#81 |
Never stuck with stock@Hotmods.net
You ought to change "Still thinking" to "Still awesome"!
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#82 |
I *am* a Dremel
Love this stuff! Bookmarked.
Seeing the video card like this, wondering if it is possible to add another card 'mirrored' to the current card.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. In 1982 I was addicted to Lady Bug and played it in the local arcade (every day) And yes i'm proud I did that! |
#83 | |
__________________
#84 |
What's a Dremel?
Wow!!!!
![]() Awesome work! Congratulations! |
#85 |
↓ Don't trust that face!
DPUltra: "Water-based solution."
So it's the same as all the other pre-mixes on the market. I hope this one transforms. A transformer is the only way you can top yourself at this point.
__________________
#86 |
Supermodder
Very nice re-make Attila. Always thinking
Will make for a very clean "spine" if I see this right.
#87 |
Ultimate Modder
Wow a new part, this is perfection brother! Mod on I am watching carefully!!
#88 |
a.k.a KazeModz
love the redesign.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 • |
#89 | ||
There is no rep for awesomeness.
Moderator
Anyway, outstanding mod!
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#90 |
8-bit addict
Nice too see you up and running again Attila, I have been eagerly following this one on your page and was just waiting for it to pop up here aswell. The Alu work is awsome as always and I can imagine it took some time to mill out those chanels by hand.
good luck
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#91 |
Multimodder
nice work dude =D
#92 |
Just a Clumsy Ape
Attila, dude, your work is inspiring to say the least...
but your logs kill me!!! i need more updates!!! hahaha |
#93 | ||
Supermodder
![]() That will improve your surface area quite significantly. The other thing you have to consider is flow. This shouldn't be much of an issue but it is something to keep in mind. This block that I built a long while ago (~2.5 years?) came close to a Swiftech GTX when cooling a OCed E6600 and based on the matrix design shown above. Do note that the tolerences were much tighter in the below block. Took me about 6hrs to build using hand tools. ![]() mounted, and still running fine (pic is old and no water btw, don't have recent pics as I'm at college)! ![]() Yes, I know it's mixed metals, but I ran 50/50 mix of ethlyneglycol and water. Is it pretty? Hell no! Does it get the job done? Why, yes, yes it does: http://valid.canardpc.com/show_oc.php?id=670480 Temps were in the mid 60s IIRC. Prime 95 stable for like an hour or so. Quote:
#94 | |||
still thinking....
Thanks a lot everyone!
I hope you have as much fun following this as I'm having building it.And thanks for all that info shadow. Quote:
![]() Quote:
I've been pretty busy lately but that hasn't stopped me in the past. What has slowed me down is waiting for various parts. Also, I've re-fitted out Na'ir with some new hardware that is documented elsewhere. Another thing slowing me down has been the following.Massive cock-up with the GPU block. When I made the block, the part was measured up without taking the extender into account. The pic below illustrates what I mean.![]() So I've asked my friend at work to cut out the basic shape and I'll have to re-cut all the features. This has a step over the connector, It's a bit more bulky but meh. There's plenty of time to pretty it up.![]() ![]() I didn't really have a lot of time today so decided to just mount the fans to the radiator. ![]() Running short of bench space. ![]() ![]() OK, I've read several times now that it's a good idea to mount the fans a little away from the rad. So taking into account how much room I have to play with, Some spacers were made from some alu tube I had in my stock pile. This fits neatly inside the 'leg' of the fan. ![]() ![]() ![]() That works well so twelve were cut and filed to size. ![]() And this is the assembly. Another bracket will be made to fit this assembly to the rad compartment that will be sealed off from the rest of the case. I've changed the orientation of the rad from the SU drawings and it will sit sideways, sucking air in from one side and exhausting from the other. Lots of fins. ![]() ![]() ![]() While I'm on about fans, Some air flow will need to be created across the mobo/gfx card. To keep a low profile I've decided to use three eighty millimetre fans although these ones are just for planning and I will use something prettier later. ![]() But I have to go and put another load of washing on. See you soon.
__________________
stillthinking |
#95 |
Keep calm & mod on. =)
Wow the rad looks gorgeous with those fans & spacers &
at the build hanging , nice solution for the gpu cable.Awesome update Attila |
#97 |
jack of all trades
#98 |
A shroud is to keep the air focused & I can see it being difficult to keep the nice look it already has with a shroud, maybe some kind of nicely filed wooden pieces that fit inbetween the spacers & just below the fan frames, not sure on how they would attach but could look absolutely sweet
#99 |
What's a Dremel?
WOW, Love the Radiator...
so you can't get a PCI extender that sticks out the other side??? |
#100 |
has finished Blue Horizon
Sweet rad
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
