Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 23rd Mar 2011, 11:38   #1
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
The GuilleAcoustic design thread
Hi mates,
to begin with, I wanted to thanks all the people that are / were involved in the Phobya contest. This is where this project came to life, and I really think I wouldn't have make it without this contest and all the advises I got.
I invite all of you to show your support to the 5 finalist, and the thread can be showed here :
http://forums.bit-tech.net/showthread.php?t=203582
Well, here are some pictures to show the concept at the end of the second stage of the contest :
The concept was a tower shape case that supports EATX mobo as well as two triple 140 / 2 quad 120mm rads. It has 3 removable trays (mobo / hardware, watercooling stuff, PSU).
As I don't need EATX mobo and only need 1 PCI-E (GPU) and 1 PCI (sound card), I decided to shrink it to microATX form factor. Here are the early work :
Here is a size comparison between the EATX original version, and the microATX revised
full size : 370 x 370 x 640
microATX : 300 x 300 x 638
I'm trying to shrink it even more, but I really want to keep the separated area concept (each with it's own tray). Since this is my first project and my first watercooling attempt, I need some advises.
I'm planning to use my core2quad Q6600 and a GTX560. What kind of radiator do I need to keep everything cool (stock and overclocked) ? I'll maybe switch to sandy bridge later, but I'll keep single GPU setup.
Here is the current hardware :
- mobo : XFX MI-9300-7AS9
- CPU : Intel Core2Quad Q6600
- GPU : none (my 9600GT passed away and I'm using the integrated 9300 ...). I'm going for a GTX560.
- RAM : 4Go Kingtson PC6400 cas 4
- sound card : M-Audio 2496, but I'll replace it with an Infrasonic Quartet
- PSU : Corsair HX520, but it will probably be a little light for a GTX560
GuilleAcoustic is offline   Reply With Quote
Old 23rd Mar 2011, 13:44   #2
Djayness
ASUS
Djayness's Avatar
Djayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the Dremel
Hey!
Neat looking case and I admire your sketchup skills. I think it will be quite the challenge to do it all in those dimensions but if sketchup says it can be done, then it will be done!
Djayness is offline   Reply With Quote
Old 23rd Mar 2011, 14:21   #3
GuilleAcoustic
Ook ? Ook !
Originally Posted by Djayness View Post
Hey!
Thanks mate . I made a correction, the size where wrong it is :
I don't think I can shrink the 300 x 300 footprint, I'm working to reduce the height.
Old 23rd Mar 2011, 14:41   #4
Roboduck
01110001 01110101 01100001 01100011
Roboduck's Avatar
Roboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the DremelRoboduck has yet to learn the way of the Dremel
Sub'd. Looks great!
Roboduck is offline   Reply With Quote
Old 23rd Mar 2011, 20:13   #5
Zesti
Multimodder
Zesti's Avatar
Zesti has yet to learn the way of the DremelZesti has yet to learn the way of the DremelZesti has yet to learn the way of the Dremel
Been waiting for this project log. Subīd.
About water cooling: One good 3x120mm rad (for example EK XT 360) should be enough for your hardware. If you want to go extreme or if you want a very silent computer, get two of īem.
And your Corsair PSU will be fine. If GTX560 and i7-920 @ 4GHz pulls only ~310W from the wall, I dont think yours will use more.
__________________
Current system: ZOE
Current project: Eterne - MOTM November '12 Nominee!
Zesti is offline   Reply With Quote
Old 23rd Mar 2011, 21:16   #6
GuilleAcoustic
Ook ? Ook !
Thanks. I'll try 2 version then. One with a single 3x120 and one with two 2x240 (maybe I could shrink the case by a good 100mm this way).
Materials will be wood and copper I think, but I'm not completetly done with rough drawings (I'm not a fast drawer, and didn't used my wacom in a while )
UPDATE (2011-03-24) :
Here is a little update. I shrinked the height from 638mm to 571mm. It can fit two dual 140mm rad.
Old 25th Mar 2011, 13:16   #7
GuilleAcoustic
Ook ? Ook !
Hello everyone,
here is my today's lunch work.
Reduced the height by another good 30mm (but increased the depth by 20mm ... I couldn't resists this gorgeous frozenQ res)
Hardware are :
- Dual EK XTC 280 radiator
- FrozenQ reservoir
- NVidia GTX560
- Seasonic X750 PSU
here are the pics :
Next step : BIG BIG BIG work on the bottom area. I have to optimise this space.
