Reply
Thread Tools View Mode
Old 2nd Mar 2011, 07:18   #41
brinkz0r
Hypermodder
brinkz0r's Avatar
brinkz0r has yet to learn the way of the Dremel
Good luck with the project Attila, I'll be watching closely
__________________
My casemodding company: Brink of Modding
My latest casemod: miXture
Custom reservoirs and more: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 2nd Mar 2011, 11:02   #42
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Originally Posted by GCOFIELDD View Post
Hey Attila, on another forum I saw a guy making bends the way you are (filing a grove before bending) and he used solder paste in the joint. It looked cleaner when he was done because you could not see the break in the material…just a thought.
Yeah I think I know who you're talking about, his work is terrific. Unfortunately I cant use that stuff because all the alu will be anodised. It will look fine when all finished. Thanks.
Originally Posted by jhanlon303 View Post
Mom!!! Attila is back too. Dueling masters? Attila vs Bod. wear out the keyboard going back and forth.
Haha welcome aboard John.
Originally Posted by Boscoe View Post
Sub'd! Mad work!
Thanks.
Originally Posted by lobster_johnson View Post
This is really exciting, Attila! I can't wait to see where this goes.
I'm a newbie when it comes to water cooling, but I found some info in an old book I bought the other day that you and others may be interested in. I'd love to see someone confirm this, even if it was written by an engineer.
From Cooling Techniques for Electronic Equipment, (1980) by Dave S. Steinberg:
Good luck with the project!
-Lobster
Thanks mate. Yes you can probably tell that I'm not overly concerned with corrosion. I've worked on many cars over the years and most have mixed metal cooling systems. I've seen what tap water does to the system. The pick-up I've been driving for the last 13 years has a cast iron block, an alloy head and brass radiator and heater element, Bi-metal thermostat etc. It's always been topped up with the green stuff and is still in excellent condition. There are some very good anti corrosion additives out there and I just have to use some.
Thanks a lot brinkz.
I may as well include this small update here as I showed a pic yesterday.
When I need to make small parts I always turn to the offcut pile under the bench. These pieces are from the base plate of Na'ir. 8 mm thick.
First, a corner is cut out and filed square. Then the shape can be marked up against this reference and cut and filed.
Then mounting holes are drilled into both the tray and the corner brackets. The tray has 3mm holes for the M3 screws to pass through and these are also countersunk. The corner pieces are tapped.
It's very strong and rigid now.
Now to this part will attach two of the three main bulkheads. But I'll leave that till the next (first) update.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 2nd Mar 2011, 12:02   #43
awratten
What's a Dremel?
awratten has yet to learn the way of the Dremel
Yet Again, Great workmanship. I can't wait to see the end result.
Who knows could be this years MOTY.
awratten is offline   Reply With Quote
Old 2nd Mar 2011, 12:30   #44
devilxc
Biding my time...
devilxc has yet to learn the way of the Dremel
Attila = sub'd!
Looking forward to this one. Great article in Custom PC btw.
devilxc is offline   Reply With Quote
Old 2nd Mar 2011, 14:15   #45
lucasrubini
Minimodder
lucasrubini's Avatar
lucasrubini has yet to learn the way of the Dremel
I love these metal works, especially those using thick metal pieces (I don't know why...). Yours is looking beautiful!
Where do you find these standoffs online? Tks
lucasrubini is offline   Reply With Quote
Old 2nd Mar 2011, 18:02   #46
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Yes, awesome cornerpieces. Much better than the standoffs made from threaded rod that I suggested.
Now, tell us all, please, how you file the edges in such good looking 45 degree angles. Surely, this can't be done using just a manually operated hand file?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 2nd Mar 2011, 18:37   #47
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Absolutely awesome sturdy supports & I forgot to comment about the custom pc feature, it was awesome .
Waynio is offline   Reply With Quote
Old 2nd Mar 2011, 19:19   #48
Archtronics
I *am* a Dremel
Archtronics's Avatar
Archtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for presidentArchtronics should be considered for president
Love your work do you shape most of it by hand?
Cant wait to see the rest of the design.
