Reply
Thread Tools View Mode
Old 13th Mar 2011, 17:41   #121
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Yep back ontopic now !
Thansk !
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 20th Mar 2011, 21:40   #122
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Here is a short update:
It is good to take a break from the build every once and again. Left the build for a good week to come back and find several issues with the design that I didn't see before. So I spend the most part of the day with the dremel taking of milimeter by milimeter certain elements of the tail to make the "flow" of the design better. There was a 3 mm thick layer of dust in the room when I finished but its done now and I am happy with it!
Last time when I hooked up the tubing to the warp nacelle it looked like this:
The white coil only just prevented the tube from folding too much so no coolant would be able to flow through. Obviously not a good solution. Take this restriction times 4 (2 per nacelles) and the single pump would definately not be enough umpff to make the ship fly any harder then warp 1,1. Back to the drawing board it is. What would make a perfect 180 degree turn and do that within 4 cm ?
Contacted Bitspower to ask for the heart to heart measurements of their snake fitting. Could not find the deatils anywhere.
Bitspower descided after seeing the buildlogs to send me a box with all different types of fittings, connectors, converters and what not to help me out. How extremely cool of them ! Looks like there are a lot of old trekkies around !
Tehy are all from the Black Sparcle Series ...
So now with the new fittings it looks like this :
PS. the yellow tape is to ensure the plexi doesnt get scratched
Looks a whole lot better al ready. No more restriction in the tubing which also doesnt want to press outwards by the strong curvature in the old solution.
This week will start the foam work encapsulating the nacelles and place the led array.
No small job .. (but so much fun!!!)
Laterz
ASPHIAX
__________________
Old 20th Mar 2011, 22:30   #123
ringo
Supermodder
ringo has yet to learn the way of the Dremel
I like your theme of your con. All over all it looks amazing.
ringo is offline   Reply With Quote
Old 20th Mar 2011, 22:36   #124
ASPHIAX
Hypermodder
ASPHIAX's Avatar
I cant wait to start the detail work on the outside of the canope, and on the fancontroller and on the servo assembly and on .... There is just so much stuff to do I need to restrict myself to work on 1 thing at a time.
Thansk man !
__________________
Old 21st Mar 2011, 09:25   #125
adidan
Yeah, nah bro.
adidan's Avatar
adidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyanadidan is a Super Spamming Saiyan
Focus man! God dammit focus!
Making nice progress there mate.
__________________
Guesswork is still work
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung S24C570HL 24" // W7 64
adidan is offline   Reply With Quote
Old 21st Mar 2011, 09:33   #126
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Gracias Amigo !
Getting the PSU and HDD's tomorrow so I will be able to finish the deflector tunnel and with that the whole external body work. Major milestone!
__________________
Old 21st Mar 2011, 13:02   #127
craigr1982
Multimodder
craigr1982 has yet to learn the way of the Dremel
Nice work, looks lovely
__________________
Craigr1982
Toxicity- A HAF932 Mod - Asus P5KE-WiFi, Intel Q9450 @ 3.4Ghz, XFX GTX275, 4Gb Kingston 1066, 60Gb OCZ Vertex 2 SSD, 2x 1Tb HDD.
craigr1982 is offline   Reply With Quote
Old 21st Mar 2011, 13:04   #128
adidan
Yeah, nah bro.
adidan's Avatar
Lol, that sounds probably more impressive than it should.
__________________
Old 21st Mar 2011, 18:21   #129
Boddaker
TRON CAT!
Boddaker's Avatar
Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.
Nice work on the nacelles so far, and congrats on winning MOTM!
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 21st Mar 2011, 18:36   #130
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
I think you need to change your sig to motm winner instead of nominated congrats .
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 21st Mar 2011, 18:45   #131
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thank you ! Just cant believe the amount of support I am getting
Saw you claimed the electrical knife from the misses again
__________________
Old 21st Mar 2011, 18:48   #132
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Yep I guess i do need to change it,
Thansk man !
__________________
Old 21st Mar 2011, 19:03   #133
Waynio
Relaxing
Waynio's Avatar
I can believe it, awesome mod .
__________________
Old 21st Mar 2011, 20:13   #134
craigr1982
Multimodder
congrats on the win! now get back to modding
__________________
Craigr1982
Old 21st Mar 2011, 20:35   #135
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Well I Guess its official now !!!
Mod - Of - The - Month FEB 2011 Winner : USS EURISKO Intrepid Mark II Class
It was very close but with 6 votes the EURISKO came out victorious and looking at the quality of the competition it is most humbling ...
I would like to thank everyone who voted Gave mental support and helped with tips, tricks and suggestions !!!
Couldn't have done it without you !!!
Grt
ASPHIAX
PS: And now back to modding !!!
__________________
Old 21st Mar 2011, 21:07   #136
adidan
Yeah, nah bro.
adidan's Avatar
You're welcome. Not your usual box and you're in a team of one, I think it quite just that you won TBH mate.
__________________
Old 22nd Mar 2011, 08:28   #137
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thansk buddy !
__________________
Old 22nd Mar 2011, 11:26   #138
Samaya
Lion Country
Samaya's Avatar
Samaya has yet to learn the way of the Dremel
Congratulations!!! Your mod is awesome and the win is well deserved
Samaya is offline   Reply With Quote
Old 23rd Mar 2011, 21:23   #139
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Here is another update :
The Deflector Tunnel!
So, What do we have to do here. Fit the MDF PSU casing into the tunnel, fit the HDD drive cage with 2 HDD's and a SSD, fit the Laing DDC pump and add a 92mm fan for the HDD cooling.
Here is an upside down picture for explanation. After a tip from The Boiler I incorporated a structural element that will make attaching the case to the standard far more easy.
The MDF PSU casing has been raised for a couple of cm's making it stick out under the case. This will make it fit into a slot in the to be build standard and when everything is neatly airbrushed the model will seem to float 1,5 cm's above the standard (well thats the idea at least, LOL)
A little jump forwards, I was so busy I forgot to take pictures! I cut the raised casing out of the foam and sunk the HDD cage into it. Also added some structural elements to make it more stiff.
The foam "behind" the HDD cage has been removed to allow a 92mm fan to be placed pushing the air out of the tail section. So cool air is coming in through the raised PSU casing and pushed out through the tail-fan
Enough room for all the cables, esspecially when they have all been made to perfect length ;-)
I only have to move the pwr connector and switch to the back. A bit sorry to have to void the 5 year warranty on a PSU that has been in my posession for less than a day. Oh well, all part of the game right !?!
Put everything into the epoxy/glassfiber and put some additional layers where the tubing willenter the tail and where the fan will be cut out.
Here for the tubing :
Gonna drop by the hobbyshop tomorrow for some hinges to make the pylons and warp nacelles move up and down.
Laters
ASPHIAX
__________________
Old 24th Mar 2011, 19:20   #140
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks ! It was close, the 700D is a beatifull piece of work!
__________________
Reply
Tags
casecon, casemod, eurisko, star trek, voyager
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