Old 25th Mar 2011, 15:27   #8
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
I'd probably buy a case like this if it was for sale, ample cooling ability and less of a foot print on the desk
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 25th Mar 2011, 15:57   #9
ianclowe4c
Minimodder
ianclowe4c has yet to learn the way of the Dremel
This looks fantastic....can't wait to see more.
ianclowe4c is offline   Reply With Quote
Old 25th Mar 2011, 15:57   #10
ianclowe4c
Minimodder
I would but one of these as well....most definately.
Old 25th Mar 2011, 16:19   #11
GuilleAcoustic
Ook ? Ook !
Thanks mates. I'm still wondering if I should go with the dual EK XT 280 (with 540mm height) or go with a dual EK XT 360 (with a 620mm height).
I think I'll rethink this after I'm done with the bottom area (PSU and HDDs).
Stay tuned
Old 14th Apr 2011, 21:58   #12
GuilleAcoustic
Ook ? Ook !
Hi mates,
just a little update to show off something I wanted to try about the outside design. I didn't had much time to play with SU, but here is the current state. The inside evolved a lot, but this will be revealed later .
Old 14th Apr 2011, 22:14   #13
ixmatal
Modder
ixmatal has yet to learn the way of the Dremel
Hey Guile,
I like the way your design is "evolving". Kind of taking on a life of its own.
Keep it up!
ixmatal is offline   Reply With Quote
Old 14th Apr 2011, 22:44   #14
Roboduck
Roboduck's Avatar
Love the new design! Can't wait to see this one built
Old 14th Apr 2011, 23:36   #15
llamafur
WaterCooled fool
llamafur's Avatar
llamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremelllamafur has yet to learn the way of the Dremel
I would totally buy this case!
llamafur is offline   Reply With Quote
Old 14th Apr 2011, 23:55   #16
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on you
oh no its growing again. i was really hoping you'd make it more compact. then i guess if it was small it wouldn't really be a monolith would it? in any case your internals were very well organized. looking forward to you getting out of the sketch up phase.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 15th Apr 2011, 05:36   #17
GuilleAcoustic
Ook ? Ook !
I have a less tall build in mind but I have to make all the tubing and wiring to decide the one I'll make . That's where SU helps
Anyway, with the new internal organisation, I gained 60mm in depth.
Thanks to everyone for your support. I appreciate it a lot. I apologies for the looooooo,g SU phase, but I'm kind of perfectionist and won't start building it until I'm totally sure with the build
Old 19th Apr 2011, 20:28   #18
GuilleAcoustic
Ook ? Ook !
Eye-candy only, but I needed one in sketchup to visualize used space. Here is a freshly modeled GTX560 with completly custom full cover block (couldn't find existing block for the GTX 560)
Time for tubing and wiring now and I'll have a better idea of left space and ease of use. I'll try to post a few picture tonight.
Stay tuned
Old 19th Apr 2011, 22:05   #19
randomhero
Multimodder
randomhero has yet to learn the way of the Dremel
Awesome, been thinking of doing something like this since I saw the Phinix Nano Tower. Hope you can give me some more inspiration for my future build
__________________
Mobo: ASUS P8P67 CPU: Intel Core I-7-2600K @ 4,636 GHz GPU: 2x MSI N560GTX-Ti Twin Frozr II @ 1022 Mhz RAM: 4x4GB Corsair Vengeance DDR3 1600 MHZ CL8 Storage: Seagate Barracuda XT 2TB and waiting for OCZ Vertex 3 to be released in Norway Case: Fractal Design Define R3 Black Pearl PSU: Corsair AX 850W OS: Windows 7 ultimate x64 Keyboard: Logitec Illuminated Wireless Keyboard K800 Mouse: Cyborg R.A.T 9
randomhero is offline   Reply With Quote
Old 19th Apr 2011, 22:33   #20
GuilleAcoustic
Ook ? Ook !
Thanks mate. Here is so far what I've done tonight (hope you'll like what I've changed) :
What has changed since the first design (Ihope I made the good choice, but I'm still in SU ) :
- Mobo is now on top
- The case now fits dual 280mm push - pull configuration
I still have a lot to do :
- Pump and res.
- Wiring and cable management.
- Hot swappable Hdd bay.
- Air intakes and dust filters.
- Trying to gain 10mm here and there .
- Watercooling tray system.
I also have to completly seal the three zone. I don't want to see hot air leeking from mobo or psu to the cooling chamber. Who said massive use of pass-through quick disconnect ?
Any input, advise, comment are welcome
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
