#1 |
Lion Country
Project: Mecha
I have started a new project and am calling it Mecha.
The idea is to have a new box for my new hardware that I will buy in about 6 months. I want to put the best hardware I can afford in when the case is ready. So some things like cable routing will be done last. I designed a frame for everything to be fitted on ![]() Nice and sturdy The case itself will look like this Box OFF ![]() Box ON ![]() At first I thought I should have a DVD drive in there but I don't use a drive that much and I will just get a portable USB DVD writer at some stage So this is what the idea is I have for the case ![]() Last week I started with the aluminium bars for the frame. They are 12.7mm square bar. I cut all the pieces for the frame ![]() And while cutting off a small piece from the aluminium, that small piece fell on the floor and I stepped on it by accident. The aluminium burnt through my little toe's skin and even got to a bit of muscle. I was saying very many inappropriate words at that time. (And yes, I have BIG feet )![]() Lesson: Don't work in the workshop when not wearing any shoes Last edited by Samaya; 10th Apr 2012 at 11:04. |
#2 |
Lion Country
Today I got the frame back from the welders and it came out very well.
Sorry for the bad quality (I only had my cellphone with me) ![]() A close up of the welds ![]() Now I will need to get rid of those bulges and then order aluminium sheets for the outside and some inside things. I am going to start on the electronics first though. I am building a custom controller for the fans, servo's and display. Enjoy and cheers, S |
#3 |
Lion Country
#4 | |
Lion Country
#5 |
Lion Country
#6 | |
Lion Country
ATMEL RULES!!!!Thanks for your offer - I appreciate it. I use Atmel for my own projects as well. Haven't done much with the Raven or on Servo control but I have made a bunch of other projects for work and such. I like the Mega328 and have started learning AVR32 UC3. |
#7 |
Lion Country
Today is a sad day
. I am going to disasemble my first ever scratch build and recycle some of the parts to go into my new build.On the right is Behemoth (Blue with brushed aluminium) ![]() I will be using some the aluminium and definitly those VERY expensive Bulgin buttons. This case held together for nearly 6 years. It was not the prettiest box on the plot but it was definitly the BIGGEST and easiest to access... Dual supplies - one for the hardware and one for the fans and lighting. A first rate P4 2.8GHz and a 5700 ultra was in there at the time. Good time, good times.
#8 |
Lion Country
Update!!!
I finished wrecking Behemoth and started work on the frame. Took me about 15 minutes to do this. I could save a bunch of stuff and very little infact got trashed ![]() Trashed stuff ![]() Anyway. I started filing down the bulges on the frame and it came out pretty decent. LUCKILY it seems the welds were done properly. I am not going to remove the bulges on the inside of the frame though - just in case I am wrong. ![]() Now I am going to measure out the panels and see How I am going to run the cables and so on. |
#9 |
Lion Country
I am going to start on the electronics. While I wait for my aluminium sheeting order to arrive.
BTW does anyone know what primer I should use on aluminium so I can paint the case? Last edited by Samaya; 9th Feb 2011 at 07:14. Reason: double picture post - oops :) |
#10 |
Lion Country
I finally got some really awesome LED's today. Osram Golden Dragon plus. These things are VERY bright. I am only going to need 3 per side panel at probably half the brightness it can go.
Here it is off ![]() Here it is on. The white you see is because my camera cannot process the brightness and this at half the brightness it can do. ![]() This is how nice the light distribution is - even with a big white flash going off. So as you can see, these LED's are bright ![]() Then I also got these guys. 12 of them. FOR FREE!!! 3kg Servo's ![]() ![]() I am busy sorting out the electronics and will do some stuff during the week. Will update in the near future Cheers, S |
#11 |
Lion Country
Project: Mecha -small update
UPDATE WHOOP WHOOP!!!
Ok its actually not that great of an update BUT I did something and it wants to be shown... I was pondering the lost couple of weeks how exactly I was going to make the side panels with their pods. This past Monday I decided to just get 0.9mm thick aluminium plate and bend it till it fitted the panel and then solder the things together. I ran my idea by a good friend and mechanical engineer (he's busy with a doctorate in mechanical engineering so I think he knows what he is talking about) and he advised me against this. Basically the flux that would be needed to weld the pieces together melts at a higher temperature than aluminium will. This will then cause the alu to buckle because it is so thin - BIG PROBLEM... They need to be flat and pretty and awesome. SOOOOO I have decided that I will rather get "L" shape aluminium pieces, bend those to the shape I want and then bolt/screw the pieces in place. It will be a bit more work but I think it will be for the best. And then today I needed to test this theoretical design idea and this is exactly what I did. I used an old piece I ripped out of behemoth for the task. It is also much thicker than what I want to use. ![]() I will need to invest in a proper mitre saw. I do not like how this came out. ![]() At least the angles were correct and wasn't that difficult to achieve. I will have to fit a "holding" piece over each corner to keep it at the right angle. ![]() This is ol' rusty trusty that I used to bend the alu - I got it for a bargain (free!!!) ![]() Cheers, S Last edited by Samaya; 27th Feb 2011 at 13:58. |
#12 |
Lion Country
Look what I got...
