![]() O I cant remember but I googled it and found some already existing threads and just asked in them.:/ Love this advices like I said its the first time for me with watercooling. |
#26 | |
Supermodder
If you are new to WCing, I recommend you read these, if you haven't already: http://www.overclockerstech.com/wate...for-beginners/ (Mainly, pay attention to the assembly as this is where most newcomers mess up) http://forums.extremeoverclocking.co...d.php?t=312743 Reviews: http://skinneelabs.com/ |
#27 |
Modder
Oh what is this, a new update? well yes it is!
Hi All!
After a long brake, it's time for a couple of new updates ![]() Thanks to a graficcard crash I was forced to buy a new pair of cards: ![]() ![]() ![]() Everything looked alright, but at a closer inspection I saw that it wasn't the cards I ordered so I had to return them to the store. But I quickly found a new pair, but this time from another store: ![]() What cards could this be then? ![]() ![]() Oh a pair of HIS 6970 ![]() ![]() Keep tuned for more!
#28 |
Modder
Oh what is this another big update? :D
And what? might it be some new plates to the chassi?
no false alarm! it was just some part for the watercooling. a couple of block for the gpus, backplates and a bridge. some more tubing, a tubecutter and a fancontroller. ![]() ![]() ![]() ![]() ![]() ![]() Tomorrow you will get some pictures from the workshop
#29 |
The German
This looks very interesting
Will be keeping an eye on this
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#30 |
Modder
Thanks in a couple of hours there will be more pictures up
#31 |
Modder
Okey so here we go again!
After spending some time with drilling and tapping holes for screws, and at the same time letting the CNC do its work I finally got some more parts ready
![]() Not a gigantic update but hope you like it! ![]() ![]() ![]() ![]() ![]() Next up I will try to put some of the parts together
#33 |
Modder
as you might see, if you look closer, there is two separate backplates
wonder why!
#34 |
Minimodder
This is getting interesting!
Keep up the good work! |
#35 |
Minimodder
Looks like a clean smart build in making. Tagging along for the ride as well.
#36 |
Modder
I agree with djzic
#37 |
Modder
Hell yeah!
Here it is! Some pictures of a partially assembled Silent Shadow
![]() There is still lots of parts missing. Enjoy! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() (I know the pictures are not 100% but due to bad lighting it had do do the trick) |
#38 |
Steals Avatars
I had a 5870 once to go trifire with my be 5970 but was DOA, so used my be 5850.
subscribed, and looks forward to seeing more.
#39 |
Modder
Update, With panic in the text!
So now its only Two days until dreamhack 2011 winter beggins and Iīm starting to feel panic crawling in.
It was some time now since the last update due to some other stuff. But here we got some pictures from this weekend when I got lots of time with the CNC, Enjoy: Thanks to how much I had to get done, resolved in that I didnīt have to much time to take pictures. But hey some is better then nothing right? |
#40 |
Modder
Continuing: Update, With panic in the text!
Here is some pictures on the frontpanel and the sides of the chassi
![]() The next update will probably come during Dreamhack but until then, Enjoy! ![]() |
| Thread Tools | |
| View Mode | |
