#181 | |
Keep calm & mod on. =)
![]() ![]() The 1 thing I dislike most about only being happy with 99.9% perfection is it really kills a budget ![]() the time consumption doesn't bother me too much with me having plenty of free time but breaking a budget does & I've gone way over budget already, in fact so far over I'd much rather not add it all up ![]() ![]() ![]() .
#182 | ||
still thinking....
Thanks for the replies.
![]() This file is tapered, but the greatest diameter of 7.8 mm is perfect for making these radii. This file is also fairly coarse, so it cuts very quickly. You need to always maintain perpendicularity to the surface you are filing in order to get a good finish. I think the position of the vice has a lot to do with being able to maintain square edges. ![]() ![]() ![]() Here's a photo of the inside edges done. ![]() Using a variety of files, any shape can be accurately made. ![]() ![]() ![]() ![]() ![]()
__________________
stillthinking |
#183 |
Supermodder
Nice work showing step by step process. Looking good
#185 |
Minimodder
Woow, u're work realized with files is amazing!!!
![]() What is the thickness of the alu' tray? I've the impression that is a little bit thick no? Very very very good job Attila!!
__________________
#186 |
Chunky good looking panel, most definitely built to last
I'd guess it's 10mm thick ![]() .
#187 | ||
still thinking....
Thanks guys.
__________________
stillthinking |
#188 |
So no need for any kind of bar frame supports, got it & yeah that sure does make for a super high quality clean look (the Attila trademark) love it
#189 |
has finished Blue Horizon
Sweet work Attilla
#190 |
WaterCooled fool
Man, I don't have the patience to hand file aluminum parts. Your work is truly outstanding.
#191 |
Never stuck with stock@Hotmods.net
Very, very nice work.
And, yeah - it's not too hard to file like that. Only, use the inside of your head, take your time, think about ways to create nice, straight edges, be quite critical as you go along and work slowly in order to be able to do quality checks on a regular basis.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#192 |
mod-envious
Awesome. The painstaking attention to detail and patience to achieve those oh so so clean lines is astounding
#193 | |||||
still thinking....
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() OK, once the two 'bulkheads' are almost finished, a few things still need to be done. The front part is significantly narrower than the rear. So I need to centre the two and fix them together. This is because, even though I measured, cut and filed very carefully, they are still not the same height. Also, some of the projections you can see are where the central plate fits. These have to be exactly the same height. ![]() Here you can see that one piece is about 0.5 mm or so too big. So this must be taken down to match the other part. In truth this is not really that critical but it's better to have them as close as possible. ![]() ![]() Next, these are the projections (not all of them) that hold the central plate. these are also not the same height. ![]() But to get in there, I need to 'mod' a file. ![]() ![]() ![]() I've used this file on every project and it's very flat, so it will be perfect to even things up in here. ![]() Here you can see the difference in height. ![]() So carefully, these are all brought to same height, all the while continuously checking that the edges are square. ![]() ![]() ![]() It gets progressively more time consuming as all the surfaces have to be brought down to last little 'low' spot. ![]() OK, now the fun part where I can get a first glimpse of what the chassis will look like. Now I always like to take measurements directly from the work, so in order to find out how big to make the lower tie plate, I need to assemble the bulkheads to the central plate. Because the two bulkheads are different sizes, supporting the central plate and then 'hanging' the two ends of it is the best way to take the measurements. ![]() ![]() And once the measurements are taken (and checked three times) the lower tie plate can be marked up on some 8 mm plate. ![]() But I have to go and pick up Anika now. Back soon.
__________________
stillthinking |
#194 |
Topiary Golem
Great workmanship! Where do you buy your files? Is the flat one a simple mill file or is it one of those specially made for alu?
__________________
Project: Seawolf Project: 1 Project: Flux (est 2012) Modders make project logs. Project logs make mods. Mods make modders.
#195 |
Ultimate Modder
The file God you are bro, period!
#196 |
The Keeper of History
Well Damn!!! That is how it's done? Next mod needs to be named Flawless Execution.
john
__________________
My deepest gratitude to this community.
#197 |
↓ Don't trust that face!
The cast iron set you have!
I would have been very hesitant to chop my favorite file up.
__________________
#198 |
Building and engineering enthusiast
Yeah I wonder too, how did you cut up your file?
#199 |
E-tailer Tailor
Looks like an angle grinder with a cutting disc to me. That should do the trick, even on tool steel.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD |
#200 |
Engineering The Extreme
Files are about 10 bucks a pop from mcmaster, I don't think its a travesty to cut the handle off of one
__________________
[Project] :::Mil-Spec::: @ Bit-Tech [Project] :::Flow::: @ Bit-Tech MOTY Second Prize ![]() |CPU: PHII 955 BE @ 3.8ghz | GPU: 2 x 4890 XXX @ 950 | 8gb Crucial ballistix tracer DDR3 1600 CL8| |
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
