#41 |
What's a Dremel? Stop asking that!!
very nice paint job
#42 |
E22.BIZ
Think I'd go with the last one, gives a much nicer all round look and more balanced feel to the loop
![]() Coming along great dude, really like the colour scheme and the solid copper tubing :P |
#43 |
Project: Elegant-Li
Looking good so far, I'm looking forward to seeing more. Congrats on the MOTM nomination BTW
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#44 |
Supermodder
Thanks
![]() Here is a small teaser got no time for update but wanted to share this with your guys ^^
#45 |
Minimodder
Very good work alain!!
#46 |
Making You Feel Old Since 2010
Haven't looked at this in a while and needless to say I'm very impressed, I love the power supply!
Well done!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#47 | |
Supermodder
First off all i want to tank the Bit-Tech staff for putting my project in MOTM competition.
It is really a honor to be in MOTM competition. ^^ Quote:
#48 |
Supermodder
UPDATE 07
This week i worked on my bay holders. My first design that i have made wasn't really what i expected. Picture's will tell the story ![]() ![]() Personally i don't like it. It looks to basic and wouldn't really fit with the rest. I started to look for something else then and then i thought to use the original bay holders from Silverstone and redesign it. ^^ ![]() Putted some tape on it and start the drawings ![]() ![]() Cutted it out ![]() Then the finished product ![]() ![]() Mounted it to check if it would fit nice ![]() And yes it fits perfect ^^ ![]() Cdrom in it ![]() ![]() then the total picture ![]() ![]() ![]() The next thing to do fix the mounting for the HDD and make a new Cdrom holder |
#49 |
Project: Elegant-Li
Very nice optical Drive racks
__________________
#50 |
Addicted to modding.
This is MOTM material in the making... Looking quality already, love the bay mod.
#51 |
Supermodder
Thanks
#52 |
what was dat sandvich ?
i really like those round shapes !
__________________
My deviantart page : link Battlefield 3: Mindrusted My computer : Link |||||||||
#53 |
Supermodder
Nice and original
__________________
Q6600 @ 3.0ghz | gigabyte g31m-es2l | 4gb crucial ballistix | 2GB XFX 6870 | antec 300 |Antec TruePower 550w | arctic cooling rev2 pro | 1tb wd caviar black
![]() Antec 300 mini mod |
#54 |
Ultimate Modder
<--- This is me
#55 |
Supermodder
#56 |
Supermodder
UPDATE 08
Time for a update ^^ it has bin a while when i posted some progress. The reason here for was that i wasn't completely satisfied with the original idea of placing the HDD cage against the case. ![]() This is not really fitting with the rest of the parts. So started to dismantling the HDD cage and started to draw some new pieces. ![]() ![]() ![]() Dropped 1 piece :s ![]() Lucky for me that the pieces are going to be painted so i glued it back to getter. Here is the pcb from the hotswap. ![]() ![]() ![]() ![]() This is how it need to look like. ![]() Sanded all the pieces and putted every thing back to getter ![]() ![]() ![]() I even made some HDD cooling (fan will be replaced with a other 1 ![]() ![]() ![]() ![]() Mounted the hole thing against it ![]() Holes for the cables ![]() ![]() Then i also had to make a new Slimdrive holder ![]() ![]() ![]() The mounting mechanism can be changed but i don't know yet ![]() ![]() ![]() Like this i can cover up all the cables between the front plate en de plate behind it ![]() ![]() HDD in the hotswap ![]() ![]() This is it ^^ tomorrow i need to get some new screws to finish it off then this part is ready. |
#57 |
Keeping the design going there. Getting a decent frosted acrylic look is difficult but i didnt see much in the way of lines or uneven sanding so nice work there as well.
#58 |
Supermodder
thanks ^^
But the plan is to paint all the parts in white. |
#59 |
Supermodder
Update 09
Small update of the painting and the extra hardware that i got from a friend yesterday. First i dismantled my raptor HDD so i could paint the housing. ![]() I got some 2 component filler to remove the lian li logo's. ![]() ![]() ![]() ![]() 2 layers of primer and after that the white paint ![]() Then the other parts Before it started to paint those i did some miner improvement on the holes. So the bolts sink in the object. ![]() ![]() Painting ^^ ![]() Putting it all back together. ![]() ![]() ![]() ![]() ![]() Then the hardware that i got to borrow ![]() I got these part from from a very good friend. In the past i modded his Corsair 800D Here is a picture of the pc that i made for him. ![]() The parts that i got where GPU CPU motherboard ram. Asus HAD 4870x2 ![]() ![]() Motherboard is Asus P5Q PRO cpu is a core duo something and the ram dono what kind or speed labels are removed.![]() ![]() The next steps are sending my Gigabyte P67A UD5 back to the shop to get the B3 version of it. When i got my new motherboard i can start to build in all pieces. So i can start to cut and bend the copper pipes. |
#60 |
What's a Dremel?
Project White Update 21/04 HDD cage ready
fantastic project mate . but how did you do the 2nd sampl of CF ?? Also any pics of the roll cage , in a built from ??
| Thread Tools | |
| View Mode | |
