#101 |
still wants Homeworld 3
and an overclocked gtx560 might be even better value.
it's gray area when you go into user modifications.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr |
#102 | ||
You Rebel scum
And as Glenster said: Quote:
__________________
Enter the 2011 Reader Survey to win £730 of hardware. Win more things with CPC and bit-tech |
#103 | |
What's a Dremel?
and I'm sure 1 of them will do a single slot but what's the point? |
#104 |
Banned
I'm amazed to see this card only shipping with 1GB RAM. I'm seeing video memory usage reach 925MB with Neverwinter Nights 2 (a 2007 release, but with all options maxed, transparency AA enabled and higher quality texture mods loaded) so it seems obvious to me that 2GB should be the minimum for mid/high-range GPUs.
Gainward/Palit were able to release a 460GTX with 2GB, so maybe they'll be able to do this for the 560? |
#105 | |
Multimodder
http://www.scan.co.uk/products/2gb-p...x-dvi-hdmi-vga |
#106 |
Banned
Thanks for the link, and quite a surprise to see that 1GB extra has less than a £20 premium - wonder why more manufacturers aren't doing this? The one downside seems to be the rear socketry - having the old D-Sub connector as well as 2 DVIs seems likely to make it harder to (air)cool due to the reduced exhaust grill.
#107 |
Minimodder
I would love to know this too....
Anyone know if they've got plans to do so, or any of the other VGA OEMS? I've got a HTPC/PVR build where PCI/PCIe slots are all precious. So I don't want my discrete GPU, taking precious PCI/PCIe slots. Thanks to anyone that can point to an OEM with plans or whom offers a single slot 560 Ti. |
#108 | |
Minimodder
| Thread Tools | |
