Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Feb 2011, 15:40   #81
jonnym
Minimodder
jonnym has yet to learn the way of the Dremel
Now that will be interesting! What mobo are you using (according to the Thermalright website, see HR-02 MCL.pdf link at the bottom), pretty much any H67 Micro-ATX board is going to have problems with the PCI-E slot, while the P67 M-ATX boards should be fine...
What RAM are you using - tall heatspreaders?
Looking fwd to the pics dude
jonnym is offline   Reply With Quote
Old 25th Feb 2011, 15:16   #82
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!Da_Rude_Baboon - it's over 9000!!!!!!!!1!1!1!!!
Its a P series and I use Corsair Vengeance with the tall heat spreaders. Scan's courier has failed me how ever. It is being delivered to my work between 17.30 and 18.30 today but I finish at 16.30 so unless I'm going past work this weekend I will not get it until Monday.
Da_Rude_Baboon is offline   Reply With Quote
Old 1st Mar 2011, 10:19   #83
Da_Rude_Baboon
What the?
Fitted the new HSF last night.
Before with the Titan Skali.
Skali and the FT-02 together.
From above.
The side
In the case
View around the socket showing the ram clearance
For such a big heat sink it was a suprisingly painless to fit and comes with an extra long screw driver as you need to screw through the height of the heatsink to reach one of the mounting screws. I have not had time to stress out the PC and get load temps yet but it idles the same as the skali and sometimes lower. With the front panel removed it was idling around 40c but that dropped to 34c with the panel in place and more direct airflow. It comes with everything you need to mount either a 120mm or 140mm fan as well so you can convert it to an active heatsink easily enough.
Old 1st Mar 2011, 10:27   #84
jonnym
Minimodder
Great work & great pics D_R.
The HR-02 is one big momma... Fits like a dream though, and must make for a pretty quiet system!
I wonder whether the temps would be lower or higher if you swapped out the CPU bracket fan for a fan on the HR-02 itself (assuming there's enough clearance on the RAM)?!
Excellent stuff.
Let us know the load temps when you get a chance
Old 1st Mar 2011, 10:37   #85
r3loaded
Hypermodder
r3loaded's Avatar
r3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremelr3loaded has yet to learn the way of the Dremel
That looks pretty nice. I'm personally considering moving the CPU fan from the heatsink itself to the angled bracket - it'll certainly solve the RAM clearance problem. Or I might get an Antec/Corsair water-cooler later on..
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | MSI Radeon 7970 | 128GB Crucial C300 + 1TB Samsung F3 | CM Silent Pro Gold 600W | Samsung XL2270HD
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400
r3loaded is offline   Reply With Quote
Old 1st Mar 2011, 11:40   #86
Da_Rude_Baboon
What the?
I think the CPU would be lower with a 140mm fan on the heat sink but i'm not sure what would happen to the rest of the case temperatures. The 140mm bottom of the fan would sit lower than the fins on the heatsink so the socket area would get airflow. The bottom pick on the install instructions shows a 140mm fan fitted. [PDF]
Old 1st Mar 2011, 11:45   #87
jonnym
Minimodder
As long as you're happy with the temps, idle & load, job's a good'un.
You're running a 2600K, I think? Any overclock?
Like I said, bet it's pretty quiet!
Old 1st Mar 2011, 14:20   #88
Da_Rude_Baboon
What the?
2500k and its at stock atm until I record a base line load temp and I am completely satisfied that everything is 100% stable. I briefly turned on the AI overclocking feature on the motherboard and it would push the CPU to 4.1Ghz so I expect there to be some head room over that with a manual OC.
Using the OCCT extreme test the temps maxed out at 78c with the Skali so it will be interesting to see how the HR-02 compares. Something is making more noise than it should so I need to fine tune the fan settings.
Old 1st Mar 2011, 15:56   #89
Elladene
Minimodder
Elladene has yet to learn the way of the Dremel
I have been monitoring this thread for a while. I do not wish to take off topic but wanted some help/ reassurance.
I am no expert would like to take the plunge on a new system. To mitigate my lack of expertise I would like to plaugerise the builds mentioned here (primarily Da Rude Baboon).
I live in Bermuda and therefore parts are very hard to come by. I will ship in from the US, but I can do this only once really (without a huge delay), so I need to order it right first time.
My need is maximum quiet/ maximum power (the age old trade off).
