Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Mar 2011, 17:26   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Crysis 2 Xbox 360 vs PC comparison
We've pulled screenshots from the Xbox 360 and PC versions of Crysis 2. Have a look.
http://www.bit-tech.net/gaming/2011/...c-comparison/1
Claave is offline   Reply With Quote
Old 25th Mar 2011, 17:37   #2
gilljoy
I *am* a Dremel
gilljoy's Avatar
gilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for presidentgilljoy should be considered for president
Just installed it, had a look at the first bit as i've not got much time to play, only playing at 1680 but should have a 1920 monitor soon.... all i have to say is that it doesnt look any better than crysis 1, maybe a little worse
__________________
Intel Core i7 3770K ||H100i || Gigabyte Z77X-UD3h||16gb Corsair XMS3
Gigabyte 7970 Ghz edition ||1tb Samsung HDD + Crucial M4 64Gb|| Xigmatek Midgard
gilljoy is offline   Reply With Quote
Old 25th Mar 2011, 17:38   #3
Otis1337
aka - Ripp3r
Otis1337's Avatar
Otis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming Saiyan
maxing this easy with my rig [5850 + 920 at 1920x1200].. FOV set to 75, AA at 4.
There is no DX10 or 11
Looks nothing close to Crysis 1
__________________
Haswell killer - Long live x58
GTX 1080 FE::Xeon X5650 Hex @ 4Ghz::H110i GT::Asus P6T SE x58::Patriot Tri DDR3 12GB
CoolerMaster 850W RealPower::Phanteks Enthoo EVOLV::Sammy F3 1TB::OCZ SSD 2x120GB::Asus Xonar - HyperX Cloud
Otis1337 is offline   Reply With Quote
Old 25th Mar 2011, 17:41   #4
Deders
I Mod, Therefore I Own
Deders's Avatar
Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.
lol, at least one PC can run Crysis 2? My 9800GTX+ averages around 22-30fps with the highest settings, even that is smooth (not jerky), Once I enable SLI with the proper profile it nearly doubles, and that's with 4xAA enabled.
I expect a 260 or anything above should be able to handle the DX9 version
__________________
i7 6700K @4.6GHz - Asus Z170 Deluxe - Noctua NH-D15 - Gainward Phoenix 1080 GLH 8GB @2050 & 11000 - 16GB Gskill RipjawsV DDR4 @3200 - Corsair HX850i - Nanoxia Deep Silence One - Samsung 950 Pro NVMe - Samsung Spinpoint F3 1TB - WD RE4 2TB - WD Caviar Blue 640 - Dell U2913WM Ultrawide - Logitech G19 - Corsair M65 - Sony STR-DN1050 Receiver - Q Acoustics 2000i 5.1 speakers.
Deders is offline   Reply With Quote
Old 25th Mar 2011, 17:52   #5
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.Jamie is definitely a rep cheat.
I think that Avermedia 727 HD Capture card is suspect, the images are a little blurry.
__________________
Jamie is offline   Reply With Quote
Old 25th Mar 2011, 17:55   #6
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
No, that's really what it looks like. Come down to the labs and I'll show you on Monday.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 25th Mar 2011, 17:59   #7
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
I was about to rage and ask WHY WOULD YOU TAKE THE 360 SCREENSHOTS WITH A CAMERA.. Then I realized how much better games are on the PC.
docodine is offline   Reply With Quote
Old 25th Mar 2011, 18:08   #8
Oggyb
Mutant
Oggyb has yet to learn the way of the DremelOggyb has yet to learn the way of the Dremel
APART FROM the dodgy upscaling from some obscenely low resolution, the difference isn't as night-and-day as I expected.
Certainly not from those screenshots anyway.
Oggyb is offline   Reply With Quote
Old 25th Mar 2011, 18:10   #9
Podge4
Oi, whats your game?
Podge4's Avatar
Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.
it just makes it look worse when you compare extreme and the 360. what about the ps3 screens?
