Reply
Thread Tools View Mode
Old 1st Mar 2011, 09:01   #61
Guinevere
Mega mom
Guinevere's Avatar
Guinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpit
How heavy is this mutha going to be?
Guinevere is offline   Reply With Quote
Old 1st Mar 2011, 10:01   #62
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
Excellent question. Dont know !
Have my daughter today so i am working from home. I will weigh the model.
The Canope is exactly 2.3 kg. It is just styrofoam with a layer of filling and a layer of epoxy and glasfiber. The baseplate is around 3,5 kg and I guess the deflector tunnel with the pylons will be about 2,5 Kg. The reservoirs with coolant will be 1 kilogram each. So the whole thing without the normal hardware will 10 to 11 kilograms or 20 to 22 pounds.
In comparison a lian-li PC-A77FA is around 9,2 Kg or 18,5 to 20 pounds.
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Old 1st Mar 2011, 10:04   #63
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
Nice work mate. One question, where exactly is it going to live when you've fininshed.
Do you have a huge desk or are you going to hang it from the ceiling in mid flight?
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is online now   Reply With Quote
Old 1st Mar 2011, 10:17   #64
cchr
Multimodder
cchr's Avatar
cchr has yet to learn the way of the Dremel
...or, it would levitate itself around the room
joking aside, i think a stand would be perfect for this.
cheers,
chris
cchr is offline   Reply With Quote
Old 1st Mar 2011, 10:19   #65
ASPHIAX
ASPHIAX's Avatar
Thanks !
It will be probably be supported by a modded tv mount off the wall in my office at home. Was thinking on this and this way I can extend also all the connections into the mount.
Another idea was to make use of a standard like this:
But that will eat up a lot of room on my desk / office and is hard to balance out.
EDIT: It will be easier to move around (like to a LAN party) with a standard so the idea is definately not "out"
__________________
Old 1st Mar 2011, 10:21   #66
adidan
CPC_refugee
adidan's Avatar
Another idea was to make use of a standard like this *snip *
I did think after I posted a sturdy stand would be good as then you could hide all the cables away. Like you say though, it'd take a bit of space up.
__________________
Old 1st Mar 2011, 10:29   #67
ASPHIAX
ASPHIAX's Avatar
cheers,
chris
Or a indoor skydiving tube with a 80 inch fan at 15000 rpm, sure would do wonders for the temps too , LOL !!!
__________________
Old 1st Mar 2011, 11:35   #68
cchr
Multimodder
cchr's Avatar
actually i was talking about a stand that would reside on the ground, not on an office.
something like a speaker stand, only steadier of course!
Thanks !
you wont have to move it to a lan party, just ride it there
Old 1st Mar 2011, 15:00   #69
ASPHIAX
ASPHIAX's Avatar
Good idea!
I will use this idea in the brainstorm session!
thansk man!
__________________
Old 1st Mar 2011, 15:07   #70
ASPHIAX
ASPHIAX's Avatar
Here's another short update
Took apart my old hobby pc for a test fitting in the Eurisko.
This is what it looked like as a V1
The V2 with a lot of plexiglass work, custom window and refitted case to house the internal 280 (roof) and 240 )(floor) radiators
Eurisko Test fitting
Can order the goodies now the internal dimensions have been confirmed. Looks like maybe I can even fit a pair of 6890's in crossfire
Going to do the internal canope work tonight and start on the epoxy for the deflector tunnel.
Later
ASPHIAX
__________________
Old 3rd Mar 2011, 22:32   #71
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Another Star Trek themed modder! I thought I was the only one! Looking awesome + subbed!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 4th Mar 2011, 17:31   #72
ASPHIAX
ASPHIAX's Avatar
Just took a tour through your buildlog! Sweet! Looking forward to more of that quality builds.
Are you working on something right now?
Was playing with the lcars idea also, your interpretation is spot on! +rep on the creativity side!
Next build is already being developed, have multiple idea's, all scifi. It will either be something from star trek, star wars or battlestar galactica. Aiming to finish this one by the end of april (hoping actually, lol)
__________________
Old 6th Mar 2011, 20:22   #73
ASPHIAX
ASPHIAX's Avatar
Found a package at my house on friday.
The first Highflow order is in !
