Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Jan 2011, 12:43   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
DFG-FET Tech Promises to Replace RAM, Flash
Scientists unveil a building block for 'universal memory' - DFG-FETs.
http://www.bit-tech.net/news/hardwar...-memory-tech/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 25th Jan 2011, 13:07   #2
adam_bagpuss
Have you tried turning it off/on ?
adam_bagpuss's Avatar
adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.adam_bagpuss is the Cheesecake. Relix smiles down upon them.
damm you gareth beat me to it plus i linked to a rubbish bbc article
adam_bagpuss is offline   Reply With Quote
Old 25th Jan 2011, 15:09   #3
Mraedis
Multimodder
Mraedis has yet to learn the way of the Dremel
Yay, working sleep modes!
__________________
Mraedis is offline   Reply With Quote
Old 25th Jan 2011, 15:13   #4
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
wow! That is wonderful ultrafast ramdisk with power off storage.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 25th Jan 2011, 16:38   #5
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
i'd much rather just get a ram drive with a reliable battery that recharges as long as theres power running through the computer. ram doesn't need a lot of charge to keep it's contents intact, but its a hell of a lot faster.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 26th Jan 2011, 03:43   #6
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
This would be just as fast as ram, but maintain a static state when power is lost.
Could be a pain in the ass for a few things though. Like if windows locks up hard, or there's some malicious code in there? Imagine that, getting a virus from installing new ram.
Tulatin is offline   Reply With Quote
Old 26th Jan 2011, 05:36   #7
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
You would probably want to continue to keep memory and storage separate so you can dump the memory if need be.
Why is volatile inherently faster than non-volatile?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 26th Jan 2011, 11:14   #8
greigaitken
Supermodder
greigaitken has yet to learn the way of the Dremel
progress is all well and good but how long till you can buy 200gb of it for 200
greigaitken is offline   Reply With Quote
Old 26th Jan 2011, 13:02   #9
GW42
Minimodder
GW42 has yet to learn the way of the Dremel
I'll go out on a limb here: it's probably best not to delay that new sandybridge build hoping this will be available by March...
GW42 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
