Reply
Thread Tools View Mode
Old 24th Mar 2011, 19:33   #141
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Here is another update !
Had a brainfart while snowboarding after seeing a piece of snow coming through a piece of cloth at the pub.
This is what is has to become:
Here is the idea:
Looks soemthing like this
CRAP !! You can still see the transparant frosted plexi. oh wait thats because light is getting into it from the sieds. DOH !!!
Hmm still a lot of light but it is not as visible now. the LCARS panel needs to be light tight from the sides and between the LEDS"s
And LED on: (my camera shows too much light. it actually is a easy going blue
Still soem licht polution but the principle works!!! now to do soem experimenting with the intesity of the leds
'Here is an overview of the layers of plexi
Laterz
ASPHIAX
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 24th Mar 2011, 21:53   #142
ASPHIAX
Hypermodder
ASPHIAX's Avatar
And to keep momentum: Another Update ! Finally had some time to translate!
HMMM Let poke some holes now the epoxy is dry
It finally became a 80mm fan. Just wouldnt get the 92mm in without it looking strange.
The Tail fan
I can still add the os SSD between the HDD's and they will still have enough cooling
Started on the Pylons with the warp nacelles. Added a couple of small hinges.
This should be made possible to do electrically (by the servo's running of an arduino) by pushing a button on the commbadge !
Warp speed !
Holes..
More holes ...
Jeffries tube from the series
The next pictures were made with green tubing for testing purposes. They will be replaced with feser white UV tubing as the whole interior will be airbrushed black and the led fan will be bue.
Ingress from the warp nacelles and egress towards the mobo and pump
Quick fitting session with all the deflector tunnel hardware fitted
Almost a shame to have to enclose this with foam
Well that was it for today
Laterz
ASPHIAX
__________________
Old 25th Mar 2011, 00:06   #143
cchr
Multimodder
cchr's Avatar
cchr has yet to learn the way of the Dremel
This is getting more awesome by the minute!
keep it up man! great work!
__________________
Sony Vaio VGN-FW11M:
Intel Core 2 Duo P8400 2.26GHz, 4GB RAM, 250GB HDD, ATI Mobility Radeon HD3470.
Dell Mini 1012:
Intel Atom N450 1.66GHz, 1GB RAM, 32GB SSD.
No Desktop for now
cchr is offline   Reply With Quote
Old 25th Mar 2011, 13:28   #144
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Good job men! I like it very much. I am a big fan of water cooling and yours looking awesome. All the servos and stuff great job keeb it up
dream1 is offline   Reply With Quote
Old 25th Mar 2011, 14:38   #145
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
Addictive Post makes you want more and more.. But can you put a rowntrees fruit pastel in your mouth without chewing?
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 25th Mar 2011, 18:08   #146
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Thanks, Look here for a lively discussion on eating a pastel without chewing OR how to say ham without closing your mouth !
__________________
Old 25th Mar 2011, 23:20   #147
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Here are a quick couple of pics made tonight!
LATERZ
ASPHIAX
__________________
Old 27th Mar 2011, 14:29   #148
ASPHIAX
Hypermodder
ASPHIAX's Avatar
I solved the problem with the huge "sunroof" bleeder and those on the sides.
I will use a reflective insulation tape (actually layed the plastic underfloor in my living room with this) It weighs nothing compared to the thick layer of filler, it seals all the bleeders, it reflects the warmth coming from the hardware inside the case preventing the foam to become an insolator and also reflects the light from the leds so the inside is better lit.
Creds to Munty for the exellent tip! Thansk bro!
Just wanted to share this pic before sealing all the bleeders.
EVIL SMILIE !!!
This the effect of sealing the bleeders. Just not sure about the way it looks. Any thoughts ?
EDIT: Oh yeah, I need to change the position of the IR receivers for the microcontrollers as the signals probably will not get through anymore.
__________________
Old 27th Mar 2011, 15:18   #149
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Is that portion on the right an NZXT Sentry LX? I've got one - have you used one before?
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 27th Mar 2011, 17:56   #150
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Its a sentry LXE with the remote . I have an LX in my other case , works ok, only when the temp rises the fan gets more power quick. wish it would have been adjustable (20 = 700rpm, 300= 800 rpm, 50 = 1500, etc )
The LXE has been purring away for a couple of days at my desk. heard some stories about the fans squeling and the lack of power on the channels but so far so good?
