Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Mar 2011, 10:44   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Thermolab Bada 2010 Review
Compact and easy to install, but there are better and cheaper alternatives.
http://www.bit-tech.net/hardware/coo...-2010-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 26th Mar 2011, 12:19   #2
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Given it's size I'd like to know how this performs against the old AC freezer 7.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 26th Mar 2011, 12:26   #3
Oggyb
Mutant
Oggyb has yet to learn the way of the DremelOggyb has yet to learn the way of the Dremel
Me too.
Oggyb is offline   Reply With Quote
Old 26th Mar 2011, 19:04   #4
Boscoe
"and she'll be foamin at the vag."
Boscoe's Avatar
Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.Boscoe is definitely a rep cheat.
Or scythe ninja mini.
Boscoe is offline   Reply With Quote
Old 27th Mar 2011, 09:25   #5
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
what happened to Arctic? their current product range makes little sense to me...
tonyd223 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
