#21 |
Supermodder
Paint looks good
I'm following.
#22 |
Supermodder
Yesterday was a big day ^^
First i want to thank Highflow for there nice prices that i get in there webshop. ![]() ![]() ![]() ![]() With this help it is possible for the case to be painted by a professional painter. He can make sure that the outside and inside will perfectly done without any dust in the paint ^^ +Yesterday there was also a nice package in the mail ![]() From who would it be ^^ ![]() Idd from MDPC After long waiting i finely could have gone to the post office to get the package. The colors as you can see will be white blue grey Here are the pic's ![]() ![]() ![]() ![]() Soon i can begin to start the sleeving. But first i need to have done the inside of the case. So i can see what cables i need to make shorter or longer so that it is a perfect fit. on to the next update |
#23 |
Supermodder
Ye i do my best to get no dust in the paint but its not really that easy i had to do the motherboard tray 3 times to get it right :s
#24 |
Supermodder
Update 04
Hey Guys Yesterday i started to strip down my powersuply so i could start sleeving the cables that are hooked to the PSU. Here are some of the pictures. ![]() ![]() I have kept the labels of the PSU. Don't know if i will re use them or not.. ![]() I just had to pull 2 plugs to get everything out of the case. Well almost everything ^^ ![]() ![]() ![]() Removed the original Sleeve from corsair+i cut in advanced all my heath shrinks. ![]() ![]() 1st part done time for a brake to eat my dessert ^^ ![]() Finished the sleeving. ![]() ![]() ![]() Today at work i started with the case of the PSU. Going to do all the preparation so i can paint the case in white also. ![]() First of all i had to make a bigger hole for all the wires whit all the sleeve the original hole was to small. ![]() ![]() ![]() Sanded every piece before i spray the primer on it. ![]() The rest of the painting will be done tommorow when i am back at work. 1 Small thing I got the fan blades of the fan so i can paint them also. ![]() ![]() Next update will be when the PSU is done. Maybe when a package arrives from Highflow ^^ |
#25 |
Supermodder
Update 05
Today the mail man came with a very nice package from highflow. With just the right parts that i need to continue the build. Now i can start with the mid plate. I needed the reservoir so i could see where i had to make some holes. First I will show u guys what was in the package that i got from highflow ![]() Bitspower Crystal Link Tube For 3-Slots To fit between the 2 HD6970. ![]() EK-D5 X-TOP - White Acetal G1/4 Rev.2 This will fit very nice with the pump that is painted in white. ![]() ![]() Phobya Balancer 150 silver nickel ![]() ![]() Scythe 120MM Slip Stream SLIM 1200RPM This i will use to cool my HDD. The fan will be painted in white also. ![]() Aqua-Computer Temperature Sensor Inline 2x G1/4 ID for the in and out going temperature ![]() Aqua-Computer Sensor cable for (electronic) Flow Meters ![]() Bitspowder madness ![]() Bitspower G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini Silver Shiny 2pieces Bitspower G1/4 Silver Shiny Rotary 90 Degree ID 1/4 Adapter 2pieces Bitspower Multi-Link (SLI/CF) Adapter BP-WTP-C47 Silver Shining 16pieces Bitspower Multi-Link (SLI/CF) Adapter Mini BP-WTP-C48 Silver Shining 4pieces Bitspower 2xG1/4" Fillport Silver Shining Aqua-Computer kraan / verbinder Zilver (G1/4) ![]() ![]() ![]() ![]() ![]() So that was it. Now back to the build it self. I already painted a few pieces Pump, Radiator + Radiator stand, PSU casing + the van blades. Well pictures will tell the rest. ![]() ![]() ![]() I placed 2 labels back on the original place in case i should forgot what PSU that i am using ![]() ![]() I did a small mod on the PSU screws. Because they are black i had to find something to change it. So i sanded the head of the screw till i saw the metal. ^^ Left black screw right modded one. ![]() Then when that was finnished i putted the PSU back together. Dit was not really easy with all the sleeve in PSU also. But after some time it finally fitted together again. ![]() ![]() ![]() Her is a little sneak preview of how the buttom of the case will be. For the pump and flow meter i still need to make a stand off. ![]() ![]() Then for the front i need to order some Enermax 120MM Cluster white The copper pipe that u see will get a goat of nickel like all the other pipes that will come in the build. ![]() Up to the next Update ![]() |
#26 |
(づ。◕‿‿◕。)づ ︵ ┻━┻
Lookin' sweet!
![]() Can't wait to see when its all together!
