Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 14th Mar 2011, 15:32   #1
Ljs
Mod Master
Ljs's Avatar
Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.
Distances from router to phone socket...
Quick question for someone in the know:
I'm going to move my BT Homehub (yeah yeah, I know) from the living room to the room my computer is in so I can plug it directly into my computer. The phone socket however, is on the other side of the room to my computer.
I would like the router on my desk so I can plug the phone into it too... Is there any max distance the router can be from the phone outlet in the wall (using an extension cable)?
I have had a search around on the forums and google but didn't really find an answer.
Thanks...
Ljs is offline   Reply With Quote
Old 14th Mar 2011, 16:13   #2
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
The problem with extending the cable from your phone line is, the longer it is, the slower the internet goes. It'd be better to extend the ethernet cable to your computer and leave your home hub where it is.
However, from what you've said I'm guessing you're only moving it about <5m?
If so, that should be alright.
I think at least.
Networking isn't my best area lol
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 14th Mar 2011, 17:44   #3
tehBoris
Hypermodder
tehBoris's Avatar
tehBoris can run CrysistehBoris can run CrysistehBoris can run CrysistehBoris can run CrysistehBoris can run CrysistehBoris can run CrysistehBoris can run CrysistehBoris can run Crysis
Depends upon how far you are from your phone exchange and how strong the signal at the master socket is. If you are less then 2 miles from your phone exchange you are most likely going to be fine.
tehBoris is offline   Reply With Quote
Old 15th Mar 2011, 07:28   #4
slothy89
MicroModder
slothy89's Avatar
slothy89 has yet to learn the way of the Dremel
further to this, I have a 30m extension cord from the socket to the router, and it doesn't seem to have much of an effect. I am within about 1-2km from my exchange so signal strength isn't an issue.
(it's 30m long as it's the one we had lying around. Should really buy a 5m one lol)
Just make sure theres nothing that could cause electrical interference near the cabling.
__________________
CPU : Intel i7 2600K @4.5GHz ~ Cooler : Zalman CNPS 9900MAX Blue
GPU : 2xSLI Gainward GTX460 1GB GLH ~ PSU : Superflower 800W Modular
Mobo : ASUS P8P67 Pro B3 ~ RAM : 4x4GB (16GB) Corsair Vengeance 1600 @ 9-9-9-24
Case : Zalman Z9+ (filled with Xigmatek XLF fans 120mm&140mm)
Storage : 120GB OCZ Vertex 3 Max IOPS - 1TB WD Caviar Black SATA III
slothy89 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
