Thread Tools |
#1 |
Cheesecake on sale!
true_gamer's Crysis 1 Config Mod, HD texture and foliage pak **New pic's in post 1**
Crysis maxed out with 16xQAA 2560x1440 with my custom ultra config.
Install the HD Texture pak first : 2GB File! http://www.fileplanet.com/194825/190...gh-Texture-Mod Also see here for any other mods you may want: http://www.overclock.net/t/1014933/a...ds-56k-warning First 9 screenshots have been taken today, running 2560x1440 with 16XQAA with HD texture, Foliage Pak and my Custom Config. Enjoy. ![]() Crysis Ultra config: Open a new text document and add these commands: Make sure to set r_height= and r_width= to your monitor resolution Code:
con_restricted = 0 r_displayinfo = 1 r_MultiGPU = 1 sys_spec_Shading = 4 sys_spec_ObjectDetail = 4 sys_spec_VolumetricEffects = 4 sys_spec_Shadows = 4 sys_spec_Texture = 4 sys_spec_Physics = 4 sys_spec_PostProcessing = 4 sys_spec_Particles = 4 sys_spec_Sound = 4 sys_spec_Water = 4 sys_spec_GameEffects = 4 ca_AttachmentCullingRation = 200 e_cull_veg_activation = 100 e_decals_life_time_scale = 4 e_detail_materials_view_dist_xy = 8192 e_detail_materials_view_dist_z = 8192 e_foliage_wind_activation_dist = 100 e_lod_ratio = 8 e_max_entity_lights = 20 e_obj_quality = 4 e_particles_max_emitter_draw_screen = 100 e_particles_quality = 4 e_phys_ocean_cell = 0.2 e_shadows_cast_view_dist_ratio = 0.8 e_vegetation_sprites_distance_ratio = 1.5 e_view_dist_ratio = 100 e_view_dist_ratio_detail = 100 e_view_dist_ratio_vegetation = 100 e_water_ocean_fft = 1 e_water_tesselation_amount = 10 es_DebrisLifetimeScale = 1 es_maxphysdist = 100 es-maxphysdistinvisible = 100 g_battleDust_enable = 1 g_breakage_particles_limit = 500 g_ragdollDistance = 100 g_ragdollMinTime = 20 p_max_mc_iters = 7000 q_Renderer = 4 q_ShaderFX = 4 q_ShaderGeneral = 4 q_ShaderGlass = 4 q_ShaderHDR = 4 q_ShaderIce = 4 q_ShaderMetal = 4 q_ShaderPostProcess = 4 q_ShaderShadow = 4 q_ShaderSky = 4 q_ShaderTerrain = 4 q_ShaderVegetation = 4 q_ShaderWater = 4 r_Beams = 1 r_BeamsDistFactor = 0.01 r_BeamsMaxSlices = 300 r_ColorGrading = 1 r_DepthOfField = 2 r_detaildistance = 20 r_DetailNumLayers = 2 r_DetailTextures = 1 r_DynTexAtlasSpritesMaxSize = 32 r_DynTexMaxSize = 60 r_MotionBlur = 4 r_ShadowJittering = 1 r_SSAO = 1 r_SSAO_quality = 2 r_SSAO_radius = 2 r_sunshafts = 1 r_TexAtlasSize = 8192 r_UseEdgeAA = 2 r_Usepom = 1 r_RAM = 1 r_WaterReflectionsQuality = 4 r_WaterUpdateDistance = 0.2 r_WaterUpdateFactor = 0.01 r_height = 1440 r_width = 2560 s_CacheSize = 1024 s_MPEGDecoders = 32 s_ObstructionUpdate = 0.1 sys_flash_curve_tess_error = 1 r_Glow = 1 r_EyeAdaptionClamp = 1.5 r_HDRBrightOffset = 5 r_HDRBrightThreshold = 0.5 r_HDRRendering = 2 r_HDRLevel = 0.4 s_FormatSampleRate = 48000 s_SpeakerConfig = 5 r_contrast = 0.66 r_gamma = 1 r_brightness = 0.5 r_TexturesStreaming = 0 r_TexMaxAnisotropy = 16 cl_camera_noise = 0.1 cl_camera_noise_freq = 1 cl_hud = 1 r_EnvTexResolution = 3 r_ReflectionsQuality = 3 r_TexturesFilteringQuality = 0 s_FormatType = 5 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Cheers, Simon.
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC Crysis 3 Ultra Config Crysis 1 ultra Config
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer Last edited by true_gamer; 18th Mar 2013 at 15:33. Reason: Added photos from in game play from today. :) |
#2 |
still wants Homeworld 3
awesome screenshots. looks amazing!
shame Crysis 2 is not moving towards this kind of visuals. have you thought about sharing your tweaks? what FPS are you getting?