Mark
__________________
Now an Architect
Archtronics is offline   Reply With Quote
Old 2nd Mar 2011, 20:59   #49
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
Originally Posted by Cheapskate View Post
Make case/win kit for new case/win kit for new case... You've set up some kind of perpetual motion machine!
QFT :-)
And amazing work as usual!
murtoz is offline   Reply With Quote
Old 2nd Mar 2011, 21:34   #50
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
D**************mmmmn, baby! -This has, 'motherboard as frame' written all over it!
Ethylene Glycol has a down side. It works great to prevent boiling over in a high temp system, but when added to a pc system, it raises the temperatures. It also attacks polycarbonate. I learned the last on the hard way.
TL;DR= EG will overheat a rig. Use it sparingly.
Cheapskate is offline   Reply With Quote
Old 3rd Mar 2011, 05:09   #51
lucasrubini
Minimodder
Hi there,
Where can I find the standoffs you're using online, do you know?
Thanks!
Old 3rd Mar 2011, 07:48   #52
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Impressive, as usual!
nagyizom is offline   Reply With Quote
Old 3rd Mar 2011, 09:56   #53
Attila
still thinking....
Attila's Avatar
Thank you.
Originally Posted by devilxc View Post
Attila = sub'd!
Thanks. I haven't seen the mag (not available here) so I'm glad to hear it's OK.
Thanks. I bought those from a local electronics shop. Online? You'll have to look.
Thanks. Haha, yes it's done by hand, is very easy and very quick. 45 degrees? not sure, I just took the corners off till it looked OK.
Yeah thanks, that's two thumbs up for the article so it must be good.
Mark
Thanks. And yes.
Originally Posted by murtoz View Post
QFT :-)
Thanks murtoz.
Haha, don't get too attached to it. I've just made a re-design and the tray is going on the pile under the bench.
Yep I'm going to experiment with anything I can find and there is always the option to swap out the copper parts for alu as a last resort.
Thanks again nagy.
__________________
stillthinking
Old 3rd Mar 2011, 09:57   #54
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Hi there,
Thanks!
They look like they've been taken from a previously used case, but you can also order them from here (I dont know of any hardware/modding shops in Brazil)
Mankz is offline   Reply With Quote
Old 3rd Mar 2011, 15:23   #55
lucasrubini
Minimodder
Yep, it's hard to find those things here in Brazil, but I have some americans relatives that can send them through USPS
Thanks Mankz
Old 4th Mar 2011, 12:27   #56
Yemerich
I can has PERSUADETRON?
Yemerich's Avatar
Yemerich has yet to learn the way of the DremelYemerich has yet to learn the way of the DremelYemerich has yet to learn the way of the DremelYemerich has yet to learn the way of the DremelYemerich has yet to learn the way of the Dremel
I am really considering to make a alu case. Great deal of my inspiration for my next project come from your projects.
Kudos
Thanks Mankz
As a matter of fact, you can go to the "Santa Efigenia" street to get those. They have plenty of those things in the transversal streets. Not exactly sure where...
__________________
----------------------------- Yemerich -----------------------------
Hephaestus (best design Windows Vista Magazine - 2007, MotM nominee 2008)
Odinn (CCE best design in CP-Brazil 2008)
Hades (Best advanced casemod design CP-Brazil 2010)
Take a look on my projects here.
Yemerich is offline   Reply With Quote
Old 4th Mar 2011, 14:45   #57
Nitrixflare
Building and engineering enthusiast
Nitrixflare has yet to learn the way of the Dremel
wow that is amazing work! Could you please write a handbook or something? I'd definitely be the first one to get myself a copy! Really want to learn a lot from you.
Nitrixflare is offline   Reply With Quote
Old 4th Mar 2011, 15:22   #58
Marcos_Viegas
Supermodder
Marcos_Viegas's Avatar
Marcos_Viegas has yet to learn the way of the Dremel
WOW... i see another "case of year" coming...
__________________
My actual project:
Marcos_Viegas is offline   Reply With Quote
Old 5th Mar 2011, 23:44   #59
Waynio
Waynio's Avatar
Yeah I'm still not up to the challenge of grand file master Attila , but it's not just the workmanship that goes into his projects, the designs are incredible also oh & the never ending quest for sheer perfection .
Old 6th Mar 2011, 14:04   #60
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
Yet another A* project in the making
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
