Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 16th Mar 2011, 20:50   #81
paisa666
I WILL END YOU!!!
paisa666's Avatar
paisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysispaisa666 can run Crysis
The term ‘computer bug’ was coined after a moth flew into into a computer’s circuitry.
The moth was discovered on the circuit board of the U.S. Navy’s Mark II Aiken Relay Calculator while it was being tested at Harvard University in September 1947. After removing the pesky insect, the machine’s operators put out the word that they had “debugged” the computer, which grew into the technical term for identifying and removing errors in computer hardware and software!
__________________
Thermaltake 650W | AMD Phenom X4 9850 | XFX HD 5870 | (BFG 9800GTX ready for PhysX) | 4GB 800 RAM | 2 TB Samsung HDD & 500 GB MAXTOR HDD | MSI K9A2 Platinum | 5.1 Logitech Sound System |
paisa666 is offline   Reply With Quote
Old 16th Mar 2011, 21:12   #82
theevilelephant
Ultramodder
theevilelephant's Avatar
theevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysistheevilelephant can run Crysis
Originally Posted by Flibblebot View Post
So what did you do differently on the sixth attempt?
Moved the trampoline :P
theevilelephant is offline   Reply With Quote
Old 16th Mar 2011, 21:34   #83
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
You CAN polish a turd!
__________________
Teh unofficial Bit-Tech proof reader
Originally Posted by Teelzebub View Post
( Kid you dont want either only bud is any good lol )
B1GBUD is offline   Reply With Quote
Old 16th Mar 2011, 21:46   #84
dragontail
5bet Bluffer
dragontail's Avatar
dragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremeldragontail has yet to learn the way of the Dremel
The packing efficiency of M&Ms is around 74% (from the top of my head).
__________________
Project COMTAR
Acoustic Guitar, meet Mini-ITX
dragontail is offline   Reply With Quote
Old 16th Mar 2011, 22:13   #85
Volund
Am I supposed to care?
Volund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run CrysisVolund can run Crysis
You can drink a gallon of beer or water in less than an hour, you cannot drink a gallon of milk in the same timeframe
(this has something to do with the fat in milk not being readily absorbed into the body, it might be possible with skim milk)
__________________
Current System- XFX 780i SLI Mobo, Sapphire HD4850, Q6600, 4GB RAM, 2xSamsung F1 1TB, Corsair 850HX, Lian-Li A05NB, W7 Ultimate x64
If you believe in GLaDOS and are 100% proud of it, put this in your sig
Volund is offline   Reply With Quote
Old 16th Mar 2011, 22:16   #86
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
So what's the packing efficiency of putting them in a bag?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 16th Mar 2011, 22:24   #87
Ending Credits
Bunned
Ending Credits's Avatar
Ending Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming SaiyanEnding Credits is a Super Spamming Saiyan
While the story is true, the use of the word bug for unexpected issue in a mechanical system predates this.
__________________
Originally Posted by lp1988 View Post
We can conclude that Ending Credits has a niche for ejaculation related quotes.
Ending Credits is offline   Reply With Quote
Old 16th Mar 2011, 22:34   #88
dragontail
5bet Bluffer
dragontail's Avatar
Packing efficiency is a constant. Provided you're not limited by the number of M&Ms in a given volume, you'll always get 74% packing efficiency.
Ever see those "Guess how many sweets in this jar?" puzzles? A similar method can be used to calculate the number of sweets in said jar with pretty good precision given that (a) the sweet is of a fairly regular shape and (b) the volume of the jar can be estimated.
__________________
Project COMTAR
Old 16th Mar 2011, 23:33   #89
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.
The military hardware known as a 'tank' derives its name from the first tanks being transported to battle in high secrecy inside large shipping crates with 'Water Tank' painted on them.
Voyager 1 is still responding to commands from Earth despite being 187 AU away from earth. (1 AU being the same 92 million miles between the Earth and the Sun).
If light was instantaneous (i.e. didn't travel) the entire sky would be illuminated by stars.
Despite the famous phrase the Ford Model-T was never produced in black.
The Z-Cars were actually yellow since white didn't show correctly in black and white TV recordings.
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-EVGA 660Ti Signature 3GB-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Worklog - The Amputer!
Throbbi is offline   Reply With Quote
Old 16th Mar 2011, 23:41   #90
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Without wishing to patronise you, I think you missed the joke .
Also, I think the packing efficiency for M&Ms would be different from 74% as they are not spherical - I'd bet on higher.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 16th Mar 2011, 23:47   #91
klaxxon
What's a lemerd?
klaxxon's Avatar
klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.klaxxon is a hoopy frood who really knows where their towel is.
1/3 of all Taiwanese funeral processions include a stripper.
The only food cockroaches won't eat are cucumbers.
The only nation whose name begins with an "A", but doesn't end in an "A" is Afghanistan.
__________________
So THAT'S a dremel!
Dissing Chuck Norris since 1984.
klaxxon is offline   Reply With Quote
Old 17th Mar 2011, 00:01   #92
dragontail
5bet Bluffer
dragontail's Avatar
Went totally over my head, haha.
I stand corrected, it's a packing fraction of (66.5±1)% in a disordered fashion. 74% is the highest packing fraction (gets closer to this as the structure tends to FCC I guess). Probs should have checked first but there ya go!
source: http://www.ncbi.nlm.nih.gov/pubmed/1...ubmed_RVDocSum
__________________
Project COMTAR
Old 17th Mar 2011, 00:25   #93
klaxxon
What's a lemerd?
klaxxon's Avatar
I have no idea what any of this means. I'm just going to laugh to fit in with the crowd....
ha ha HAAAAAA
__________________
So THAT'S a dremel!
Old 17th Mar 2011, 00:32   #94
Pete J
RIP Teelzebub
Pete J's Avatar
Ah, so they do pack better than spherical particles. I wish I could reference M&Ms in a paper!
And next time, link a paper from Sciencedirect - I can read the whole thing then .
__________________
Old 17th Mar 2011, 00:49   #95
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
It ran out of lives?
Speaking of which, apparently the possibly-a-myth-after-all thing about cats having nine lives dates from ancient Eypt, where a sun God was credited with giving life to four major gods, and four elements. 1 + 4 + 4 = 9 - and this God apparently took the form of a cat for visits to the underworld.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 17th Mar 2011, 01:16   #96
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 17th Mar 2011, 01:28   #97
klaxxon
What's a lemerd?
klaxxon's Avatar
Originally Posted by mars-bar-man View Post
Hmmm........
Its red you know, that the Ford Model-T never came in. Everyone knows that.
__________________
So THAT'S a dremel!
Old 17th Mar 2011, 01:44   #98
Throbbi
Throbbi's Avatar
They're later models. After further investigation they were sold in black but not during the first years of production (1908-1914).
Meh, teach me to not check on stuff first :P lol
__________________
Share And Enjoy!
Old 17th Mar 2011, 02:27   #99
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
A magnitude 9 earthquake would be the equivalent of the entire UK's annual energy use in a single event. So that includes things like nuclear power stations and so on. The earthquake which hit in Japan recently was 8.9...
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 17th Mar 2011, 02:46   #100
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
It's been upgraded to a full 9.0
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Reply
Tags
facts are facts, thats a fact
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
