#1 |
still thinking....
Cor Leonis
Welcome to my first water cooled project, Cor Leonis (heart of the lion).
I haven't made any drawings for this but I have prepared some sketch up images for the log to give you an idea of what's going on, so I'll get straight into it and explain as things progress. In the following images you can see that the graphics card will mount parallel to the motherboard with the aid of a PCIex extender. I've also included the two blocks here, and the thing to note is that there will be no tubing this side of the board. All the tubing will be around the back of the board, between it and the PSU. I'll leave any more details for the progression of the project, I think it's more interesting like that. ![]() ![]() ![]() I have already played around with making some water cooling gear for the past month. ![]() As usual I start building from the inside out. The first and central part is the motherboard/GFX tray. This is only a little different from the norm in that it not only holds the mobo but also has an extra level to hold the GFX card. This is made from 4mm plate and the only thing to measure initially is the width of the board I'm going to use (mATX). The length of this piece is just a guess including all the bends for the second tier. ![]() Now before work can progress its necessary to fit the motherboard. The positions for the standoffs are taken straight off the board. ![]() ![]() ![]() The GFX card is mocked up with the extender so I can get a look at where to mark the first bend and also to measure the height and where the standoffs for the GFX card will go. ![]() ![]() ![]() ![]() Then the details are cut and filed. ![]() ![]() ![]() I usually score the bend line to give a nice, tight bend, but with this thickness a score line wont be enough. I use my little trimmer with a 3 mm bit to make a trench 2 mm deep, then with a square file, make a ninety degree 'V'. ![]() ![]() ![]() The bends are then started in the brake but completed on the bench by hand. ![]() ![]() ![]() ![]() Then the standoffs and mobo refitted. ![]() Then some standoffs are fitted to the GFX card to get a look. The card is higher than I hoped but I wanted to retain access to all the connectors under it. I may swap the standoffs for some rubber grommets and get a few mm back. ![]() ![]() ![]() That's all I've done so far so I'll be back when some more works been done.
#2 |
theorycrafting
He's at it again...
Nice thoughts there, flipping the card around that way by using an PCIe-extender.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#3 |
dat steak
YES YES YES YES YES.
#4 |
Supermodder
Looks pretty interesting. Hope your not planning on using any of the other slots though....
__________________
WoT's: Xye_Sol Playing: Panther II, SU-8, PzIV, M2, M4A3E8, M36, Tetrarch, T43, T20, T50, JgdPnth, AMX13 75, ARL44
Mech_Antec: Xeon 3450@3.809GHz | Asus P7P55D-Evo (1808 BIOS)|Asus 6950|Corsair C300 128Gb|RAID 0 WD Cav. HTPC in Progress: E35M1-I DELUXE|Intel 320 Series 40Gb|2Tb Seagate Barracuda|The Dragon Reborn (Case) CNC Controller: E8500@3.3GHz (unable to push further)| Asus P5N-D|8800GTS|Barracuda 250Gb| Condensation (Case) |
#5 |
ReliXmas time!
I will be watching this one. Very promising start!
#6 | |
jack of all trades
Awesome beginning and love the block development, a little disappointed that you didn't go for anything more ambitious than a labyrinth, but your work can be considered nothing less than perfectionist. |
#7 |
Supermodder
Finally here... watching
__________________
***gtek-computerdesign.com*** |
#8 |
I Mod, Therefore I Own
I didn't notice the name of the OP, so I just started thinking "Crikey, this guy is good, very similar to OldNewBy
![]() Great to see you back at it again Attila, fantastic work on the bends. Do those GPU extenders work that efficiently? I have no reason not to believe they do, but always been hesitant about them.
__________________
ZiiP Gamestore [ZiiP] Gaming Community - IW BlackMailers and loonies abound! Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350. |
#9 | |
modeteer
Same as everyone else though mate, I'm excited to see this develop |
#10 |
↓ Don't trust that face!
Oh, sh*t!
This will be awesome fun. -Not for you, though. the control wiring is under the graphics card. Wiring that up is gonna suck, man. Edit: D*mn. No 90 degree SATA ports, either. I learned you can't fold a SATA wire directly off the plug not to long ago. They break really easy there. Make case/win kit for new case/win kit for new case... You've set up some kind of perpetual motion machine!
__________________
#11 |
Supermodder
I' ve already love it
#12 |
Is the daddy!
MOAR!!!!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#13 |
Ultimate Modder
Great start for once more brother, good luck with your built I will be watching!
#14 |
Sorry, for my bad english.
It will really nice!
And can you speak in hungarian?
#15 |
Who loves ya baby
The main man's at it again lol, really like the psu out the way behind the motherboard Attila and this is the first time I have been able to see one of yours from the start so really looking forward to it coming together dude! Great stuff!
__________________
BISMARCK |
#16 |
Making You Feel Old Since 2010
Yes, the messiah of filing has finally returned! Well done attila, I love the standoff for the GPU, more greatness to come I hope... Subbed
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#17 |
Avoiding the "I guess.." since 2004
Just one wish - knowing the thread will be flooded with praises and people crying for an update, could you please add the date of update to the topic each time ally you add something, so it's easy to see from the listing? Thanks!
Also just checked the water block stuff and am wondering if I should be crazy inspired or just leave the hobby, knowing I'll never make anything as pretty Needless to say, keeping an eye on this.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 |
#18 |
E22.BIZ
I must admit, I did get a little giddy when I saw the next project was starting
Glad to see your entering the mad world of water cooling Attila
#19 |
Hypermodder
Attila Goes water
![]() /follow !
#20 |
Multimodder
Great to see another project underway Atilla! Love your work, and not meaning to be a party-pooper, but why not simply use the blue cover block in your sketchup over the GPU to cover a koolance gpu-220 or Swiftech MCW80 gpu only block? I love your work, but I can't see a simple labyrinth/snake type design working as well as commercially available blocks.
Watercooling blocks have evolved away from those types of designs as they don't work very well compared to impingement plate & microfin/micropin blocks, and need high flow to perform well.
__________________
Project: Hush! |
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