I would be obliged if someone could confirm my parts list is complete/ answer a couple of questions:
PSU: Silverstone Strider 600w + optional short cable kit (Is this PSU quiet?);
CPU: i7 2600k
MB: P8P67 - M - Pro ( i will not manually overclock, do I need pro?);
Ram: 2 * 4GB Corsair Vengeance 1866 (Is this the correct Ram?);
SSD: Best I can but with money left over;
HDD: 1TB Samsund spinpoint (is this a quiet HDD?);
Cooler: Thermaltake HR02 fanless heatsink;
Optical: Slotloading drive (to be found via web);
Cables: Slimline SATA to SATA adapter, 3 * 15cm straight SATA cable.
Hope you can help with questions/ confirmation re above.
My last question is GPU: whats the best/ quietist that will fit into the case. I see a number of these on this thread (KFA2 GTX 560, eVGA GTX 570, Saphire 5870 HD Vapour-x). Which is the best for fit (must) and the power/ quiet trade off (and indeed the rear exhaust seems recommended).
I appreciate the help. I am very much a beginner re comp build so do need the help.
Elladene is offline   Reply With Quote
Old 1st Mar 2011, 17:46   #90
r3loaded
Hypermodder
r3loaded's Avatar
CPU: Do you need to run "professional" software? (stuff like video editing/3D rendering/CAD). If not, save a fair bit of money and get a 2500K. If you're not going to overclock (and never wish to), save some more money and get a non-K model CPU.
Mobo: The main difference between the Pro and non-Pro models is that the Pro allows for SLI and can accordingly configure its PCIe lanes in 8x/8x mode instead of 16x/4x. I decided to pay the extra £7 for the flexibility.
RAM: 1600Mhz is all you really need. The Vengeance RAM does look nicer, but beware clearance issues with CPU cooler fans. As you're planning on the fanless HR02, this won't be an issue.
SSD: OCZ Vertex 3 is coming pretty soon, so you might want to wait for that. If you need one right now, it's either the Crucial C300 or the Vertex 2E you want to look at.
HDD: My F3 is pretty much inaudible above the sound of the fans, though you can hear it when it spins up if you're paying attention.
GPU: The case allows for 14 inches of room, so I'm guessing even the upcoming Radeon 6990 will fit in. I have a KFA2 GTX 560 which vents into the case, but it's not particularly a problem as the fan in the bottom blows it out anyway. Performance-wise, for 1080p resolution a GTX 560 is plenty.
__________________
Old 1st Mar 2011, 18:18   #91
Elladene
Minimodder
Perfect info. Thx. I feel comfortable (and excited) to begin placing orders. Unfortunately, it will be a long wait to get the parts from store to my front door. At least I can get things rolling. I would like to, but do not have the patience, to wait any more for anything. Maybe I'll upgrade some bits in 12 months.
Once again, thx.
Old 3rd Mar 2011, 09:35   #92
Da_Rude_Baboon
What the?
Hi Elladene. I'm glad my posts have been useful to you. Is the PSU quiet? I'm not 100% sure yet as something in my case is making more noise than I like and I haven't worked out if its a fan, PSU or just the fact my computer sits on the desk (my old one was on the carpeted floor) and something is vibrating. The odd thing is the noise is a constant and does not change under load. Its like fan noise but with an odd rumbling. Tonight I'm going to unplug the fans and stop the PSU fan to see if I can work out what it is. Its not loud and I only notice it if I'm trying to sleep with the computer on.
I was playing Napoleon: Total War last night and my GPU was loud during play. I have never heard its fan spin up like that before but I don't think I've played a game which stresses it so much either. I would follow Silverstones advice and try and find a GPU which expels hot air out the rear of the case. I used the Vapour-X as its what I already had.
Old 3rd Mar 2011, 20:59   #93
morkfromork
Multimodder
morkfromork's Avatar
morkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremelmorkfromork has yet to learn the way of the Dremel
Some nice builds in here. When i first saw the ft03 i did not like it at all. But the more i see people using them and posting there pictures the more i like them. Might have to start looking at changing my raven rv02 and getting one of these.
Still think the hwite one looks nasty but the black one is sexy.
__________________
Mork calling Orson come in Orson.....
morkfromork is offline   Reply With Quote
Old 4th Mar 2011, 08:43   #94
Da_Rude_Baboon
What the?
Ignoring my previous intentions I ran the OCCT PSU test which puts the maximum strain on your CPU and GPU with the CPU over clocked (via autotune in the BIOS) to 4.1GHz last night. CPU temps after an hour were 64C and the GPU was 70C. Quite impressive for a passive setup and you could feel the heat coming from the computer.
