Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Jan 2011, 18:19   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Intel HD Graphics 3000 Performance Review
How fast is the Sandy Bridge graphics system in some of the most popular games?
http://www.bit-tech.net/hardware/gra...mance-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 27th Jan 2011, 18:26   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
Z68 is pretty much a well known upcoming product, or an educated guess?
none of the leaked slides mention it
what i'd be interested to see is nVidia Optimus technology on Z68, imagine overclocked to 4.6GHz CPU, but the system only draw 50w during idle.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 27th Jan 2011, 18:31   #3
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Can it play Crysis?
Mankz is offline   Reply With Quote
Old 27th Jan 2011, 18:31   #4
Fordy
Multimodder
Fordy has yet to learn the way of the DremelFordy has yet to learn the way of the DremelFordy has yet to learn the way of the Dremel
I completely understand not using your normal suite of test games for a GMA test, however:
I am currently in an upgrade dilemna, strapped for cash, desperately needing more frames - but a new mobo/CPU too.
It would be fantastically helpful to my "which first" choice, if you also included benchmarks against lower end cards and on, say, BC2.
__________________
Fordy
HTPC Project Log
Fordy is offline   Reply With Quote
Old 27th Jan 2011, 18:40   #5
Salty Wagyu
moo
Salty Wagyu's Avatar
Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!
Did you test to see if movie playback was correctly played at 23.976fps instead of 24.000fps? If it doesn't then it causes a frame pause every 40seconds which looks like a stutter
__________________
Main System & HTPC Specs
Salty Wagyu is offline   Reply With Quote
Old 27th Jan 2011, 18:41   #6
Timmy_the_tortoise
International Man of Awesome
Timmy_the_tortoise has yet to learn the way of the Dremel
Given the OpenCL support.. could a game theoretically use this just for Havok Physics whilst a dedicated GPU handled all the rendering and the CPU handled the rest?
That'd be interesting to see.
__________________
i5 4670|8GB Crucial Ballistix Sport|Zotac 2GB GTX 660|Samsung Spinpoint F1 1TBCorsair TX650W|Antec NSK2480
Timmy_the_tortoise is offline   Reply With Quote
Old 27th Jan 2011, 18:49   #7
mucgoo
I *am* a Dremel
mucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for presidentmucgoo should be considered for president
LOL at minecraft being used in a benchmarking
mucgoo is offline   Reply With Quote
Old 27th Jan 2011, 19:00   #8
barrkel
Multimodder
barrkel has yet to learn the way of the Dremel
There's a non-linear return to marginal FPS; at low FPS, every extra FPS is noticeable, but it's worth less and less the higher up you go. An FPS per GBP calculation that doesn't take this into account is problematic.
Mind you, figuring out the marginal return curve isn't that easy.
barrkel is offline   Reply With Quote
Old 27th Jan 2011, 19:31   #9
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
I think Hexus use a system in their calculations where marginal FPS below 30 is awarded double points, and marginal FPS about 60 is awarded half points.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 27th Jan 2011, 19:32   #10
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming Saiyan
On page 8, under the image, you refer to Z68. Yet in the following paragraph you call it Z67...
Typo?
__________________
Gaming: [Silverstone TJ08-E][Asus Z170M-PLUS ][i5-6600K][Tundra TD03][16GB 2666MHz][Asus 7970 DCUII TOP][Samsung 850 Evo 500GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus Z97M-Plus][i7-4770K][Corsair H55][16GB 1600MHz][iGPU][Samsung M.2 NVMe 256GB][Seasonic X-650 Gold]
Kids: [Silverstone SG05B][Asus H87I-Plus][i3-4330][8GB 1600MHz][Asus 6850 DirectCU][Crucial M4 256GB][ST45SF 450w][Dell E207WFP]
NAS 1:[Synology DS211j] NAS 2:[Homebrew OMV]
Fingers66 is offline   Reply With Quote
Old 27th Jan 2011, 20:02   #11
John_T
Supermodder
John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.
Nice review, although I am somewhat baffled as to how and why you tested as you did. I hate to be one of those picky people who incessantly moans over the smallest thing, but:
Left 4 Dead 2
- Tested at 1280x800.
- Cost of performance measured at 1280x800.
Starcraft II
- Tested at 1280x720.
- Cost of performance measured at 1680x1050.
Minecraft
- Tested at 1920x1080.
