Old 28th Mar 2011, 15:21   #161
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Attila, I love the drill press, but moreso the materials behind it and the seemingly nice workshop. Good stuff - could we perhaps have some pics of that shop where all the magic happens?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 28th Mar 2011, 20:12   #162
SNiiPE_DoGG
Engineering The Extreme
SNiiPE_DoGG's Avatar
SNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the DremelSNiiPE_DoGG has yet to learn the way of the Dremel
Well man, you certainly are giving the middle finger the the laws of watercooling, but it sure does look nice.
I'm sure you've got plenty of input from the fellows who are on the forums all the time, but if you ever need another WC guru's opinion or advice, you've got my info and I'm all ears
You sure do go at a breakneck pace! I am just beginning the designs for Mil-Spec, and you're on your second mod since we battle royaled at MOTY 09.
__________________
[Project] :::Mil-Spec::: @ Bit-Tech
[Project] :::Flow::: @ Bit-Tech MOTY Second Prize
|CPU: PHII 955 BE @ 3.8ghz | GPU: 2 x 4890 XXX @ 950 | 8gb Crucial ballistix tracer DDR3 1600 CL8|
SNiiPE_DoGG is offline   Reply With Quote
Old 28th Mar 2011, 22:47   #163
nat83c
What's a Dremel?
nat83c has yet to learn the way of the Dremel
Awesome, just awesome, and the fact it comes out of Australia makes it even better.
__________________
Microsoft is like an empty warehouse.... full of broken windows
nat83c is offline   Reply With Quote
Old 29th Mar 2011, 04:45   #164
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
This better be epic. I'm going to give you a run for the money this year for MOTY. I can't let you win three in a row!
Automatic vs. manual showdown!
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 29th Mar 2011, 04:49   #165
SNiiPE_DoGG
Vs the Auto-Manual Paddle shifters of my build! lets take it up a notch eh?
__________________
Old 29th Mar 2011, 06:40   #166
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Originally Posted by ianclowe4c View Post
This is some fantastic work. I wish I had the tools that you do in order to do some mods. Sadly, I must just use my dremel at the moment.
-ianclowe4c
Thank you. But you only need a jigsaw, a hand power drill and some files to make good parts.
Originally Posted by dream1 View Post
Wow Great metal job. I like your style
Thank you.
Originally Posted by Obsidian Rift View Post
Thanks for the reply! Will search tru the "zillions" of China supplier now! ;]
Really looking forward to your next update! Cheers!
Shouldn't be too long.
Originally Posted by Pelihirmu View Post
+1 for that, sadly And don't manage to find time anymore for modding or extra money
But great job so far! Subscribing
Thank you.
Originally Posted by Tonton Buddy View Post
Hi!!
I'me really fan of ur idea!!
Place the GPU parallel at the motherboard is great!!!
I shall be watching, keep up the good work.
Thanks Tonton. You already know I'm following your project.
OK. I built this small workshop just before Cygnus X1 was started (2008). It measures 3.33x 3.33 mtrs. It took about two months to build and with all my junk inside, it's a little cramped, but you've seen me do a lot of work outside so where there's a will, there's a way.
Thanks mate. And thanks for the offer of advice but the guys here have already 'Ripped me a new one'.
Thanks mate.
Haha., well I don't think you guys will competing against this one. It's unlikely that this will be finished this year (of course I could be wrong, as I often am). .......................................... ...But............................................ .
.....I'll be starting 'Arrakis' in a couple of months and this may be your competition.
Back to the build. I just couldn't get the original layout of components to work properly so this layout, that looks fairly conventional, was arrived at. The advantages of this scheme is that the case is now much narrower, it's not as tall, the exhaust from the rad will direct air overl the boards, and a side benefit, if my cooling system is just arse (which it may well be. ) then there is enough room on the viewing side of the boards to rip out my blocks and fit manufactured blocks.
Next time I will be back with the bulkheads.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 29th Mar 2011, 07:56   #167
Tonton Buddy
Minimodder
Tonton Buddy's Avatar
Tonton Buddy has yet to learn the way of the Dremel
Hi
Yes i saw! Thanks
I had there is some time a similar idea to yours, but I am not enough equipped in tool to realize it and especialy, i miss space and time to work.
Your workshop is my dream!!! Me i've just a mobile toolbox workshop and some handtools for work, but it's already enough for realize some little work.