The PSU is pretty quiet and I have identified the GPU intake (case) fan as the cause of my noise.
Old 4th Mar 2011, 09:04   #95
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.
Originally Posted by Da_Rude_Baboon View Post
...<snip>...The PSU is pretty quiet and I have identified the GPU intake (case) fan as the cause of my noise.
Is it the fan itself or is it causing a resonance through the case panel?
__________________
Gaming: [Silverstone FT01-BW][Asus Z68-V Pro/GEN3][i5-2500K@4.0GHz][Titan Fenrir][8GB 1866MHz][Asus GTX 580][Crucial M4 256GB][Xonar DX][Antec TP New 650w][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus P8P67-M Pro][i5-2500K][8GB 1600MHz][Asus 6850 DirectCU][Corsair Force 3 120GB][Seasonic S12 430w]
Kids: [Silverstone SG05B][Asus P8H61-I][Pentium G840][4GB 1333MHz][OCZ Vertex Plus R2 120GB][Dell E207WFP]
Projects: [Antec 300 improved] NAS 1: [Synology DS211j] NAS 2: [OpenMediaVault]
Fingers66 is offline   Reply With Quote
Old 4th Mar 2011, 13:34   #96
Da_Rude_Baboon
What the?
I don't know yet as its quite a 'congested' part of my build. I have the sata cables and several power cables routed through that area so it's not an area you can clearly see. The fan bracket is removable so it may be slightly loose or a screw that is not fully tightened. The case panels are very rigid so I would doubt the fan would cause any resonance there. I used the highly scientific process of plugging in the fans one by one until the noise started. I could investigate further or I could play Napoleon:TW and N:TW keeps on winning!
Old 6th Mar 2011, 04:29   #97
Rhinogobius
What's a Dremel?
Rhinogobius has yet to learn the way of the Dremel
Would like to know if you solved that noise issue, just about to build same set up and wonder if worth buying 3 replacement fans before i start. I am thinking of 3 x Noiseblocker BlackSilent PRO-PL2 which seem to have good balance of noise / airflow. Also how would you rate the noise of the fans which come with case, as i normally run fans of fan controllers and these just seem to connect to PSU and run on full. Thanks.
Rhinogobius is offline   Reply With Quote
Old 7th Mar 2011, 16:50   #98
GiantKiwi
I <3 Arduino Builds
GiantKiwi's Avatar
GiantKiwi has yet to learn the way of the Dremel
Considering making my rig slightly smaller, this case could be useful for it. So, 1. does anyone know if its possible to fit a corsair h50 at the top of the case in push/pull? I'm considering changing the motherboard i've got (rampage III extreme) for its smaller dimensioned sibling the III gene, my only worry being that an i7 950 does have a tendency to run rather hot. Also would like to attempt to fit my 2 6970's in the mix (yeah this could start to get fun) would it be possible?
so basically it will be this:
Current Rig:
Core i7 950
Corsair H50 /w Push/Pull
Rampage III Extreme
24GB Patriot Viper II Sector 7 1600MHz DDR3
2x XFX HD6970 CF
Corsair Pro Series Gold AX850
Coolermaster Stacker 832SE
change the motherboard to Rampage III Gene and change the case to the FT03, and keep everything else.
Would have hyperthreading on, but probably not bother with much or any overclock due to stability issues related to the RAM slots all being full.
thoughts?
__________________
http://valid.canardpc.com/cache/banner/2203311.png
PC: Intel Core i5 2500k @ 4.5GHz || Corsair H70 || Asus Maximus IV Gene / Gen 3.0 || 16GB Corsair Vengeance Low Profile 1600MHz DDR3 || XFX HD6950 Flashed to HD6970 || Corsair Pro Series Gold AX850 || Silverstone Temjin 08 Evolution
My Builds: Baritone Guitar
GiantKiwi is offline   Reply With Quote
Old 8th Mar 2011, 00:39   #99
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
I wouldn't put in two graphics cards - the second would be pulling air off the side of the case as there's very little ventilation other than from the base.
Or, drop them for a HD 6990. A little slower but single PCI-E slot.
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 8th Mar 2011, 09:39   #100
GiantKiwi
I <3 Arduino Builds
GiantKiwi's Avatar
only problem with that is i will need a sale on the current GPU's before i can afford that :/
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
