#121 |
Stainless steel.. hmm..
Those copper pipes are Awesome! Man I love those.. Really neat bend/placed, too. I hope the sanding of those bend-wrinkles is not going to be a pain in the ass.. Nice work.
__________________
English is not my native language. Please forgive me my mistakes.
#122 |
Multimodder
Piping looks great. This is such a clean build. Good job.
#123 |
Project: Elegant-Li
I love the copper tubing, really sets this mod off from the rest. I hope you polish up the tube and varnish it so it stays nice and shiny
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#124 | ||
Supermodder
The pipes will get polished and after that they will get a coat of nickel on them so they will fit with the rest of the case ^^ |
#125 |
still thinking....
There is too much awesomeness here and not enough stars.
![]() The pipes will look terrific when plated. I am interested in how a seal is made in the connectors. Can you show/tell us? Is the end of the pipe flared for a compression joint?
__________________
stillthinking |
#126 |
Modder
Very inspiring work!
#127 |
Pump Killer
I know the wiring is not done yet, but as it looks now it's just sooooo clean!
![]() (is it wrong that I wanna lick the copper tubing? )
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#128 |
Dremel Molester
This is an amazing build. The copper tubing work is inspirational.
__________________
#129 | |
Hypermodder
One concern I have is the transference of pump vibration to the case using solid lines. I've done this before, and the pump vibrations really carried to the rest of the case. Using some tubing in and out of the pump really helps with this. The build is coming along nicely and is looking great.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence Last edited by voigts; 22nd May 2011 at 07:26. |
#130 |
Making You Feel Old Since 2010
STOP feeding my copper fetish!
This looks wonderful, absolutely love the whole thing, clean is the word. Well done.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#131 | |
Hypermodder
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#132 |
↓ Don't trust that face!
@Voigts -Yeah, US standard plays a lot of monkey numbers. A 2x4 is 1 1/2"x3 7/16", for example.
Maybe Bitspower will see this and take the hint. They have in the past. You might just see US diameter fittings some day. -Oh, and I popped in to say I love what you are doing. It makes my current copper setup look crap. ![]() @Angel - Don't do that. It tastes like blood. It's awful.
__________________
#133 | |||||||
Supermodder
^^ Its something new ![]() Quote:
I u want i can send some pipes to u so u can what ever u want with it ^^ Quote:
Thanks for the comment Quote:
#134 |
Moderate Modder
if you get some autosol or copper polish you can make the pipes almost pink (its a dirty job but worth the effort)
__________________
Watering down PC's since 2009.... |
#135 |
Noob Modder
Hi, VERY NICE BUILD
so jellous. Now I want to scrap my project Thanks Your white looks better than mine ![]() I will try take some inspiration from you . I still think the Enermax Clusters look better tho .
__________________
Project: Clean Est Finnish Time 2099
#136 |
Pump Killer
Damn... I just KNEW I'd one day regret not being a vampire...
__________________
#137 |
Supermodder
Today irecieved a package from Marnix AKA UgotHeinzzd
With Commandant nr4 and some extra O-rings for the fittings. Thanks for the tip and the stuff man ^^ ![]() ![]() When i came home i immediately started with polishing the pipes Copper pipes naturel ![]() Copper pipes sanded to 1000 grid. ![]() Copper pipes polished with Commandant nr4. ![]() and the result it is just WAUW ^^ ![]() Started with the pipes in the case that where sanded already. ![]() ![]() ![]() I really love the result of it i am falling in love with it ![]() |
#138 |
Now the pipes just look classy, i love it.
__________________
#139 |
Nice pipes! You were going to nickelplate them, right? If not, you should, lol.
And are you going to copper-fi the small ones between your graphic cards? Anyway, nice work.
__________________
#140 |
Multimodder
Polished pipes are outstanding & look great.
Keep up the good work. |
| Thread Tools | |
| View Mode | |