How are your experiences with it?
__________________
Old 27th Mar 2011, 21:12   #151
PureSilver
E-tailer Tailor
PureSilver's Avatar
I find the temperature probes to be a bit of a pain, TBH, and something - probably a battery - has died, so it won't hold the date/time etc when the computer's powered down. I like it, but I wouldn't buy another one.
I wish someone would make a fan controller that pulls temperature data from the actual components via a motherboard USB header, or something. Most components measure their own temperatures, so it seems stupid for fan controllers to try and measure it themselves (through the wrong side of an HSF/the plastic casing of a GPU/whatever else the probes are stuck to) when they could just grab it from a basic program. That way I wouldn't have to fill my case with inaccurate, annoying probes that massively underestimate temperature.
__________________
Old 27th Mar 2011, 21:37   #152
MurdocksFace
What's a Dremel?
MurdocksFace's Avatar
MurdocksFace has yet to learn the way of the Dremel
Your build is great in itself, but this screen... I would it have on my TV all day. I would probably buy a second TV just to display it. That is awesome!
MurdocksFace is offline   Reply With Quote
Old 27th Mar 2011, 22:00   #153
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Sounds like the battery, installed mine without it and had the same issue untill i found I hadnt plugged the battery in
Yep, i know exactly what you mean mate! Speedfan does do something in that area with the temp coming directly from the device but I havent found a fancontroller that integrates with a prog like speedfan. I hope that if I ever get a sponsor in this area I can do something with them to adress this. In my belief its not only what you can make with the products of the sponsor but potentially also with the sponsor itself. The best idea's are born out of necessity and modding is in my view about continuously thinking outside the box.
__________________
Old 28th Mar 2011, 14:58   #154
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Hahaha, thanks man! The Sentry LXE fancontroller is already in and I am expecting the microcontroller for the leds and the panel from cnc guy in two weeks, so keep tuned!
__________________
Old 28th Mar 2011, 19:33   #155
MurdocksFace
What's a Dremel?
I'll keep tuned, alright (in a jealous way!).
I had an epiphany today: on the screen you posted there is a spelling mistake in the ship's class. It's supposed to be Intrepid, not "Entrepid".
(This occurred to me whilst buying groceries, so I will not see the finishing of this build, as I'm going to kill myself for being too much of a sad, sad nerd. )
Old 29th Mar 2011, 13:36   #156
0rbibital
What's a Dremel? Stop asking that!!
0rbibital has yet to learn the way of the Dremel
Beam me up captain
0rbibital is offline   Reply With Quote
Old 29th Mar 2011, 14:08   #157
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Maybe after all the stardust settles I can build you a version so you can look at it all day long!
Hahaha, good to see that my build is reaching parts of the brain active while buying groceries. I always come home with the wrong stuff because I'm thinking of other stuff while I get the list dictated by my wife, lol!
Thansk a bunch dude! the CNC guy was gonna do a test run tonight so I was able to change the design!
With the amount of support I am getting (5 buildlogs total 2000 hits a day) I can tell you one thing : You are not alone !!!
__________________
Old 29th Mar 2011, 14:10   #158
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Originally Posted by 0rbibital View Post
Beam me up captain
WARP 9 - Engage !
Thanks!
__________________
Old 29th Mar 2011, 23:44   #159
LooseNeutral
Hypermodder
LooseNeutral's Avatar
LooseNeutral has yet to learn the way of the Dremel
Wow, some nice updates. Can't wait to see that controller and the water cooling scheme Looks great. Also, congrats on the MOTM win!
LooseNeutral is offline   Reply With Quote
Old 30th Mar 2011, 01:24   #160
Shadow703793
Supermodder
Shadow703793 has yet to learn the way of the DremelShadow703793 has yet to learn the way of the Dremel
Nice. As for the bleeding, have you considered painting it with something like rubberizing spray? 1-2 coats of rubberizing paint will completely block out the bleeding.
Shadow703793 is offline   Reply With Quote
Reply
Tags
casecon, casemod, eurisko, star trek, voyager
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
