#101 |
Supermodder
Aaah no i don't put any sand in it.
It bends perfect like this i think u need sand when u use bigger pipes not really sure . |
#102 |
Multimodder
Wow! Amazing skills you have!
Quote "The black fans will be changed with white fans from silverstone" End quote I thank that letting them black could add a bit of contrast, but only you have the final picture in your head so...Let it snow! Let it snow! Let it snow!
#103 | |
Supermodder
Hardware Update ![]() Today they mail man came with a new package from Highflow^^ I show u guys what was in the box. ![]() What did i get. 5 Silverstone 120MM FM121 Silver Controller 2400RPM ![]() 1 Koolance CPU-370 ![]() ![]() ![]() 1 Aqua-Computer (electronic) Flow Meter (It is a shame that u cant find them in white so i need to find something on that .) ![]() Then also some fittings rubber sealings power connectors temp meter ![]() And also a Aqua-Computer Aquaero 5 XT USB fan controller, graphic LCD, touch control, IR ![]() ![]() ![]() ![]() And i got some new bolt to put everything together ![]() Now i can start with the pump and flow meter mounting plate Still need to draws and make it. But there are allot of other thing to do now also with my parts Last edited by alain-s; 4th May 2011 at 06:56. |
#105 |
Multimodder
I am looking forward to your incorporating the Aquaero. It looks fantastic.
#106 |
Stainless steel.. hmm..
Nice hardware!
Although I still think its a bit funny how over-engineered most fan controllers these days are.. I do really get why they are usefull because they also monitor temps etc. but I just wish the manufacturers could cut down on the "gamer factor". I don't think anyone needs constant temperature monitoring right on front view on the case, right? Anyway, I'm looking forward to the next update, I'm really digging the all-white colors scheme and the neat build!
__________________
English is not my native language. Please forgive me my mistakes.
#107 |
Supermodder
Ho-hoo, you are a talented man! I love your case so far!
__________________
Current projects: Tydirium is on the way! Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5| Follow me on Facebook |
#108 |
Project: Elegant-Li
Wow, lucky you with the new Aquero. I really like it but can't justify $170 Euro lol.
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#109 | ||
Supermodder
Thanks man
+ it will fit perfect in the project. I tested the aquero 5XT yesterday it looks a lot of fun but i cant find how to set the fan speed lol. The fans are spinning at full power i don't know how to turn them down. Think i need to check the aqua computer forum. Thanks a lot ^^ ye it is expensive but u get some nice hardware for in return. |
#110 |
Supermodder
Update 12
After a few days of playing with the Aquaero XT5 it is time to put my attention back on the case. this weekend i have made the pump stand. I couldn't really find a good design for it. I also wanted to make sure that the vibration from the pump wont go on to the case. Here some pictures of the stands Few weeks ago i bought these rubbers for the vibration. (first pictures are black and white GF borrowed the cam :s) ![]() First time i bended the plexiglass so i tried on a spare piece. ![]() ![]() It went well so i started with the good parts. I made 2 different stand to see what would be best fitted. Stand 1 ![]() ![]() ![]() ![]() ![]() ![]() Stand 2 ![]() ![]() ![]() ![]() ![]() ![]() Tested them in the case to see what would fit the best. ![]() ![]() ![]() ![]() Tbh i prefer the stand 1 even that it doesn't have the same features as the case parts. Well maybe a make a other 1 if cant get out of it. also did a very small mid on the silverstone fans ![]() And i did the power cables of the fans also to connect to the Aquaero ![]() ![]() Just need to make a cover for the back of it else u will see the mes with the wires ![]() Tonight i will brake my pc off so i can send my motherboard to the shop so i can get the B3 version of it. Lol i almost forgot to show u my first idea of the pump stand ![]() ![]() ![]() Good that i didn't go further on that idea it really looks bad after the other one's |
#111 |
Ultimate Modder
I REALLY love this mod buddy! Fantastic stand the design fits 100 % with the rest!!!!
#112 |
Linux User!
This build is AMAZING! Second stand fits in with the rest of the beautiful design you've got going on here. Keep up the good work and good luck!
__________________
Main Rig Phenom II X4 | Dark Rock Pro | GA-880GA-UD3H | GTX 460 | 2x2Gb HyperX Blu & 2x4Gb XMS3 | 250GB 840 SSD | 1TB + 3TB HDD | CM 690 II Advanced Laptop i5 24320M | nVidia GT540M | 4Gb RAM | 500GB HDD Steam, Origin, BFBC2, WoT: Pyr0660
#113 |
Hypermodder
The pump stand looks good.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#114 | ||
Supermodder
Thanks Voigts ![]() This night i tried a other design for my pump stand. I combined the first 2 designs and make 1 piece is it ^^ Drawing it on my last piece of plexi glass so it have to be right. ![]() ![]() ![]() ![]() ![]() placed the pump on the stand ![]() ![]() ![]() ![]() ![]() This is it ^^ |
#115 |
__________________
#116 |
Project: Elegant-Li
Nice work on the pump mount, it looks fantastic.
__________________
#117 |
Supermodder
#118 |
Supermodder
Small preview
#119 |
What's a Dremel?
I love copper pipes.
(pronounced as "I love turtles") Great Job, man.
#120 |
Supermodder
Update 13
After long days of filling and sanding the body is ready for paint. I only have to do the sidepanels now and then it can go to the painter. Last week i also received my new Motherboard Gigabyte P67-A UD5 B3 version So i installed it with he 2 HD 6970 so i can finish my loop. And i finished my pump also with the stand and the flow meter. But first the Case With my previous Project Umbrella i had to make some holes in the bottom of the case for the drain and some mounting holes. ![]() These are all gone now ![]() ![]() Removed all the scratches that i made on the top case ![]() ![]() ![]() After all the sanding it was time to put the case in to the shower to wash all the dirt off ![]() The pump Because the i had to turn the pump to put it on th stand i couldnt reach the the bottom to adjust the speed of the pump. I had to make something so i could still do it. without moving the pump Drill a hole ![]() ![]() ![]() Locktide on the screw so it wont move around ![]() Also finished up the stand of the pump. ![]() ![]() ![]() Like this i can still reach it without moving the pump around ![]() Replaced the power connector so i can plug it directly in to the PSU ![]() ![]() Because i couldn't find any white housing for the flow meter i decided to make it white my self ![]() ![]() ![]() ![]() The Motherboard Installed it on the tray with the HD 6970 ![]() ![]() ![]() Completed a other piece of the loop from CPU to GPU ![]() ![]() ![]() ![]() Tray in the case ![]() ![]() ![]() ![]() ![]() I only have to make the connection between the midplate and CPU and then is the loop completed then i can start the sanding and polishing of the pipes |
| Thread Tools | |
| View Mode | |
