Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Jan 2011, 15:56   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Does Flash Really Sap Your iPhone Battery?
Famously, you can do almost anything on an iPhone apart from run Adobe Flash; a move that Apple has always defended on the grounds that Flash isn’t finger-friendly and that it drains the battery life too much.
According to IT Pro, this firmly held line has led to ‘one of the most bitter and unresolved disputes in the technology industry.’ What's more, the site has also undertaken some testing to discover the truth about the iPhone Flash video and battery life debate...
http://www.bit-tech.net/blog/2011/01...phone-battery/
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 25th Jan 2011, 16:00   #2
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I think users should still have the choice.
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 25th Jan 2011, 16:05   #3
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
VLC on iPhone isn't the best implementation. when using it, it makes my iphone feel warm. whereas watching encoded-for-iOS videos is perfectly fine.
what i suspect is happening is that VLC is using inefficient CPU to decode while we all know GPU decode is far more efficient in terms of speed and power consumption.
only real conclusion i think we can draw from this is that on from results on Galaxy Tab:
FLV 6h30m
H264 6h58m
H264 is easier on battery life, by a tiny little bit.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 25th Jan 2011, 16:06   #4
sear
Multimodder
sear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for presidentsear should be considered for president
What Apple is doing is more or less like Microsoft from prohibiting OpenOffice.org/LibreOffice from running on Windows because they claim its minor incompatibilities might "damage the user experience"... it's an obvious and utterly absurd excuse to try to justify what is clearly an anti-competitive practice. My guess is Apple were upset that Adobe wouldn't give them further concessions (and possibly even refused a takeover) and so are trying their best to simply beat them down using underhanded and petty tactics.
sear is offline   Reply With Quote
Old 25th Jan 2011, 16:07   #5
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
Flash is about more than just videos though.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 25th Jan 2011, 16:09   #6
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
I think this is a badly executed article. As they have shown, there isn't much difference between flv and h.264 in when played in the same player. They have completely missed the point that the problem with flash video is the player rather than the compression format. Watching flash video in an embedded player in a webpage makes my MacBook Pro get hot, playing the same file in FLV is much faster, smoother and less power hungry.
Bad journalism.
__________________
Jamie is offline   Reply With Quote
Old 25th Jan 2011, 16:37   #7
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
@sear Remember Hanlon's razor
"Never attribute to malice that which is adequately explained by stupidity."
Or in this case, Apple are determined to sell to part of the market who can't be bothered to learn how do use a computer. Instead Apple sell them a dumbed down/easy to use phone.
You could even argue that it's a pro-competition move because their competitors can just point at their devices and say "unlike the iphone, it runs Flash".
I don't care, I've still got months of a bottom of the range nokia before I can upgrade, and when I do, it won't be an iphone even if I could afford it.
phuzz is offline   Reply With Quote
Old 25th Jan 2011, 16:40   #8
Unknownsock
Supermodder
Unknownsock has yet to learn the way of the Dremel
I always thought this was more over the fact that Adobe changed their primary OS design to windows rather than Mac? Although the battery life thing always seemed like it was hiding the real story.
Unknownsock is offline   Reply With Quote
Old 25th Jan 2011, 17:16   #9
memeroot
aged and experianced
memeroot has yet to learn the way of the Dremelmemeroot has yet to learn the way of the Dremelmemeroot has yet to learn the way of the Dremel
its about choice
memeroot is offline   Reply With Quote
Old 25th Jan 2011, 17:44   #10
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
Originally Posted by sear
What Apple is doing is more or less like Microsoft from prohibiting OpenOffice.org/LibreOffice from running on Windows because they claim its minor incompatibilities might "damage the user experience"... .
openoffice runs on windows without any problems...
it does on my windows 7 computer at least
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 25th Jan 2011, 18:02   #11
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
Considering FLASH player crashes on a daily basis on each of my browsers (CHROME & Firefox), I hope apple keep Flash away from their products.
feathers is offline   Reply With Quote
Old 25th Jan 2011, 18:10   #12
BlackRaven
Freaking printers!
BlackRaven's Avatar
BlackRaven has yet to learn the way of the Dremel
If it is a 30 minute difference then it is not really that much. You would not be watching 6 hours of video on the thing anyway.
