Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 6th Mar 2011, 15:27   #1
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpitmars-bar-man is almost as Godly as yodasarmpit
Most relevant study to date.
This is what real scientists work on.
Link. (May be slightly NSFW).
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 6th Mar 2011, 16:57   #2
Pete J
The upgrade bug biteth...
Pete J's Avatar
Pete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on you
Half were told to refrain from looking at breasts for five years
FIVE YEARS?!
I wonder if there's an optimum size of breast to look at as well?
__________________
Lian Li PC-P80B / EVGA Classified 3 / i7 920 D0 @ 4043GHz (no HT) / NH-U12P / 3x4GB Corsair Vengeance @ 1544MHz 8-8-8-24-1T / 3x EVGA 3GB GTX 660 Ti SC+ @ 1150MHz core boost 7400MHz memory / X-Fi Titanium Professional / 2 x 250GB Samsung 840 / 120GB Vertex 2 / 2x1TB RAID0 Spinpoint F1 / 2TB WD Caviar Green / Silverstone 1500W / 3007WFP-HC / 2407WFP / Beyerdynamic MMX300 / Logitech K350 Wireless Curve / Razer Mamba (2012) / Sidewinder Force Feedback 2 / Datacolor Spyder3 / Windows 7 Ultimate x64
Pete J is offline   Reply With Quote
Old 6th Mar 2011, 17:05   #3
Rotcrack
Food Maestro.
Rotcrack's Avatar
Rotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run CrysisRotcrack can run Crysis
Must be slightly off, what kind of guy would have that self restraint?
__________________
"Are there any experienced suicide bombers?"
Originally Posted by Krikkit View Post
PETA can sod off tbh, cocksuckers.
Rotcrack is offline   Reply With Quote
Old 6th Mar 2011, 18:01   #4
Malvolio
Keep calm and canter on.
Malvolio's Avatar
Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.
I think it works via a scale: the farther away you are, the bigger they need to be?
__________________
MC and Ellie FIX it!
It's a comic I do. With dolls.
Occasionally it's funny.
Malvolio is offline   Reply With Quote
Old 6th Mar 2011, 18:06   #5
samkiller42
Considered for President!! Moi??
samkiller42's Avatar
samkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for president
Haha, Only in Germany too
Sam
__________________
The Laptop: Dell Vostro 3450, SB i3 2350m, 8GB DDR3, 256GB 830 SSD, Intel 6235 Wifi N/BT 4.0, Dell 5550 3G/GPS
The Server: Phenom 2 x6, 8GB DDR3, 3TB Seagate, 2TB WD Green, 2*1TB Samsung F1
samkiller42 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