Tonton Buddy is offline   Reply With Quote
Old 29th Mar 2011, 08:04   #168
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
Sweet workshop , if only UK weather was good enough for me to work outside
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Old 29th Mar 2011, 08:39   #169
alain-s
Supermodder
alain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremelalain-s has yet to learn the way of the Dremel
Dam idd a nice work shop
alain-s is online now   Reply With Quote
Old 29th Mar 2011, 09:27   #170
Nutman
Nutman's Avatar
Thanks for the awesome workshop pics!
__________________
Old 30th Mar 2011, 18:02   #171
andy_mcp1
I may have an I.D-10T error...
andy_mcp1's Avatar
andy_mcp1 has yet to learn the way of the Dremelandy_mcp1 has yet to learn the way of the Dremelandy_mcp1 has yet to learn the way of the Dremelandy_mcp1 has yet to learn the way of the Dremelandy_mcp1 has yet to learn the way of the Dremel
Looking top notch as always. Have to admit that I'm a little jealous of that workshop, beats working out of the conservatory.
Your design is awesome! I've spent a great deal of time in Sketch-Up trying out different orientations of the components using PCI risers etc. Is it just me or is the PSU a real pain in the... I find that it hinders what you can do with the design by dictating the min height or width of the case, it really does limit how small/ thin you can go no matter how well laid out the rest of the components are. Rant over...
Have always had an urge to design my own water blocks but I never took the plunge because I thought that a) it wouldn’t be possible to manufacture it at home without it looking cobbled together b) able to achieve adequate cooling from them (would the CPU just cook without all those years of industry experience behind the design). However I stand corrected on the construction front and this project has shown me that you can break away from the norm and create whatever you like with just a drill and router and still make it look sexier than what’s on offer in the market. +rep for taking the plunge and pulling it off. Will be very interested to see how this performs in cooling terms, if it sit on par with air cooling then I think I might join you and attempt making some custom blocks for the next project.
Keep up the good work!
andy_mcp1 is offline   Reply With Quote
Old 30th Mar 2011, 18:28   #172
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Good speech andy but psu's can be mounted side ways too to keep a slim build but just checked what you said again & you said height or width but that could make it so you have the storage in front of the psu .
Oh wow I missed checking the update before commenting .
Very nice diy workshop Attila awesome in fact & see you are going to be mod juggling soon, awesome .
Last edited by Waynio; 30th Mar 2011 at 18:33. Reason: Oh wow I missed checking the update before commenting
Waynio is offline   Reply With Quote
Old 30th Mar 2011, 18:54   #173
EvoDOOM
Multimodder
EvoDOOM has yet to learn the way of the DremelEvoDOOM has yet to learn the way of the DremelEvoDOOM has yet to learn the way of the Dremel
Nice workshop, cant wait to see this finished
EvoDOOM is offline   Reply With Quote
Old 4th Apr 2011, 10:33   #174
Attila
still thinking....
Attila's Avatar
Hi
Yes i saw! Thanks
Yes it's amazing what can be accomplished with just a few tools.
Very lucky with the weather here.
Thanks.
Thanks. You hit the nail on the head with the PSU. This one component has caused me to waste hours, no, days. I come up with a nice design only to be frustrated by the PSU, and end up putting it in exactly the same place every time.
Regarding the home made blocks, I would be overjoyed if they equalled good air cooling in their performance.
Thanks. I'm still working but the parts that are being made now take a long, long time.
__________________
stillthinking
Old 4th Apr 2011, 10:52   #175
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
are you going to plug the gaps between the rads and the fans?
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 4th Apr 2011, 17:18   #176
Nutman
Nutman's Avatar
Damn, that's awesome filing. Runs sooo perfectly along those lines.
__________________
Old 4th Apr 2011, 19:35   #177
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
How do you make those inner radiuses? I'm having a hard time trying trying to file a perfect circle consistent along the edge.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 4th Apr 2011, 20:17   #178
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Don't want to speak for Atilla but doesn't he use round files?
__________________
Razer2007 is offline   Reply With Quote
Old 4th Apr 2011, 21:49   #179
skreenname
Allons-y!
skreenname's Avatar
skreenname has yet to learn the way of the Dremel
You're a fooking machine, man.
So precise!
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________
Zotac ION-ITX-A-U | 2GB A-Data DDR2 800
skreenname is offline   Reply With Quote
Old 4th Apr 2011, 22:07   #180
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for president
Awesome build! I NEED to see how this turns out!!
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
