#61 |
Modder
Re-organizing computer hardware for unique case design - sounds like I'm following this.
![]() Just one question, why full ATX form factor motherboard? |
#63 |
I am searching...
Looks good so far, will be keeping my eye on updates!
__________________
MOD : M-itx HTPC Scratch Build |
#64 | |
Multimodder
Cars can get away with mixed metal and Ethylene Glycol Systems because the is so much more heat produced over a larger area. The best way to ensure corrosion doesn't happen to you is to not mix metals. Would hate to see an Attila mod succumb to galvanic corrosion. -Your Friendly Neighborhood Metallurgist Last edited by saxman; 7th Mar 2011 at 13:22. |
#65 |
LIKE AN ANIMAL!
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#66 |
Kiwi in London
Subbed!
__________________
Gaming: [Silverstone TJ08-E][Asus Maximus Gene V][i5-3570K][Corsair H55][8GB Crucial Ballistix 1866MHz][Asus GTX 580][Samsung 840 Pro 256GB][Corsair HX650][Dell U2412M][Corsair K60] Main: [Lian Li PC-A04][Asus P8Z77-M Pro][i5-2500K][8GB 1600MHz][Asus 6850 DirectCU][Corsair Force 3 120GB][Seasonic S12 430w] Kids: [Silverstone SG05B][Asus P8H61-I][Pentium G840][4GB 1333MHz][OCZ Vertex Plus R2 120GB][Dell E207WFP] Projects: [Antec 300 improved] NAS 1: [Synology DS211j] NAS 2: [OpenMediaVault] |
#67 |
a.k.a KazeModz
wow very nice so far, although and I know its not really needed but I think a full coverage water block would just look cleaner but I understand that would be more difficult to design.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 • |
#68 |
Please... Just call me Stu.
I'm so impressed by those bends. Never seen a GPU orientation like that before, but it looks awesome. I'll be keeping an eye on this.
#69 |
Beef Potato Wheelman
After Nair... Subbed for sure!
__________________
No, I don't have a worthy signature. Fact is, I don't know why you're reading this. |
#70 |
Supermodder
I'm using the same GPU orientation in K3N. Good to see I'm not on my own in it
...And looking forward for the rest of course
__________________
***gtek-computerdesign.com*** |
#71 |
Hypermodder
I love the idea of changing the orientation of the GPU. That is an idea that I've already had in my mind for some point down the road. I don't really understand why you use such thick alu. That alu is like 3 times thicker than it needs to be to accomplish the same thing. I must say that those bends look excellent. I never get over your tenacity when it comes to filing.
I've been watercooling now for about 6 years, which may or may not mean squat, but I'll throw my 2 cents in here. I'm not trying to ride a hobby-horse, but as a general rule, there is good reason why watercoolers have harped and harped on not using alu with copper. There have been multiplied examples of corrosion. The Apogee GTX "military grade anodized" alu top was the apex of this. There were gobs of people that ended up with corroded tops. The gunk from corrosion will work its way throughout a loop. Koolance among others also used to make alu rads, which were nothing but trouble. It is because of the problems associated with corrosion that you don't see many alu watercooling parts anymore-thankfully. You won't have trouble in a car, as a car is designed to run 50/50 ethylene glycol. The corrosion inhibitors in the antifreeze moderate the problem. As most of us probably know however, ethylene glycol lowers the efficiency of the water in its ability to transfer heat. Hence, car radiators are sized accordingly to account for this. A really solid anodizing of the alu blocks can mitigate the corrosion issue as the anodizing creates a barrier between the alu and the water. The anodizing however needs to be flawless, as just one exposed part can lead to problems. If you run around 20% antifreeze or like substance with good corrosion inhibitors, and flush things out regularly, you can slow the corrosion process down to the point of being insignificant. Obviously its not the ethylene glycol that is needed in mixed-metal loops, it is the corrosion inhibitors included in antifreeze, and antifreeze is a cheap solution. Most people however don't want to mess with having to run corrosion inhibitors, and deal with any potential gunk issues. So to boil it down, if you get a good, solid anodizing layer on the blocks, use a good dose of anti-corrosive, and flush regularly, you will do fine. It is just so much easier using distilled water with a killcoil or biocide and being done with it. You also don't loose any heat transferring efficiency that may occur with certain anti-corrosives. Now I'll move on to admiring your excellent work as always.
