Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 11th Apr 2012, 10:28   #8561
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Yeah, sorry, I haven't been on as I'm halfway through a new build and haven't had a working PC for a week or two!
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 11th Apr 2012, 11:38   #8562
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
Originally Posted by smc8788 View Post
I'm actually finding the repair tool nerf to be much more frustrating, it makes it nearly impossible to solo in tanks and even repair a friendly tank under light RPG fire.
I concur. I could live with the tanks being made of paper and dried spaghetti if I could repair them at a decent rate but the repair tool nerf borks it completely.
Da_Rude_Baboon is offline   Reply With Quote
Old 11th Apr 2012, 11:53   #8563
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
The repair tool isn't all that bad to be honest. There is another option though. If your man enough to give it a go. Use the EOD BOT to repair. It can repair all vehicles and as far as I am aware hasn't been nerfed in regards repair time. Might give it a go later today if anyone wants to check the repair time EOD vs Repair Tool?
Plus driving the EOD is much more fun now.
Ignore my vocals I did that on the fly! And vocal to video is out of sync as I removed a section of video and forgot the voice over would not reflect the actual action on screen.
__________________
MrDomRocks is online now   Reply With Quote
Old 11th Apr 2012, 11:59   #8564
Elton
Proud Model M User
Elton's Avatar
Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.
Readjusted to the new settings. Am having tons of fun. And the MP7 is now a hose of death. Lots of death.
Underbarrel is getting more use. It seems foregrip does nothing for the ARs now. They need to fix vehicle repair times. The missile damage can stay the same, but the double whammy is murderous.
__________________
There's good ideas and then there's terribly great ideas.
Elton is offline   Reply With Quote
Old 11th Apr 2012, 12:08   #8565
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.CrapBag is the Cheesecake. Relix smiles down upon them.
I've started using the EOD quite a bit now, never had a kill with it pre patch and have 34 now, handles much better but really doesn't like steep inclines as it goes nuts.
Really don't like the fact that if you even touch a friendly vehicle or drive it into a friendly soldier it explodes, just makes you more careful I suppose.
CrapBag is offline   Reply With Quote
Old 11th Apr 2012, 12:09   #8566
JitsuSparty
Multimodder
JitsuSparty's Avatar
JitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run Crysis
Originally Posted by CrapBag View Post
I'v started using the EOD quite a bit now, never had a kill with it post patch and have 34 now, handles much better but really doesn't like steep inclines as it goes nuts.
that explains a lot - I was getting frustrated as to why my bot kept dissapearing.
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!"
So Say We All - BitFenix Prodigy casemod
JitsuSparty is offline   Reply With Quote
Old 11th Apr 2012, 12:17   #8567
Doc943
What's a Dremel?
Doc943's Avatar
Doc943 has yet to learn the way of the DremelDoc943 has yet to learn the way of the Dremel
Pet hate is joining a server just to see the game end. The 200 or 500 points awarded just ain't worth waiting yet another 45 seconds to start.
Doc943 is offline   Reply With Quote
Old 11th Apr 2012, 12:21   #8568
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.wuyanxu is the Cheesecake. Relix smiles down upon them.
whaaat? i used to love glitching the bot into enemy vehicle and dis-repair them
no thrown C4, no multiple MAV kills, no EOD bot rampage, repair tools takes ages to kill, defib are almost impossible to kill. why are they taking away all the fun parts of the game?
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is online now   Reply With Quote
Old 11th Apr 2012, 12:55   #8569
Phalanx
Needs more dragons and stuff.
Phalanx's Avatar
Phalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for presidentPhalanx should be considered for president
They're working on it. New live scoreboard will show you how far in a game is before you join.
__________________
XBOX Live!: Ph4lanx | Steam: Catachan
Phalanx is online now   Reply With Quote
Old 11th Apr 2012, 12:55   #8570
Parge
Parge's Avatar
Well they have an update just around the corner (if not already out?) that allows you to see live server data, so you can see if the round is about to end!
__________________
Old 11th Apr 2012, 13:01   #8571
CrapBag
CrapBag's Avatar
I finally got the scoreboard today, only just noticed it.
Old 11th Apr 2012, 14:08   #8572
Mr Happy
Mr Happy's Avatar
Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.Mr Happy is the Cheesecake. Relix smiles down upon them.
me too
__________________
My Room and Computer
Gunsmith
talk about being subtle, might as well gone for Vagina Vally
Mr Happy is offline   Reply With Quote
Old 11th Apr 2012, 14:47   #8573
Achilleas.k
Supermodder
Achilleas.k's Avatar
Achilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the DremelAchilleas.k has yet to learn the way of the Dremel
And now, to make everyone feel inadequate:
Achilleas.k is offline   Reply With Quote
Old 11th Apr 2012, 15:04   #8574
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Doesnt bother me, I have a big P***s so don't need to epeen!!
__________________
Old 11th Apr 2012, 15:26   #8575
Phalanx
Phalanx's Avatar
Plus he's at a disadvantage, as he can't take in the whole screen at a glance, so he's more prone to being flanked.
__________________
Old 11th Apr 2012, 15:31   #8576
Achilleas.k
Supermodder
But he doesn't get the same image you would get on a single monitor stretched onto multiple, it's more information. He can get the same information any of us get from one monitor on his central monitors and the rest are just extra, so he'll probably catch things off the corner of his eye that wouldn't fit in a single monitor FOV.
Old 11th Apr 2012, 15:50   #8577
Dae314
Hypermodder
Dae314's Avatar
Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.Dae314 is a hoopy frood who really knows where their towel is.
He also probably changed his FoV to match the extended resolution. If he did it right, it could be like how movies are at a larger aspect ratio. Instead of stretching the image he sees all the way across, he just reveals extra information on the sides that otherwise wouldn't be there.
Then again, who knows if he changed his FoV :P.
__________________
"I have lived on the lip of insanity, wanting to know reasons, knocking on a door. It opens. I've been knocking from the inside."
-- Rumi
Dae314 is offline   Reply With Quote
Old 11th Apr 2012, 16:59   #8578
Mr Happy
Mr Happy's Avatar
Looks like id have to settle for the monitors
__________________
Gunsmith
Old 11th Apr 2012, 17:04   #8579
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Looking at it I think that the image is fake. Doesnt look hard to do mind! And those monitors must cost the same as a small country if they are real.
__________________
Old 11th Apr 2012, 17:21   #8580
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
Well I thought what with the battlelog being down earlier I may get it but it's still not here for me.
On a tangent, my LAN cable is either bust or something. Every time I use a hard wire connection instead of wifi I get stuck on the loading screen or kicked mid game even with the latest drivers.
I do have a second port on the mobo I could try to see if it's that but like a numptee I left the metal flap in and will have to take the whole rig apart.
May have to pick up a cable...
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is offline   Reply With Quote
Reply
Tags
battlefield 3, bf3
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