![]() All $100 worth... ![]() ![]() ![]() I can only start working on it over the weekend though . Will try to mark out everything in the meantime. Can't wait
#13 |
Lion Country
I have started masking all those panels.
Done 3 sofar in this pic ![]() And then I ran out of tape ![]() ![]() Done masking ![]() Not done masking ![]() Some good news I suppose is that everything is oversized as opposed to not-going-to-fit-and-needs-replacement size ![]() I'll start some cutting over the weekend and hopefully have a WAAAAAYYYYYY more interesting post to make
#14 |
Lion Country
I started marking the panels last week already - to cut them obviously. But it is taking VERY long. A panel is done every 4 hours or so because it is checked about seven times and then checked against similar panels and then fixed where I made mistakes. So if these cuts are not "right" well then I'll have to redo my education - from grade 1...
#15 |
Lion Country
Ok so marking is going well. I finished marking the side panels. Then I found that the first side I marked has a fault and is marked 3mm too long because of some angle being 1' degree out
![]() ![]() I have to redo those 2. And then in other news... I found that my frame is 10mm LONGER than what my dimensions say it should be ![]() ![]() I wish I could have welded the frame myself. O well I'll just add the extra length to my panels. Luckily I bought the aluminium longer than was required.All the side panels marked. I still need to do the pods ![]() Small mock-up of how the panels will be fitted. ![]() I hope to start cutting over the weekend - really hope to... |
#16 |
Lion Country
So finally I can say UPDATE!!! I actually did some cutting of a SINGLE panel. I couldn't finish it but I got very far with it. Took me 3.5 hours to just do this little bit - This is going to be a looooooooonng build.
On with the show First cuts - nice and straight with a Jig saw ![]() ![]() ![]() Finished cutting ![]() It still fits ![]() ![]() Tapping 11 holes is not much fun. ![]() At least I made sure the holes align with the tapped ones... (this time )![]() And fitted to the frame with all the scratches... ![]() So now I still need to cut the small corners off, file down to the required width and then sand it down so there are no more scratches. Then I'll start on the next couple of panels. I do have another home project that is constantly interrupting this mod (My fish tank cabinet need doors and the stand with my daughters birds on needs to be sanded (again) and painted). I am also waiting for my screws that I ordered to arrive. Sorry if the updates are not frequent enough I am trying to get to the mod more.Enjoy, S |
#17 |
Lion Country
Ok I managed to upload SOME pic.
This is my setup for cutting the aluminium. Pity my Jigsaw is old and makes the blade bend side ways, otherwise you would have seen a perfectly straigth line... ![]() ![]() 4 sides done ![]() Quick mock up ![]() That edge is looking mighty fine ![]() And done ![]() OMW this piece is thin. It bends so easily... But I have a plan, a big bright plan that is going to cost wifey money (which I supply ) I also finished off the edges of the thick piece and marked the place where the hole's would be, but I broke a drill bit off in the thick alu and need to get that out first - so no pics of that until I fix it ![]() Let me know what you think, S |
#18 |
Lion Country
I think I'll try a 1mm thick bit to drill into the 1.5mm broken bit and see if I can extract it that way or I could just leave it there and drill a hole next to it. I'll just be more careful next time
#19 |
Lion Country
I think you're right. I'll leave it there and just make a new hole next to it. The panel will cover it in anyway.
#20 |
Lion Country
Another day of idea testing...
I had a bit of time to implement some ideas that came to me. Firstly I want to use M2 screws to fix the sides to the frame. That way it would be easier to cover them when I paint the case (Less area) ![]() Then I did this tester. I thought it would look great with a see through red coloured perspex (will need to polish it though) with some miniature led's lighting it up. ![]() I still need to cut the rest of the panels but that will have to wait as my little girl is turning 4 this weekend and we have to celebrate that ![]() But after the celebration I will be looking forward to an 11 day holiday from the 22nd. I can't WAIT for that holiday ![]() ![]()
| Thread Tools | |
| View Mode | |
