Reply
Thread Tools View Mode
Old 1st Mar 2011, 20:42   #1
thechoozen
Hypermodder
thechoozen's Avatar
thechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysis
Corsair Graphite 490T bullet - update: 150811 - Final Pics before Gamescom
Last Sunday we decided to start a new project, the reason is easy to explain....we couldnīt make any progress on our Pirates Case, because it was already packed and ready for the cebit.
We also had a few cases staying around us, so we thought why not create a new mini itx optimized version of one of them....so we finally picked a Corsair Graphite 600 T as our Base and started to disassemble it....
Our Plan for this Mod is also easy to explain, weīre going to reduce the height of the case about 11 cm, so that we could still integrate a full size PSU, a big Graphic Card and a watercooling setup beside the mini Itx System....
after disassembling all parts we cutted all parts into 3 parts so that we could take away approx. 11 cm in the height of the case....
then...we started to rebuild the case...
thechoozen is offline   Reply With Quote
Old 1st Mar 2011, 21:17   #2
pyro1son
Linux User!
pyro1son's Avatar
pyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremel
going to be watching this one. looks great!
__________________
Main Rig
4670K @ 4.00GHz | Dark Rock Pro | Z97 Gaming 7 | GTX 970 | 2x2Gb HyperX Blu & 2x4Gb XMS3 | 250GB 840 SSD | 1TB + 3TB HDD | CM 690 II Advanced
Laptop
i5 24320M | nVidia GT540M | 4Gb RAM | 500GB HDD
Steam, Origin, BFBC2, WoT: Pyr0660
pyro1son is offline   Reply With Quote
Old 1st Mar 2011, 21:19   #3
KidMod-Southpaw
Super Spamming Saiyan
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
Agreed, subbed for something very new! For example, first time I've seen a 200mm intake an a mini ITX case!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 2nd Mar 2011, 10:13   #4
ThirtyQuidKid
Supermodder
ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.ThirtyQuidKid is the Cheesecake. Relix smiles down upon them.
Another interesting mod. Like to see the finished article here.
ThirtyQuidKid is offline   Reply With Quote
Old 2nd Mar 2011, 10:25   #5
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
Reminds me of Coolmiester's mini-Cosmos
Mankz is offline   Reply With Quote
Old 2nd Mar 2011, 18:20   #6
JCBeastie
Supermodder
JCBeastie's Avatar
JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.
Not even finished and I'm certain I want one! :P
JCBeastie is offline   Reply With Quote
Old 4th Mar 2011, 22:22   #7
thechoozen
Hypermodder
thechoozen's Avatar
thx m8īs!!!
in the last days we made a lot of progress, but too sad...itīs not really visible....
what we did is quick to explain....after cutting all parts into several pieces....we had to reconnect them.....
So one of the first things we did, was to bend a few angles which should help us to reconnect all pieces and bring more stability to the cutted edges. After that we still had a few gaps and slits which had to be filled with a bit of filler/putty. While filling all gaps, we also filled this small designed by Corsair lettering which was embossed into the mainbase.
Beside that we also changed the lighting color of the 2 x 200mm Fans from white to orange.
And last but not least we sprayed a first coat of test laquer on the first parts, so that we could see which parts still needs some work......
Old 5th Mar 2011, 00:01   #8
morkfromork
Supermodder
morkfromork's Avatar
morkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for presidentmorkfromork should be considered for president
Awesome mod. I don't like the look of the 490 case but it's starting to look good as an itx case.
Have subbed and can not wait to see the finished job.
__________________
Mork calling Orson come in Orson.....
morkfromork is offline   Reply With Quote
Old 5th Mar 2011, 17:58   #9
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Whahah This looks awesome !
k.3nny is offline   Reply With Quote
Old 5th Mar 2011, 19:08   #10
KidMod-Southpaw
Agreed, I want to see the whole thing with the panels and plastic on!
__________________
Old 5th Mar 2011, 20:05   #11
ThirtyQuidKid
Supermodder
The cut and shut PC is shaping up very well.
Really good effort and results starting to show.
Old 7th Mar 2011, 20:10   #12
thechoozen
Hypermodder
thechoozen's Avatar
thx a lot m8īs!!!
me too, but that will took a few days ...until all parts are ready .... (not to mention that we already tested if all parts can be assembled as they should )
in the last days we made a bit of progress....atm the inner case is nearly finished so that you canīt see where we made the cuts....the plastic parts still needs some work...but as soon as theyīre finished you wonīt find a scratch on them
Beside that we also started to build a midplate / PSU Cover and an HDD tray which will be placed under the midplate....
Old 7th Mar 2011, 20:46   #13
pyro1son
Linux User!
pyro1son's Avatar
Sweeeeeeeet!
__________________
Main Rig
Laptop
Old 7th Mar 2011, 21:00   #14
k.3nny
Hypermodder
k.3nny's Avatar
Ow my !
Verry small and neat update !
Old 8th Mar 2011, 00:06   #15
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
liking the direction this is heading
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 8th Mar 2011, 00:47   #16
MarcosLFV
What's a Dremel?
MarcosLFV has yet to learn the way of the Dremel
Very nice!
MarcosLFV is offline   Reply With Quote
Old 8th Mar 2011, 18:23   #17
MarcosLFV
What's a Dremel?
That shrink case are cool
Congratulations!
Old 9th Mar 2011, 00:44   #18
Pulga DSTV
What's a Dremel?
Pulga DSTV has yet to learn the way of the Dremel
Needless to say much
Fine Design
Pulga DSTV is offline   Reply With Quote
Old 10th Mar 2011, 07:08   #19
thechoozen
Hypermodder
thechoozen's Avatar
thx!!
yesterday we "finished" the cover for the bottom of the case, for that we add another piece of metal to the prepared cover and added the first coat of paint...beside that we drilled all holes in the hdd drive cage.
We also prepared the side panel for the next cuts ...so that we can continue the work on it today...
Old 10th Mar 2011, 19:31   #20
KidMod-Southpaw
Yums! I love dinky builds!
__________________
Reply
Tags
490t, babetech.de, bt-custompc.de, corsair graphite 600t, thechoozen
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
