Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 28th Oct 2011, 09:32   #3301
keir
S p i t F i r e
keir's Avatar
keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by Lassar View Post
Still waiting for my physical warefare key....
I got mine this morning. I'm still waiting for the ****ing DVD!
__________________
Latest project ¦ Hidden living room gaming PC ¦ Awaiting time/space from kids
UV . Silent . waterCooled - Vertex 4 256GB . i5 750 @ 3.1Ghz . 8GB DDR3 1600 . Gigabyte GA-P55M-UD4 .GTX 670
keir is offline   Reply With Quote
Old 28th Oct 2011, 09:46   #3302
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!
I had an email from Amazon this morning with a postage notification and a second email with my DLC key. I only ordered on Wednesday.
Da_Rude_Baboon is offline   Reply With Quote
Old 28th Oct 2011, 09:50   #3303
shigllgetcha
Come at me bro
shigllgetcha's Avatar
shigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysisshigllgetcha can run Crysis
Mine was dispatched taday from amazon Ill not have a change to play until Sunday or Monday anyway so its no big loss.
I changed my address last week so id guess thats what held me up
__________________
I dont trust anything I hear on QI ¦ xbox live id: shigllgetcha ¦ PC: some dell
shigllgetcha is offline   Reply With Quote
Old 28th Oct 2011, 09:54   #3304
the_kille4
Chaos will rule da world.eventually
the_kille4 has yet to learn the way of the Dremel
i'm currently having an awesome time playing bf3... here are some commands that i use...
generally settings that are not on the normal settings is available through the command line
you can access it by pressing the [`~] button.
by typing "list" you can see what sort of commands there are as far as what is on the screen there are 5 types of commands
RenderDevice.XXXX
Render.XXXX
Screenshot.XXXX
WorldRender.XXXX
Postprocess.XXXX
I will just explain each of these in detail, although I don't know what some of them actually do.
when you type it it doesn't matter if you type with capitals or not
RenderDevice.XXXX
RenderDevice.Dx11Enable
either 0 or 1
enables DirectX 11
decreases your fps
RenderDevice.VsyncEnable
either 0 or 1
enables vsync
RenderDevice.TripleBufferingEnable
either 0 or 1
enables triple buffering
RenderDevice.ForceRenderAheadLimit
Render.XXXX
Render.DrawFps
either 0 or 1
enables fps...now you don't need fraps!
Render.DrawFpsMethod
don't know what it does
Render.DrawScreenInfo
either 0 or 1
shows the resolution, frame refresh, whether vsync is on
Render.PerfOverlayEnable
either 0 or 1
allows the use of performance overlay... I think not really sure
Render.PerfOverlayVisible
either 0 or 1
shows the CPU/GPU performance
covers the map making it slightly hard to see
here is the pic of Render.XXXX stuff
top right is fps
top left is screen info
bottom left is performance overlay
Screenshot.XXXX
Screenshot.Render
maybe creates screenshot...
Screenshot.Format
probably changes the image format of the screenshot
WorldRender.XXXX
everything bar enabling/disabling motion blur in the world render i don't know what it does however i listed them anyway
WorldRender.TransparencyShadowMapEnable
WorldRender.MotionBlurEnable
either 0 or 1
enables motion blur
WorldRender.MotionBlurScale
WorldRender.MotionBlurMax
WorldRender.MotionBlurNoiseScale
WorldRender.MotionBlurQuality
WorldRender.MotionBlurMaxSampleCount
WorldRender.MotionBlurFrameAverageCount
WorldRender.SpotlightShadowMapEnable
WorldRender.SpotlightShadowMapResolution
WorldRender.DxDefferedCsPathEnable
WorldRender.FxaaEnable
PostProcess.XXXX
don't know what these do
PostProcess.AOEnable
PostProcess.AOMethod
the_kille4 is offline   Reply With Quote
Old 28th Oct 2011, 09:57   #3305
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
Wow. Some nice commands. Some of which I will be using, like the fps counter . Thanks +rep.
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 28th Oct 2011, 10:10   #3306
Mr Happy
Mr Happy's Avatar
Mr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for presidentMr Happy should be considered for president
Just fell through letterbox NICE
Mr Happy is offline   Reply With Quote
Old 28th Oct 2011, 10:17   #3307
ClaggyPants
What's a Dremel?
ClaggyPants has yet to learn the way of the Dremel
I need to finish work. Stuck here till 5pm although I have the house to myself tonight - drawn curtains and 42" 1080p and 5.1 action all the way after 6pm though
ClaggyPants is offline   Reply With Quote
Old 28th Oct 2011, 10:28   #3308
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.
My physical DVD from Game was on my desk this morning when I got to work, having sat there for a day in full view of the cleaners etc... (I wasn't in the office yesterday when it arrived).
At least I have it now.
__________________
Gaming: [Silverstone FT01-BW][Asus Z68-V Pro/GEN3][i5-2500K@4.0GHz][Titan Fenrir][8GB 1866MHz][Asus GTX 580][Crucial M4 256GB][Xonar DX][Antec TP New 650w][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus P8P67-M Pro][i5-2500K][8GB 1600MHz][Asus 6850 DirectCU][Corsair Force 3 120GB][Seasonic S12 430w]
Kids: [Silverstone SG05B][Asus P8H61-I][Pentium G840][4GB 1333MHz][OCZ Vertex Plus R2 120GB][Dell E207WFP]
Projects: [Antec 300 improved] NAS 1: [Synology DS211j] NAS 2: [OpenMediaVault]
Fingers66 is offline   Reply With Quote
Old 28th Oct 2011, 10:33   #3309
Lance
I ate Bhindi Bhaji.
