#21 |
Minimodder
Awesome work so far dude. I'm gonna get started on my g5 mod soon too
![]() Do you have a pinout guide for the front panel? I've scoured the internet and can't seem to find one. Would be much appreciated!
__________________
NZXT Lexa (Sexy Lexy) blackline evga 750i FTW SLI E8400 @ 3.6ghz 4GB OCZ Reaper EVGA GTX 260 FTW edition |
#23 |
Minimodder
Awesome. Thanks!
__________________
#24 |
Minimodder
Great work.
#25 |
Multimodder
#26 |
Multimodder
well. this project is not dead, yet.
just been facing with lot of difficulty and stupid error. as u can see. i have started the back io port mod ![]() make a bracket for the io port to be fitted to the case. ![]() as u can see. it didnt fit ![]() ![]() looks like i made the wrong way ![]() ![]() ![]() will try to fit it before finishing other part. before than. replacement for the apple hdd tray this ![]() or this ![]() thanks for taking a look. |
#27 |
Multimodder
after 2 weeks of trying, 2 times failure.
i finally managed to secure the back io port. ![]() ![]() some wired things on the LAN port. ![]() ![]() i found out it is the magnetic coil inside the port. this made a great setback to the plan i had. we will see how it goes in the end. the soldering on the io port. ![]() ![]() i think i will finish this up very soon. the rest is to install my hardware inside and call it a day. update will come soon. |
#28 |
Multimodder
final picture
![]() ![]() ![]() ![]() ![]() thos who has sharp eye may notice that the atx cable is not plunged in, no harddisk, and the back 92mm x2 fan had not been installed. all those will be fixed soon as i had to leave this project behind at my hometown. thanks for looking. and i guess see u all soon. |
| Tags |
| apple, g5, mod, powermac, powermac g5 mod |
| Thread Tools | |
| View Mode | |