#27 |
Supermodder
Thanks man
Update 06 Small update i didn't do allot these days. because i was more looking at my case then doing anything. Need to get a image of where i will put all the stuff in the case But while a was looking at it. I did some work on the top of the case i made the top hole bigger so my reservoir could fit in it. The reservoir it self will be a Aquacomputer Aquatube G1/4 Delrin White That also will be modified and will serve as a fill port. Here are some pictures of the hole before i started to make it bigger for the res. ![]() Because there was already a hole from my previous CM i had to come up with something to cover it up. ![]() ![]() ![]() Made 4 M3 holes for the mounting of the res so u don't see any screws on the out side of the case Now the reservoir I had to make some adjustments to it so it would fit perfectly. ![]() On the next picture u can see that i removes the edge around the res. ![]() ![]() ![]() ![]() The screws need to be gone they spoil the clean look of the case. So i when to the iron shop the get some new stuff ![]() bought some extra stuff to try out on the res for mounting. But first i handle the window of the res. ![]() ![]() ![]() ![]() ![]() Nice and clean looks allot better ^^ Now the mounting of the res ![]() ![]() Personally i like it this way its something different will replace the pvc spacers with aluminum ![]() I am also busy with a small HDD cage mod to cool the HDD. I saw the idea in build log from anG3L (Sors salutis) so why not try it my self removes the fan housing and i used some tape to stick it on the HDD cage ![]() ![]() ![]() this is where the HHD cage should come. ![]() The next steps are to mod the HDD cage it self and paint it together with HDD cooling. And maybe make the mounting mechanism for HDD cage it self. That is all for the next update. |
#28 |
(づ。◕‿‿◕。)づ ︵ ┻━┻
That res looks sweet
#29 |
Air Cooled Fool
Shrouldess fan, that's gangster!
__________________
- Q6600 G0(9x333) -- Asus P5k Premium -- 4GB Ballistix DDR2-800 -- EVGA GTX570 -- OCZ Vertex 2E 128GB -- 500GB Samsung F2 -- Antec Truepower New 650W -- Samsung Syncmaster 206BW -- Razer Lycosa, DeathAdder, and Destructor -- Custom Buitl Watercooled Case --
Pistol Pete's Project Perspiration Project Log |
#30 |
Multimodder
Just wondering how the airflow is affected by the removal of the shroud. Won't it make the air go side ways some? shure most of the air will probably go the right way but the airflow won't be the same.
#31 | |
Supermodder
#32 |
Topiary Golem
^^ Now it's mostly spinning the air around. That might be a good thing actually. It's not like much would get through the base of the cage anyway.
__________________
Project: Seawolf Project: 1 Project: Flux (est 2012) Modders make project logs. Project logs make mods. Mods make modders.
#33 | |||
Supermodder
Thanks it gives a cleaner look now with the screws sunk in to the Plexiglas
![]() Quote:
There is change of airflow indeed but it still works pretty good to cool the HDD. + I founded a new fan of Xigmatek that will come out in a few weeks and i probably will change it whit that fan + i will put 4 of them on my radiator. here is the link of it Xigmatek XOF-F1251 ![]() Need to say they are looking very nice
Last edited by alain-s; 31st Mar 2011 at 15:28. Reason: posted a picture of the fan |
#34 |
Supermodder
Mini update
Sadly i couldn't have done much this weekend. I forgot most of tools at work :s But did some small progress i made my midplate in clear plexi and i gave everything a position in the case first Cdrom, Aqua Computer, HDD Cage ![]() The Midplate ![]() ![]() I am still doubting if i will sand the midplate to get matt look or keep it clear. Then something else i like to get youre opinions for my loop I have made 3 difrent loops for my CM What loop looks the best ![]() Loop 1 ![]() Loop 2 ![]() Loop 3 ![]() Or something else i am open for any ideas ore tips. |
#35 |
Side bewb.
I prefer the last one
__________________
Bewbs. |
#36 |
Supermodder
I have no idea about watercooling. But i do know that the i5 you are using doesn't run the hottest. So would it be better to have the water go to the gfx cards first then to the cpu after......
__________________
Q6600 @ 3.0ghz | gigabyte g31m-es2l | 4gb crucial ballistix | 2GB XFX 6870 | antec 300 |Antec TruePower 550w | arctic cooling rev2 pro | 1tb wd caviar black
![]() Antec 300 mini mod |
#37 |
Side bewb.
Wouldn't make any difference really. The water temperature will reach a constant throughout the loop, won't make any difference.
__________________
Bewbs. |
#38 |
Supermodder
In that case id go for the 3rd loop. Least about of tubing needed... keep it clean and tidy.
__________________
#39 |
What's a Dremel?
WOW alain-s the paint looks amazing. did you wet sand it to get it so shiny? i am curious what kind of paint you used and how many coats.
good work keep it up |
#40 | |
Supermodder
started with a 400grid then 600grid paper then 1 layer of primer sand it again with 1000 then 1500grid then 2 layer of primer. after that i start sanding with 1500 grid and 2000grid then 1 layer of paint let it dry for a day sand it again with 2000grid and final layer of paint then i use motip paint |
| Thread Tools | |
| View Mode | |