BlackRaven is offline   Reply With Quote
Old 25th Jan 2011, 18:48   #13
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
I've been flashing for years and never once felt like a sap.... Being a professional flasher isn't easy, I was thinking of retiring but thought I'd stick it out a while longer.
PingCrosby is offline   Reply With Quote
Old 25th Jan 2011, 18:57   #14
FelixTech
Robot
FelixTech's Avatar
FelixTech has yet to learn the way of the DremelFelixTech has yet to learn the way of the Dremel
You must be going to the wrong websites...
I don't have an iPhone so I don't have a clue, but does the VLC app not play H.264 as well as flv? Surely that is the only fair comparison to be made. All we learn here is that first-party programs are more efficient (shock horror!).
__________________
Use ClickMechanic for car repairs and servicing!
Play Animal Shogi for free on Android!
FelixTech is offline   Reply With Quote
Old 25th Jan 2011, 19:14   #15
Eiffie
Supermodder
Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.Eiffie is a hoopy frood who really knows where their towel is.
Same here, I got a win7 64-bit PC and the current version of open office and i've never had any problems getting it to run. It's quite smooth actually!
__________________
I5-750 @ 4GHz - MSI P55-GD65 - 8GB Crucial DDR3 1600 - EVGA GTX 680 2GB - 1 Western Digital Black 1TB - 2 Western Digital Green 2TB - 700W Silverstone PSU - H50 Water Cooling Unit - Win7 64-Bit - Logitech G400 - Cooler Master QuickFire Pro MX Brown - Steelseries Icemat V2 - Blue Microphone Snowball - Logitech C920 Webcam
Eiffie is offline   Reply With Quote
Old 25th Jan 2011, 19:23   #16
Flibblebot
Smile with me
Flibblebot's Avatar
Flibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming Saiyan
You're misunderstanding sear's point - what he's saying is that Apple banning Flash is similar to if Microsoft were to ban OpenOffice from running on Windows - not that they have banned it.
It's curious that Apple have gone from bemoaning Microsoft's anti-competitive practices to doing the same thing that they accused MS of doing...it's amazing what being a market leader does to your business practices
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 25th Jan 2011, 23:11   #17
OleJ
Me!
OleJ's Avatar
OleJ has yet to learn the way of the DremelOleJ has yet to learn the way of the Dremel
Or rather: It's curious what being a market leader does to public perception of said practices.
You can fully decode H264 via HW without overhead which (kind of) equals better battery life and performance. I gather that if Adobe had been out a lot earlier with built-in support for 90% of the HW-decode chips out there it would have been an entirely different game.
Adobe have been incredibly late in the game wrt GPU video acceleration. As far as flash being able to take advantage of decoding HW / HW acceleration...? Has anyone even heard of this?
__________________
Quickr! Clickr to my Flickr!
Canon camera stuff. Some aluminium PC, a Mac Mini and a last-gen MBP 17"..
OleJ is offline   Reply With Quote
Old 25th Jan 2011, 23:44   #18
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
It's about choice, but also about attribution. If something crashes or glitches on our system we won't rest until we identify the culprit, analyse the fault and resolve it. If it happens to a muggle they blame the obvious, usual suspect: it is either a virus or Windows (or the iPhone).
It is never that dodgy piece of pr0n they downloaded, or that wonky program they installed by curious coincidence just before the fault occured, or (like happened with someone I know) the fact that you cannot continue using the Internet when you've just unplugged your WiFi router to free up a socket for an iron. So rather than getting undeserved bad press, those who cater to muggles try and make their stuff idiot-proof.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 25th Jan 2011, 23:48   #19
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpit
I gathered that Apple has abandoned Flash because it was old (or at least ageing) tech. It would make sense for Adobe to up their game a bit so that their software is more efficient and user friendly.
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Old 26th Jan 2011, 00:50   #20
Tokukachi
Multimodder
Tokukachi's Avatar
Tokukachi has yet to learn the way of the Dremel
Huh? I don't know how people can be so stupid as to fall for Apples BS PR. There is one reason and one reason alone why flash is not on the iPhone; the app store.
Having flash support would kill off apples #1 source of revenue, most of the apps on the App store are just iPhone versions of free flash apps / games that have been around for years.
Tokukachi is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