- Cost of performance measured at 1920x1080.
Three games, (six tests) compared on four different resolutions?
Why? What on earth was the benefit of doing it like that? Couldn't you just have picked one resolution and stuck with it for easy, consistent comparison across all tests? I just can't for the life of me understand the logic of it.
Anyway, it certainly looks powerful for integrated graphics. Looking forward to seeing these Z67/8 boards...
John_T is offline   Reply With Quote
Old 27th Jan 2011, 20:05   #12
frontline
Punish Your Machine
frontline has yet to learn the way of the Dremelfrontline has yet to learn the way of the Dremel
Interesting article, although i'm still not convinced by Intel's driver support in the long term. AMD and Nvidia will have competing products out soon, so it will be good to compare the options available in a few months time.
Another option would be to spend the £77 price difference between the Sandy Bridge system and the Phenom II system on something like a dedicated 5750 GPU and get far superior graphics performance.
__________________
Intel Core i7 2600K| Asus P8P67-M PRO R3 | Corsair H70 Hydro Series CPU Cooler |Corsair 8GB (2x4GB) DDR3 1600MHz XMS3 Memory Kit CL9 1.65V | Sapphire HD 6990 4GB GDDR5 | Crucial M225 128Gb SSD | Asus Xonar DX | LG W2261VP | Corsair GS800 PSU
frontline is offline   Reply With Quote
Old 27th Jan 2011, 20:07   #13
bogie170
Supermodder
bogie170 has yet to learn the way of the Dremel
How would Nvidia ION2 benchmarks compare against these chips?
bogie170 is offline   Reply With Quote
Old 27th Jan 2011, 20:08   #14
Scootiep
Multimodder
Scootiep has yet to learn the way of the DremelScootiep has yet to learn the way of the Dremel
Just to flaunt my ignorance, I simply can not get over this obsession with Minecraft. I'm not arguing that it's a game worth frittering away some hours on because the game play itself has merit. But for analyzing graphics performance of hardware? COME ON! It's like going back to my old NES copy of Dragon Warrior and saying to myself "You know what would really be great? If every texture in this game was more blocky!" Who in their right mind thinks that it's actually worth it to review the graphics performance of hardware based upon this game. It's simply ridiculous. Just because it gives you a simulated three dimensional world to run around in doesn't excuse it's complete lack of any decent texturing. Again, I'm NOT SAYING Minecraft is a bad game! I'm simply saying that it's a terrible game GRAPHICALLY.
__________________
"Out of order?!? F&$% Even in the future nothing works!" - Dark Helmet
Scootiep is offline   Reply With Quote
Old 27th Jan 2011, 20:16   #15
Timmy_the_tortoise
I've never played it, but as far as I know you can build some pretty huge stuff with it. I'd imagine that could push a graphics chip pretty hard.
__________________
Old 27th Jan 2011, 20:16   #16
Kingsley813
Minimodder
Kingsley813 has yet to learn the way of the Dremel
Yeah, agreed. Oh, and while they're at it, dig out a copy of Wolfenstein 3D and test the GFX on that too.
Kingsley813 is offline   Reply With Quote
Old 27th Jan 2011, 21:10   #17
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
A good thing about Minecraft is that it uses OpenGL and as you can see in the benchmarks it shows that Intel still has poor support for it in their drivers compared to Direct3D.
Narishma is offline   Reply With Quote
Old 27th Jan 2011, 21:33   #18
SimonStern
Registered Lurker
SimonStern's Avatar
SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!SimonStern - it's over 9000!!!!!!!!1!1!1!!!
I'd like to know when those Z boards are coming out myself. I see the "second quarter of this year" part but I wonder when that might be. I haven't pulled the trigger on sandybridge yet and when I do (soon I hope) I'll be wondering should I wait for those or just go with a P67 and lose the use of the graphics.
I still think it's pretty stupid they did it like that.
SimonStern is offline   Reply With Quote
Old 27th Jan 2011, 21:39   #19
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
24Hz support?
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 27th Jan 2011, 22:36   #20
jimmyjj
Hypermodder
jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.
How about subjective image quality tests. Previous Intel chips have not performed well here?
__________________
Asus P8P67, 2500k (stock), 8GB vengeance, GTX770 (EVGA AC SC), U2412M, Intel 330 180GB SSD
jimmyjj is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