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr |
#3 |
RIP Teelzebub
Sweet! I don't suppose you could e-mail me your Cvar files if I gave you my address?
__________________
#4 |
I Mod, Therefore I Own
Needs more AA
![]() Love the screen shots.
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l Steam: murraynt |
#5 |
the worst
Moderator
It finally looks like it did in those first screenshots they showed way back!
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog - Oculus Rift
#6 |
Cheesecake on sale!
Thanks, it was a painful slow process of trying to get the right lighting whilst trying to work out how far I could push the graphics. Even at this level of detail it's still high in the 40fps.
I will post a link on here later with my config...(Now in the middle of building my dads new PC). Cheers, Simon.
__________________
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer |
#7 |
Moderate Modder
I only just realise how demanding Crysis is on GPU's.. Playing Dead Space 2 . the inline temp monitior just above my GPUs got to 30 degrees .. During Crysis it rocketed to 41degrees
No enviromental differences infact it was a cooler evening if anything. I have re-loaded this game and have lost where you get the patches from anyone have a link to them? (pleaseeeeeee)
__________________
Watering down PC's since 2009.... |
#8 |
...at least I have chicken
Some of them are quite nice (third one down for example), but the ones with long draw distances in particular seem awfully blurry. Surely that would make it easier on the GPU if it's drawing less detail in the distance than it normally would (unless it's just applying a blur filter or something over the top, I suppose)?
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650] Other stuff I own: [BenQ XL2411T/Dell 2407WFP] - [CM Novatouch TKL] - [Zowie FK1] - [Fostex TH900] - [Woo Audio WA7 Fireflies] - [Sony Bravia KDL65W855] - [Onkyo TX-NR515] - [B&W 685] [Steam] - [Battlelog] |
#9 | |
RIP Teelzebub
Look forward to it!
__________________
#10 |
Ultramodder
just a tad too much HDR
__________________
mobo: Gigabyte GA-MA790X-UD4P Cpu: AMD Phenom 2 X4 945 @ 3.00ghz Gpu: EVGA GTS 450 RAM: OCZ Reapers DDR2 4GB storage: Hitachi Deskstar 320Gb 7200rpm 32Mb cache Case: NZXT Apollo black OS: Windows 7 ultimate x64 keyboard: MS KB mouse: Cooler Master Storm Inferno mousemat: OCZ mouse mat headset: Creative SoundBlaster Arena headset speakers: None |
#11 |
Cheesecake on sale!
Looks fine for me. You may need to adjust your monitor.
__________________
#12 |
Minimodder
Looks really jaw dropping.., I wish Crysis 2 was also in jungles and stuff
#13 |
Banned
#14 |
Banned
Great screenies Simon, and thanks for the config file. Crysis atm doesn't present much of a challenge to my new GPU so its about time it got a work out
#15 |
Butt-kicking for goodness!
Impressive as that is (mostly because you're getting playable frame rates!!!), that's not the best cryengine 2 can do.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors BT Feedback Last edited by Tangster; 18th Mar 2011 at 09:25. |
#16 |
Banned
An engine like that and they go and make their new game in a crappy ole urban environment I've seen a million times before
![]() I just hope it sells well enough that they can make a Crysis 3 and do it like the first one but bigger and better. p.s. That rig of yours is :O |
#17 |
Multimodder
"Download Crysis Ultra config (will also work with Warhead). Download
Put this file into Crysis\Game\Config\" Tried to follow this link but went to"Uploading .com" is this correct and if so how do i download the config. Sorry if the answer is blindingly obvious. Last edited by ZortB; 19th Mar 2011 at 01:24. |
#18 | |
Moderate Modder
__________________
#19 |
Designated CPC Jetwhore
I've been trying lots of mods and configs for Crysis recently too so I might aswell add some of the stuff I use:
My custom config (A modified CCC config which gives me between high and very high performance but far better graphics IMO, also I've found the main changes between most configs is the HDR and SSAO setting, so i've included a list of these at the bottom for many popular configs, to use them just delete the ";" marks in front of the line) Silent's HD Foliage I'd definitely recommend this to you True Gamer, makes such a difference to the vegetation. You might also want to try using some ToD mods, they make a massive difference to the lighting of the game. The most popular ones are CCC, Reli2, Natural Mod and Mster. At the moment i'm loving a slightly modified Reli2 ToD. Sorry if anyone thinks this is hijacking, if it is i'll just take it down, I just wanted to add my input.
__________________
#20 |
Banned
That Foliage mod is really nice. Any idea what affect it has on frame rate?