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#72 |
I Endure
Diethylene glycol might be a better choice-it's more efficient than ethylene at corrosion protection, so it takes less to achieve the benefit.
If you were in the US, I'd HAZMAT-ship you some from the lab. I've got a fluid here that has a chunk of aluminum tied to a chunk of copper with steel wire and no corrosion after eight months. It's not even DEG but something more umm... strange but it's pretty much dead even with DI water for cooling capacity and still works just fine with any metals. If you ever get a hankering to mess with chemicals and want to try it, LMK and I'll get you the formulas. Also, for DEG, it's the same as G48 Glysantin (as opposed to G11 or G12 Pentosin) and in the US is marketed as Zerex G05 at NAPA and other auto supply chains. That's where I get mine, and I get it undyed as G05 so I can add any color I want to it. |
#73 | |
Where the bloody hell are ya'?
__________________
Current Project: Silent Element! || ASUS Rampage 3 Extreme, Intel i7 950, 3x2GB Corsair DDR3-2000Mhz, AMD Radeon 5870 1GB ||
|| Patriot Inferno 120GB SandForce SSD 2x Western Digital 640Gb raid 0, Western Digital 1Tb || || Apple MacBook Pro 13" Aluminium || |
#74 |
Side bewb.
Subbed!
__________________
Bewbs. |
#75 | |
There is no rep for awesomeness.
Moderator
Alternatively, some companies still reclaim Fluorinert (Perfluorcarbon PF-5080 or similar). A bit pricey but fill-and-forget: no corrosion, no conductivity, no bacterial growth: 100% inert.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#76 | ||||||||||||
still thinking....
You can start here.Haha., well thank you, but this may not even be finished this year. Though I'll try. ![]() Quote:
Thanks. Quote:
![]() Quote:
![]() Thanks. ![]() Quote:
![]() ![]() ![]() Quote:
![]() Quote:
![]() Thank you. ![]() Quote:
See below about the WC. Quote:
![]() Quote:
![]() Now, first of all, I cant believe this amazing response to the start of this project, WOW! Concerning the corrosion problem, thanks for all your replies and advice. I am aware of this problem and I will experiment with the system as a whole when I've made (and purchased) all the loop components. The aluminium parts will be hard anodised and if necessary, the copper parts will be re-made in alu as well. Some form of corrosion inhibitor will be used, and thanks to Kayin for the list of alternatives. That I'm not as concerned as some of you boils down to the fact that what I'm making here has a very limited working life (as a functioning PC, though not as an 'object'). This cooling system is designed and made specifically for this project, this case, this hardware etc. The CPU block will probably not be suitable for any other motherboard. In short this project has to function as a PC but it doesn't have to do this forever. Na'ir al Saif has been sitting on my desk since October last year being used as my main rig. It will be my main rig till it's replaced by this one. And on it goes................... I haven't been able to make anything really new because of some redesign work on the main parts of the chassis. Because of this, the mobo/GFX tray had to be re-made so this took some time but it actually saves time in the long run, because it makes the chassis much more rigid and also gets rid of six parts that were used to connect the old tray and two of the bulkheads to the third (front) bulkhead. So only a few pics this time, because I did some things differently from last time. Here you can see the new part is larger than the old one. ![]() ![]() I had some problems with the c/s on the old board but some lubricating fluid fixed that. ![]() Instead of routing a channel for the bends, this time, I cut a small trench with the hack saw and then filed the 'V' groove to depth. ![]() ![]() And the new part. ![]() ![]() ![]() Now, next time I should have something new to show you.
__________________
stillthinking |
#77 | |
still thinking....
) please share your info.
__________________
stillthinking |
#78 |
Topiary Golem
^^ Did you just quote 18 different questions in a single post? +repworthy!
Oh, and the case is coming along too!
__________________
Project: Seawolf Project: 1 Project: Flux (est 2012) Modders make project logs. Project logs make mods. Mods make modders.
#79 | |
In Flames we Trust
It's looking so awesome. crazy.
![]() When I checked some german watercooling stores for fluids for my build I saw the Double Protect Ultra from Aqua-Computer. Quote:
__________________
Scratch Build - Jestercon - MOTM Nominee Aug 2010 - building paused |
#80 |
Keep calm & mod on. =)
Wow $400 per litre
I would say get them to sponsor you but I think you'd be better off finding an alternative solution I love this method for bending thick alu, I first seen it on NavidsonRecord's log, I just didn't think too far into it that with some sturdy extra supports can make it totally strong .
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