So here are the first starfleet approved USS EURISKO tech specs
The best radiators I could find. I am planning to overclock the system so i need all the cooling i can get. (also foam is a very good insulator so the less heat the better)
To get enough flow through a large ship like the EURISKO i need to have a strong pump. I have allowed room for a secondary laing pump if the circulation proves inadequate.
the fans for on top of the radiators. These fans will be put into a push-pull configuration with the planned fans in the bottom saucer. This to improve the cooling even better. Due to the thick thermochill rads, space was an issue. So I opted for these ultra thin (12mm) Scythe fans
The White Hot EPS Plasm Conduits will be made from the UV tubing from Feser
And a couple of beautifull pieces of mesh for the top and bottom DCIM's
__________________
Old 6th Mar 2011, 20:26   #74
ASPHIAX
ASPHIAX's Avatar
And here they are : Itsy and Bitsy !!!
The built to order reservoirs for the EURISKO !
Made available by my sponsor : Brink of Modding
they hade to be exactly 27cm long and 5 cm wide to fit into the Warp Nacelles.
(update on how that will work, will follow shortly)
Itsy en Bitsy
Peter, Thanks man !!!
__________________
Old 6th Mar 2011, 20:44   #75
ASPHIAX
ASPHIAX's Avatar
Here is the update for this weekend.
Started work on the canope and bottom saucer. One of the final dusty jobs.
All the bottom saucer parts glued to the baseplate
And added a layer of epoxy
Started work on the Main Deflector
Found a sweet piece of plexiglas, cut a hole for the fan to suck in some air and sunk a piece of mesh into it.
Cut a quick couple of pieces of depron to cover the edges. Now I have to wait for the deflector tunnel to be put into the filler and epoxy before i can complete it.
Started work on the warp nacelles with the Brink of Modding reservoirs.
Quickly realised the foam pylons and nacelles were not going to do the job. Setback of about a day. I wanted to hollow out the nacelles and put the hardware into it but the stiffness of the epoxy/glas layer would not stand up to hold the reservoirs, coolant, tubing and fittings. Let alone the mechanical forces that would work onto the epoxy/glass layer once the servo's have been fitted and the whole wing section can move up and down. Back to the drawing board it is ...
Found the solution. There will be MDF plating in this baby !
Even in a starship they have to do weight reduction, so out with all the mdf we dont need!
And a quick test fitting. This picture is with the old foam pylons (the new solution in beneath it)
with this solution the pylon/nacelle partition will be strong enough to handle anything.
Made sure the dimensions stayed the same due to the relative sizes (nacelles vs canope vs width and height)
Side facing view with the reservoirs sticking out of the wood just slightly. This will be made better by the depron plates.
Just a quick test with a single led. working with WWWicked on a 10 fold led arrangement for the nacelles.
Total view
Could not resist testing the Main Deflector with the led. The MD needs to finished with the Angel Eyes or Frosted Led technique.
Wish I had 2 leds for testing ...
Best
ASPHIAX
__________________
Old 7th Mar 2011, 20:35   #76
ASPHIAX
ASPHIAX's Avatar
The USS EURISKO thanks you for your vote !
http://forums.bit-tech.net/showthread.php?t=204963
Oh yeah did I mention it is an extreme honour to be nominated?
Please give my wife a reason to tolerate the mess of future builds
Best regards,
ASPHIAX
__________________
Old 7th Mar 2011, 20:42   #77
adidan
CPC_refugee
adidan's Avatar
You have been voted for.
Even if it wasn't a great build I'd vote purely for the amount of mess you've made.
__________________
Old 7th Mar 2011, 20:45   #78
ASPHIAX
ASPHIAX's Avatar
LOL thanks! Next one will probably be a Desanto Cylon Centurion. This will mean a sculpture of the head and shoulder parts of the cylon made out of ... you guessed it .... FOAM !!!!
The mess will return !
ASPHIAX
__________________
Old 7th Mar 2011, 20:56   #79
adidan
CPC_refugee
adidan's Avatar
LOL thanks! Next one will probably be a Desanto Cylon Soldier.
Cool, with the devilish red light and all I hope.
__________________
Old 7th Mar 2011, 21:00   #80
ASPHIAX
ASPHIAX's Avatar
yep, looking into collision detection system that will fixate the red eyes on the person in front of it. But that is in a few months. first finish this baby!
__________________
Reply
Tags
casecon, casemod, eurisko, star trek, voyager
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