__________________
AMD FX8350 @4.3ghz, Asus M5A97 EVO R2.0, 8gb Corsair Vengeance
Sapphire Radeon RX 480 Nitro+ OC 8gb, AOC u2879vf 4k,
Kingston SSDNow V300 240gb, Asus Xonar D2, LG BH10LS30 BD-RE, Win 10 Pro x64
Podge4 is offline   Reply With Quote
Old 25th Mar 2011, 18:11   #10
Aterius Gmork
smell the ashes
Aterius Gmork's Avatar
Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.Aterius Gmork is definitely a rep cheat.
Those comparison screenshots are a bit unfair tbh - you upscaled to 1600p (1440p), a resolution very very few people are going to game on with an Xbox. A comparison of 1080p shots would have been fairer imo. Of course the pc would still be superior, but the blurryness would not have been quite as bad.
__________________
Feel free to correct this post per PN or otherwise to help me improve my English.
Aterius Gmork is offline   Reply With Quote
Old 25th Mar 2011, 18:13   #11
docodine
killed a guy once
docodine's Avatar
Can custom resolutions be set in Crysis 2? If so.. Non upscaled comparison?..
Old 25th Mar 2011, 18:14   #12
Apexgun
What's a Dremel?
Apexgun has yet to learn the way of the Dremel
The 360 compared to extreme is a major difference IMHO
__________________
Apexgun is the name, unfortunately not original
Apexgun is offline   Reply With Quote
Old 25th Mar 2011, 18:16   #13
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
360 is massively different to all three PC presets to me. I can't see a massive change in quality between the PC presets though.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 25th Mar 2011, 18:22   #14
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
is it me or i don't see ANY difference between the 3 PC settings?
can anyone point those differences out for me please?
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 25th Mar 2011, 18:23   #15
Flibblebot
Smile with me
Flibblebot's Avatar
Flibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming Saiyan
Shock Horror: Recent PC Graphics Better Than Five-Year-Old Console!
Coming up after the break: Men are different from women.
So, joking aside, is it fairly safe to say that Crysis 2 isn't as much of a push forward in graphics engine technology as the original - and that a reasonably recent PC will be able to run it without any major problems?
What will all those people whose first response is "...but will it run Crysis" be able to say now?
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 25th Mar 2011, 18:33   #16
cgthomas
Cpt. Handsome
cgthomas's Avatar
cgthomas has yet to learn the way of the Dremel
I was really looking forward to installing it tonight, however bloody Amazon failed to deliver. This is the last time I pre-order from Amazon. Game on the other hand is always spot-on with deliveries (sometimes a day before release )
Never make the mistake of pre-ordering from Amazon. (Call me old-fashioned, but I don't prefer digital downloads)
LOL, I guess it's still going to be "..... but can it play Crysis?"
__________________
Iím an AquaTuning product tester - I am........ honestly
cgthomas is offline   Reply With Quote
Old 25th Mar 2011, 18:37   #17
proxess
Ultramodder
proxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for president
But will it run Crysis 1?
__________________
Laptop: i7 4930MX @4.0GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 25th Mar 2011, 18:52   #18
Deders
Deders's Avatar
It could be potentially it's more optimised than the original, if the levels weren't designed for consoles in mind then who knows what it could achieve.
I wonder what the original would run like with the new engine
__________________
Old 25th Mar 2011, 18:59   #19
frontline
Punish Your Machine
frontline has yet to learn the way of the Dremelfrontline has yet to learn the way of the Dremel
"But can you configure Crysis?"
Or maybe all game reviews should have at least one comment "do you have to press start to continue?"
__________________
Intel Core i7 2600K| Asus P8P67-M PRO R3 | Corsair H70 Hydro Series CPU Cooler |Corsair 8GB (2x4GB) DDR3 1600MHz XMS3 Memory Kit CL9 1.65V | Sapphire HD 6990 4GB GDDR5 | Crucial M225 128Gb SSD | Asus Xonar DX | LG W2261VP | Corsair GS800 PSU
frontline is offline   Reply With Quote
Old 25th Mar 2011, 19:01   #20
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
At the end of the day, the PC is using Console texture and art assets
....you cant polish a turd..
Hustler is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
