#141 |
Never stuck with stock@Hotmods.net
With all the alu work that you do, you REALLY need a CNC Router.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#142 |
Cad Pro Quo
Some good information here.
Essentially, if you put copper and aluminum together, you will dissolve the aluminum. This doesn't take into account the reactivity of the water that you put in, however. Yes, it will be 'pure' water initially, but as soon as it touches anything it will start sucking up ions, making it more and more conductive. Edit: A much easier to read table.
__________________
Completed: Acronym |
#143 |
Building and engineering enthusiast
@nutman: he does it all by hand, that's what makes him so amazing.
#144 |
Supermodder
All aluminum system end of topic
![]() Hi Attila very nice redo. Maybe some grooves or channels around the block would fit with your build
#145 | |||
still thinking....
But this would have it's down side, which I wont go into here.Quote:
, but brass is within acceptable limits. This could mean that the radiator can stay. ![]() Thanks mate. Quote:
![]() I had enough time (made enough ) to finish the channels and water feeds today.Drilling the holes first made routing much easier. ![]() ![]() Some of you may not know what I'm using to cut the channels. I'ts a Ryobi trimmer that takes 1/4 inch bits. With a 10 mm carbide bit. ![]() ![]() Dropping down vertical is a hit and miss affair so there are some rough spots, but I'm happy with the result. ![]() Then the feeds are drilled (10 mm). ![]() ![]() Now the shaded area is all useless material, so I may as well try some decoration on the way to removing it. If it works it can stay, if not it'll go. ![]() ![]()
__________________
stillthinking |
#146 |
Keep calm & mod on. =)
Attila you always amaze me & inspire me with your awesome manual ways
, sky's the limit it seems ![]() |
#147 |
LIKE AN ANIMAL!
Rough spots? Sure...
![]() Dude, this looks amazing!
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far. ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn Iä! Iä! Cthulhu fhtagn!
#148 |
Supermodder
Nice, now I see other side maybe some steps along that "V"
#149 |
↓ Don't trust that face!
Daaaang! I never built up the nerve to hand rout aluminum. any problems with it trying to grab?
I pretty sure you removed the excess already, but some perpendicular fins sawed into that area would be cool. -Just promise us you will mount the whole thing in a jig to do it...
__________________
#150 |
Yeah, it looks like Attila went about using the press drill and subsequently the router WITHOUT securing the piece in a jig - madness. Think about it breaking your fingers if not secured properly.
You must have the fingerstrength of the Hulk.
__________________
#151 |
Multimodder
This mod looks amazing!
How could I have missed it....
__________________
Sponsors on the Wave Project
#152 |
E-tailer Tailor
How did I not find this beforehand? A new Attila mod, no less?! Subbed!
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX750, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX 2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD |
#153 |
has finished Blue Horizon
Impressive work with that handheld router
#154 |
What's a Dremel?
Hi Attila! I am a admirer of your awesome metal work and attention to details! (been going tru all your work logs n website for the past 3days n counting...
) You've inspired me to start working on my scratch build... in ALUMINIUM of course!! Keep up the good work!! ![]() **Btw what drill press would you recommend/ you using? Thanks!
#155 |
still thinking....
Thanks a lot guys.
The router is hand held (very firmly with both hands). I haven't had any problems with it wanting to do it's own thing. The main problem is lowering the bit into the work, very hard to get it to go into the cut without taking a chunk out of the side. My drill press is set up 'just so'. This means, basically, that anytime the drill gets stuck in the work, the belts just 'slip' and I can turn off the drill and extricate the work piece from the drill bit. So, yes, I do hold most things with my left hand while drilling. As with anything to do with power tools., ALWAYS give 100 percent of your attention to the job at hand. I do not recommend doing anything as described above. @ Obsidian Rift., The drill press I bought about a year ago is a Chinese generic model made for a zillion different companies that just put thier name on the outside. You will be able to buy one like this or similar, anywhere in the world. This one cost me about $370 but I just received a catalogue in the mail, and this model is on sale for $280. Considering the good quality and the amount of materials and work that has gone into this, these prices are amazing. This drill press is a floor standing model, is big, heavy and well made. Here are some pic's. ![]()
__________________
stillthinking |
#156 |
Minimodder
This is some fantastic work. I wish I had the tools that you do in order to do some mods. Sadly, I must just use my dremel at the moment.
-ianclowe4c |
#157 |
Multimodder
Wow Great metal job. I like your style
#158 |
What's a Dremel?
Thanks for the reply! Will search tru the "zillions" of China supplier now! ;]
Really looking forward to your next update! Cheers! |
#159 | |
Supermodder
And don't manage to find time anymore for modding or extra money ![]() But great job so far!
#160 |
Minimodder
Hi!!
![]() I'me really fan of ur idea!! Place the GPU parallel at the motherboard is great!!! I shall be watching, keep up the good work. |
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