Lance's Avatar
Lance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on youLance - may the hammer of Bindi be bestowed on you
Originally Posted by Mr Happy View Post
Just fell through letterbox DICE
Fixed that there for ya!
See you all on the battlefield from 7 onwards!
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is offline   Reply With Quote
Old 28th Oct 2011, 10:50   #3310
Cerberus90
petrolhead
Cerberus90's Avatar
Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!
Just finished the single player,
__________________
Steam: Cerberus90
| Q6600 @ 3.2GHz | Asus P5K Premium | 4GiB Patriot 1000MHz | 256GB Samsung 830 |
| Gigabyte GTX460 @ 830/2000 | Fractal Core 3000 | 24" BenQ G2420HD |
Cerberus90 is offline   Reply With Quote
Old 28th Oct 2011, 10:54   #3311
loftie
Hypermodder
loftie's Avatar
loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!loftie - it's over 9000!!!!!!!!1!1!1!!!
PostProcess.XXXX
I imagine these will enable/disable and cycle through the AA, the one with options Low, Medium, High. Can't remember what it's called.
loftie is offline   Reply With Quote
Old 28th Oct 2011, 11:02   #3312
yassarikhan786
Ultramodder(Not)
How long did it take ya and what difficulty level did you play at? For the second question I'm assuming Hard .
__________________
Old 28th Oct 2011, 11:03   #3313
impar
2n-1
impar's Avatar
impar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremelimpar has yet to learn the way of the Dremel
Greetings!
HyperThreading enabled or disabled?
http://www.overclock.net/intel-cpus/...eading-vs.html
Check the minimum FPS.
__________________
"Dispatch War Rocket Ajax to bring back his body!"
impar is offline   Reply With Quote
Old 28th Oct 2011, 11:04   #3314
yassarikhan786
Ultramodder(Not)
Originally Posted by impar View Post
Greetings!
Interesting. Virtually no difference .
__________________
Old 28th Oct 2011, 11:08   #3315
WildThing
Hypermodder
WildThing's Avatar
WildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the DremelWildThing has yet to learn the way of the Dremel
Me too, Amazon says dispatched via Royal Fail - delivery estimate 28th. I have the day off work which is great, but still no BF3.
__________________
Asus P8P67 PRO ¦ Intel i5 2500K @ 4.4GHz ¦ Titan Fenrir ¦ XFX 6950 @ 6970 ¦ 2x4GB Corsair DDR3 1600MHz ¦ 2x Crucial C300 128GB (OS + Games) ¦ Samsung Spinpoint F3 1TB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ Corsair 650D case ¦ HP 24" LP2475W ¦ Win7 x64
WildThing is offline   Reply With Quote
Old 28th Oct 2011, 11:23   #3316
keir
S p i t F i r e
keir's Avatar
I'm in new look with the OH thinking this is good karma. It better be there when I get home or I'll explode.
__________________
Old 28th Oct 2011, 11:28   #3317
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on you
Weird I'm in the same boat amazon tells me 28th but nothing yet I'm so annoyed
__________________
The Rig: i7 3770K @ 4.6Ghz/ Asus Maximus Gene V/ 16Gb Corsair Vengeance (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 /
The Water: EK Supreme HF CPU Block / EK 7970 CSQ GPU Block / XSPC H2O 750 V4 / 2 x 240mm AlphaCool NeXXXos UT60 RADs /
The Project: Antec TwelvOrange
flame696 is offline   Reply With Quote
Old 28th Oct 2011, 11:32   #3318
Fingers66
Kiwi in London
Fingers66's Avatar
Bit-Tech review is up: http://www.bit-tech.net/gaming/pc/20...-3-pc-review/1
__________________
Old 28th Oct 2011, 11:33   #3319
thefriscokid
why s**t so crazy?
thefriscokid's Avatar
thefriscokid has yet to learn the way of the Dremelthefriscokid has yet to learn the way of the Dremelthefriscokid has yet to learn the way of the Dremel
Anybody notice that when you drive through water (CB for instance) your player will automatically dismount from the vehicle.
__________________
i5 2500K | 8 GB Corsair Vengence | MSI GTX560TI | Asus P8P67 Pro B3 | Crucial M4 64 GB SSD | 2x Samsung F3 1TB | Antec TP 750W | Lian Li A05 | Win 7 Pro 64-Bit | Logitech Z-5500 5.1 THX | Filco Ninja TKL | Razer DeathAdder | Dell U2410M | Senn PC360
battlelog: thefriscokid - bf3s - xbox live: JAS82
thefriscokid is offline   Reply With Quote
Old 28th Oct 2011, 11:35   #3320
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpit
Only if its water deep enough for the vehicle to 'float', otherwise you should be fine.
__________________
Bewbs.
mars-bar-man is online now   Reply With Quote
Reply
Tags
battlefield 3, bf3
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
