Case Mod - In Progress !!! Project White Completed New Pictures on Page 16 !!!
Discussion in 'Project Logs' started by alain-s, 27 Feb 2011.
  1. alain-s
    alain-s Minimodder
    12 Jan 2011
    It is time for a new case mod project. After getting some ideas for my new build.
    The name of the project tells it already. It will be a nice clean white case. What case that it will be is not yet desisted the options are:
    Cooler Master ATCS 840
    Corsair Obsidian CC700D/800D
    SilverStone TJ07
    If my TJ07 cant be sold i will break it off and rebuild it again.
    The idea is to build a very nice and clean case mod as possible. the inside of the case will be white. The sleeve will be white/blue and maybe some grey in it but that i will see when i start the sleeve.
    For the Tubing i am not sure what it will be yet dual loop or not. It will probable be part copper pipes that will be nickel-ed with some normal tubing.
    I am also planning to water cool every thing with water except the memory.
    The water blocks will all be Plexiglas nickel and blue cooling water
    The hardware that will be used:
    Gigabyte P67 UD5
    Intel I5 2500K
    Kinston Hyper X 1600Mhz 2x4gb
    Corsair HX850W
    XFX HD 6970 in Xfire
    hier zijn al wat pic's van de hardware
    Gigabyte P67 UD5
    met I5 2500K
    XFX HD6970
    Corsair HX 850W
    These are the pictures from the hardware.
    I build it all in my old Antec P160W to test it on air.
    Because this is my first buildlog on the forum i added some links of my previous projects on other forums
    Project Umbrella
    http://forum.highflow.nl/f34/project-umbrella-7415/
    http://it-service.be/forum/index.php?topic=411.0
    Black Obsession
    http://forum.highflow.nl/f34/obsession-8572/
    http://it-service.be/forum/index.php?topic=492.0
    cu till the next update
  2. KidMod-Southpaw
    28 Sep 2010
    Looking forward to the rest of this! I hope to see some sleeving and lots more red epicness!
  3. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    This is a great project, i will follow :thumb:
  4. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx ^^
  5. alain-s
    alain-s Minimodder
    12 Jan 2011
    UPDATE 01
    The first update of my new build log. It is not much but better a small update then no update. ^^
    I have decided to keep my TJ07 and make a new build of it.
    Yesterday i started to brainstorm for some good ideas for my build.
    I wanted to make sure that i had a HDD hot swap and HDD cooling.
    So i started to make some samples in cardboard to see how it all would fit together.
    Here are some pictures of the process.
    As you can see there is a hole above the reservoir. I am going to make it bigger so i can put the reservoir in it. Then it can be used for fill port/reservoir.
    In the Front plate will come a hole with a dust filter behind it so when i need to clean it i can do it very easy.
    Where the fan grill is there will come a 10mm deep fan that can cool the HDD and make some airflow in the case.
    These are just the first ideas of how i want it there is still room to change stuff.
    Till the next update :p
  6. Sickbunny
    Sickbunny What's a Dremel?
    28 Feb 2011
    Excellent another white build, I cant wait to see what you come up with :)
  7. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx i am doing my best to keep it as clean as possible
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow the flip down front bezel is a really smart idea!
  9. Guest-23315
    Guest-23315 Guest
    I think I might have to 'borrow' that idea ;)
  10. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx
    :thumb:
  11. alain-s
    alain-s Minimodder
    12 Jan 2011
    UPDATE 02
    Hey everybody it is time for a small update.
    Yesterday and the day before i had some time at work to continue my modding work?
    I started as first with the motherboard tray. Got everything loose from each other and started with the drawings.
    To continue with drilling,cutting,sanding ^^
    Here are the pictures of the work.
    Nicely sanded with water.
    then the primer is going on.
    When i was waiting for the paint to dry. I had a idea to mod the small parts of the motherboard as well :p
    Drilling a few holes
    Drawing with pencil to get a better few of it and continued my work
    This is it for today
    Cya for the next update
  12. KidMod-Southpaw
    28 Sep 2010
    Nice details :)
    Looking very good!
  13. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx Kidmod
  14. rgrande
    rgrande What's a Dremel?
    7 Mar 2011
    Nice man! I'm following you project!! Good job and good luck.
  15. KidMod-Southpaw
    28 Sep 2010
    Please host your pictures elsewhere.
  16. Guinevere
    Guinevere Mega Mom
    8 May 2010
    What pictures ;)
  17. KidMod-Southpaw
    28 Sep 2010
    The magic disappearing ones? :worried: Bandwith exceeded.
  18. alain-s
    alain-s Minimodder
    12 Jan 2011
    Ye i know i am upgrading the acc so they will be back soon.
    Thx for following
    And lets make a small extra update with some new pictures
    UPDATE 03
    Paint update :p
    Not much to say of the painting that it involves a lot of sanding and painting :p
    Here are the pictures.
    Motherbordtray back together.
    That was it again.
    There is still a lot of stuff to paint in the next few days i will do my radiator.
    And i have to find something for the mid-plate.
    Atm i don't know what i will do with it but i am sure it will come to me. ^^
    After that it will be time to start on the frond of the case when the aluminum is arrived.
  19. Anubus
    Anubus Minimodder
    7 Jul 2008
    You have broken links there man.
  20. alain-s
    alain-s Minimodder
    12 Jan 2011
    All pictures are back now :D
