News Dragon Age 2 DRM explained
Discussion in 'Article Discussion' started by CardJoe, 1 Feb 2011.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Sounds fair enough.... Bit of a pain having to verify each install, but for me that's only once or twice for a game (determined by the number of times I rebuild the OS usually)
  3. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    So you can play offline, provided you log in online once in a while?
  4. Jewels
    Jewels What's a Dremel?
    26 Apr 2009
    All versions (retail or digital), apart from Steam's, use this form of DRM, and it's apparently more lenient than Steamworks.
  5. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    Don't see the problem with this, although I'm sure we'll get a few goons in here whining regardless.
  6. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I've seen worse. My main worry with all the DRM games come with these days is what happens if I want to play that game in 10 years time.
  7. mpr
    mpr What's a Dremel?
    26 Jul 2010
    Don't forget after a single authentication via Steam, you can switch to offline mode permanantly (or until you buy anew game or need a patch etc...)
  8. REMF
    REMF What's a Dremel?
    31 Mar 2009
  9. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    EA appear to be using their brain...unlike a certain Ubisoft.
  10. memeroot
    memeroot aged and experianced
    31 Oct 2009
    the original da was pirated to pieces though
  11. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I've heard Steam's offline mode actually requires you to log in every once in a while as well. Not sure how often either of these systems needs a connection, but I think they're both much of a muchness. Doesn't really affect me nor most other people on here - just about all of us have always-on connections - but I don't see myself boycotting this like I did with Ubi games. Not that I'm planning on buying DA2, mind..
    One other thing, I think there's something in there about EA having some backup plan for if they go under or the servers are taken down or hell freezes over. Props to them.
  12. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    Even if you get the Steam version I expect the EA log in will be required as soon as you add DLC to the game, as per DA at present.
  13. the-beast
    the-beast What's a Dremel?
    10 Aug 2010
    Bugger, thanks a lot EA. Since my gaming PC is not connected to the internet (No point as I don't play multiplayer and my connection is crap anyway) this is going to be a major headache.
    What was wrong with just a disc check that DA1 used?
  14. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I don't have a problem with it. Sounds pretty reasonable actually. I already have an EA account that I use, so it won't really be any different than what I do already.
    I wouldn't worry about it. I'm sure there will be a crack out the same day it releases (certainly within a week). Just buy it, then search for a crack, and bosh, sorted!
  15. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    Sounds reasonable, tbh - although I do hate having to sign up for yet another account :/. Still, a much better proposition than some others I've heard.
  16. the-beast
    10 Aug 2010
    Sounds like the easiest solution to me, still don't like EA's insinuation that were all criminals first and customers second.
    After the 5 install limit was revealed on launch day for Dead Space 2 I kind of feared that EA had lost the plot with DRM again :(
  17. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    It's not draconian DRM but Witcher 2 is still a lot better bargain than this. CD projekt knows how to value their customers...
  18. Tokukachi
    Tokukachi Minimodder
    20 Jun 2007
    Both times i've tried using this (when I've moved / known i'm going to be without a net connection) its worked fine for 1 or 2 days then demands i go online, so from my experience it's next to useless.
  19. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    This actually sounds pretty good, not too intrusive. Of course it'll be cracked by pirates before the game is even launched, rendering all the time and money they spent on the system completely pointless, but that's true of any DRM.
    edit: regarding steam offline mode, I used it for months at a time while at uni, to play half life and portal without being able to connect steam.
  20. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    the fact there isnt really any particular intrusive DRM does sound quite good.
    mite concider switching to the Steam version although I've currently got the signature version pre-ordered and I dont think I can get that on steam
Tags: Add Tags
