#141 |
The Keeper of History
be warned though. replacing a dash with a 'maybe armed' airbag is tricky and VERY expensive. Usually more than just replacing a blown airbag at up to $6000USD. Bomb disposal nasty.
__________________
My deepest gratitude to this community.
#142 |
Hate your face
So far everything is fine and they have started repairing it
It is still possible the airbag is damaged but, from what they can so far (the dash is still on), it looks fine. Therefore, the insurance gave the OK to start repairing the car . I saw it today and the windshield is off. They now need to remove the whole dash and clean its inside as well as the air vents because they're filled with dust and glass. Then they need to replace the ceiling and the backseat. Overall it should take quite a while before I get my car but at least 1) they're fixing it and 2) they lent me a 2011 Versa instead of the dreadful 2004 Sentra. I still can't wait to get my dropped Accord though ... I'm sitting almost as high as laurie drivers in the Versa
__________________
| i7 950 | 6GB | Sabertooth X58 | 2xGTX 570 | Force GT 120GB | 10.5TB total | X-1250 | Bravura X-Fi | Define R3 XL | H50 | 2233RZ 120Hz | |
#143 |
Did a skid that went for two weeks.
NICE
[/borat]
#144 |
Keep us posted as they remove the dash. I be here watching.
john
__________________
#145 |
Hate your face
they started working on the car. I'm far from getting it back because there are some parts that are back order. Minimum 3 more weeks (pure guess). If I'm right that means I will have been without my car for five weeks. Anyways, here's some pictures I took earlier today
__________________
#146 |
Cable management time?
__________________
#147 |
How many wifi's does it have?
HOLY *******iiiiiiiTTTT!
Insane stuff! Looks very scary indeed. Woooo! Change! Ok vote of the week: Will the change found on the floor on knuck's car be there when the car is finished repaired?
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#148 |
Change will evaporate mysteriously
__________________
#149 |
Hate your face
there was a dollar underneath the driver's seat and it's not there anymore
![]() come to think of it, there was a ton of change in the change compartment of the dash ... haha
__________________
#150 |
Blistering Barnacles
And will the giant Pot Noodle (pic 5) be consumed too ?
#151 | |
Multimodder
__________________
Mork calling Orson come in Orson..... |
#152 |
E-tailer Tailor
Looks like now's the time to get that iPod connection fitted...
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD |
#153 |
Hate your face
FTFY
__________________
#154 |
Geeked since 1982
Looking good so far. Amazing what needs to be taken apart to get at what they need to fix.
__________________
40D| 350D | 24-105 f/4L | 24-70 f/2.8 Sigma | 50mm f/1.8 | 75-300 f/4-5.6 Sigma | 420ex Speedlight
365 Daily Photograph | Smugmug |
#155 |
Go ahead, spell my name wrong.
__________________
Gigabyte EX58-UD5 | Intel i7 920 @stock | 6x2gb 1600Mhz Corsair Dominator | 560Ti Hawk | Tagan 480W EasyCon | Lian Li PC-A77FB | Samsung Syncmaster 2443 | Logitech Illuminated | Logitech G500 gog.com - Classic videogames, Windows 7 compatible, no DRM, bundled extras, outstanding service. Check it out, get hooked, spread the word! |
#156 |
CPC_refugee
__________________
Don't do today what you can put off until tomorrow Battlefield 3 adidan_uk BF3 Stats i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz // 250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64 |
#157 |
Hate your face
I don't believe you have this model in europe. Trust me, the original suspension makes the car look like a freaking truck.
I mean, look how high that freaking thing is !! ![]() ![]() Compared to mine ![]() ![]() That's an old pic with stupidly small tires. There were some Hankook 205/40/17 installed when I bought the car. I bought a set of Goodyear Eagle GT 215/45/17 the next summer and they fill the "hole" (not sure how to call this) even better than this. If you still think dropping the suspension of this car is a bad idea then I have lost faith in all of humanity
__________________
| i7 950 | 6GB | Sabertooth X58 | 2xGTX 570 | Force GT 120GB | 10.5TB total | X-1250 | Bravura X-Fi | Define R3 XL | H50 | 2233RZ 120Hz | Last edited by knuck; 5th Mar 2011 at 18:28. |
#158 |
Modder
Damn! I can't believe something like that can actually happen. Glad nobody was hurt.
#159 |
I like those tail lights! They are very early nsxish
I don't like the new accords as much, your shape is the best one, but she'd look better if you dropped the front another inch - this would improve handling at low speeds, but things would slowly get worse the faster you go... unless you correct things with a camber kit and stiffer rear end ![]() The last decade has seen too many cars just get uglier and uglier ![]() I must have missed it, so who's paying for the repairs? I hope it's the road authorities
#160 |
guys guys guys... It's Canada... lowering the suspension, even a bit, would mean having your car stuck every 3m with the snow in winter. And with Montreal premium road, his ass would be bruised up in 5min of drive in summer.
__________________
| Tags |
| knuck is a hero |
| Thread Tools | |
| View Mode | |
