#1 |
Multimodder
Project reborn, a simple PowerMac G5 mod, final picture 14/4/11
it has been a year since i mod.
now it is time to re-polish my skills. the victim for this project is ![]() it will be just a simple conversion for common form factor to be used. the initial plan is to keep the case form being chopped. Last edited by tjay@TJ; 14th Apr 2011 at 04:38. |
#2 |
Multimodder
some picture to do the talking
some older lian li case to donate its panel for bracket. ![]() bended ![]() this picture will show u how it is mounted. ![]() ![]() beside that a psu mount bracket was also created.
#3 |
The Keeper of History
Another G5 mod. Several of us have done them.
I watch. john
__________________
My deepest gratitude to this community.
#4 |
Multimodder
thanks.
i has been follow most if not all of the g5 mod, getting inspiration and tips from them. well, i started this project in febuary, i still have some more picture to post. more to come after i rearrange my photo |
#5 |
Multimodder
since i dislike the 1st version of the bracket i mad, i decide to make a new one.
![]() ![]() fan mounting. ![]() cut some arcylic pieces ![]() this is how it looks like at the moment. ![]()
#6 |
Hypermodder
I used to work on a G5 at my work and those are some nice cases if you ask me. I like to see people modding them, it kinda makes me laugh to see a Macintosh being stripped for its beautiful exterior.
#7 |
What's a Dremel?
Great work with that case
#8 | |
Multimodder
thanks. |
#9 |
Multimodder
update
cut some slot for the pci bracket on the arcylic which use to mount the motherboard. ![]() ![]() and also cut the upper divider try for psu breathing hole. ![]() ![]() and also some hole for cable routing ![]() in the process. i break my jr saw. ![]() the blade was not broken even once. |
#10 |
Nice cuts in the tray. sorry about the saw.
john
__________________
#11 |
Multimodder
thanks john.
#12 |
Multimodder
yay~ new update.
tap the bracket using screw ( cant find tapper in this country )![]() also the spacer is placed. ![]() ![]() original mac hdd cage ![]() ![]() problem ![]() ![]() ![]() the hdd cage will hit the motherboard. well i guess i had to find the solution. some other things ![]() ![]() this lian li bracket will be placed infront as intake thanks for watching and see you soon. |
#13 |
Building Proxima
Aaaah too much G5 mods going on. I gotta make mine (which will start in a few weeks) better!
mwahaha. But no worrines. I will watch and lurk
__________________
Proxima - The log of Dreams
CAGE - MOTM September 2010 Winner ------------------------------------------------------ LOSIAS.net Losias.net Facebook :: Losias.net Twitter |
#14 |
What's a Dremel?
Hello!
Nice work, I'm watching you
#15 | |
Multimodder
![]() thanks. i will be watching urs too.
#16 |
Multimodder
been facing quite a few small problem.
1st is the hdd cage. (not enough space for it and the g5 air baffle /deflector in place) ![]() 2nd is the front IO cable. (not long enough for it to reach, i managed to burn a speaker by plugging in the wrong pin )![]() ![]() ![]() ![]()
#17 |
Multimodder
before giving up or taking some rest form modding.
i managed to do some test fitting with some hardware. hardware use will be going in the g5 case. processor - intel i5 750 motherboard - asus p7p55d-e-pro ram - corsair xms3 2x2 gb graphic - gigabyte gtx 260+ psu - gigabyte odin gt 550w (not seen yet) hdd - WD 808gb (not seen yet) ![]() ![]() ![]() u can see about the wire will have no space to route once the psu placed. ![]() ![]() the g5 and my current lian li g7b ![]() hardware gutted out ![]() that is all. more work is being done. seen u soon. |
#18 |
Minimodder
If Apple does one thing right every time its make beautiful cases. Me watch.
Maybe you can mount the HDD rack standing up. Or if you can find a small enough one on its side. |
#19 |
Pump Killer
What strikes me is the genious way you made the bracket for the GFX. Just pushing it a bit further in. It's frikkin awesome! Why didn't I think of that!? That would have saved me 2 billion years in workarounds!
Loving it!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#20 | ||
Multimodder
ur project was the inspiration for this mod. the bracket is design to be used with this converter. ![]() it will fit exactly into the space in between. beside that, the apple io port which i cut will fit into the original position without any problem with this bracket.
| Tags |
| apple, g5, mod, powermac, powermac g5 mod |
| Thread Tools | |
| View Mode | |
