Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Mar 2011, 10:51   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Roccat Kone+ Review
Large and brimming with customisation options, but it doesn't support all your fingers.
http://www.bit-tech.net/hardware/per...-kone-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 27th Mar 2011, 13:45   #2
RGUK|Alex
Camping like a pikey
RGUK|Alex's Avatar
RGUK|Alex has yet to learn the way of the Dremel
I remember a while back I was actually considering getting this mouse, not because of its wealth of features but purely because of its aesthetic merit. I now feel happy in knowing that I had made the right choice buying the CM Storm Inferno, a much cheaper mouse with plenty of potential. Still looks nice with all the lights nonetheless, however when I'm in the middle of a gun fight I don't tend to raise my hand to look at the lights underneath for satisfaction. That comes from shooting somebody.
__________________
You are now manually breathing and blinking.
RGUK|Alex is offline   Reply With Quote
Old 27th Mar 2011, 14:05   #3
smc8788
...at least I have chicken
smc8788's Avatar
smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.smc8788 is definitely a rep cheat.
I have one of these and I can honestly say it's the best mouse I've ever used (and I've tried plenty of mice - the Logitech MX518, Razer Deathadder, and R.A.T. 7 amongst others). I keep coming back to the Kones though, since I find them supremely comfortable and their driver software is excellent. I also had the original Kone which was plagued by problems with its mouse wheel, so I bought the Kone+ to replace it as I couldn't find another mouse I liked as much. I was a little sceptical of how much they'd improved the mouse wheel, but I haven't had any problems with it so far and I would struggle to find something I don't like about it.
As for the lack of finger support, that's something very personal to the user so you may or may not be bothered by it (obviously I'm not), and will depend on what kind of grip you use on the mouse. The R.A.T. 7 for example has excellent finger support when using the appropriate attachment but overall I felt it was nowhere near as comfortable.
__________________
My Rig: [FD Define Mini] - [Asus P8Z77-M Pro] - [i5 2500k @ 4.4GHz/1.34V] - [Corsair H60] - [8GB Corsair Vengeance LP] - [Asus GTX TITAN] - [512GB Vertex 4, 1TB F3, 2TB F4 x 2] - [Corsair HX650]
Other stuff I own: [BenQ XL2411T/Dell 2407WFP] - [CM Novatouch TKL] - [Zowie FK1] - [Fostex TH900] - [Woo Audio WA7 Fireflies] - [Sony Bravia KDL65W855] - [Onkyo TX-NR515] - [B&W 685]
[Steam] - [Battlelog]
smc8788 is offline   Reply With Quote
Old 27th Mar 2011, 14:34   #4
Saivert
Supermodder
Saivert has yet to learn the way of the Dremel
yup. The Logitech G5/G7 doesn't have a ledge for resting fingers on either and I rarely ever drag the fingers along the mouse surface. I keep a firm grip on the mouse and avoid it.
__________________
- I'm the troll who bumps page 2 topics -
Saivert is offline   Reply With Quote
Old 27th Mar 2011, 16:46   #5
Ninja_182
Enginerd!
Ninja_182's Avatar
Ninja_182 has yet to learn the way of the Dremel
Originally Posted by smc8788 View Post
*Snip*
*Snip*
Personally when looking for mice I rule out all those with little finger supports (and the few with thumb supports), they don't 'support' my finger, they put it somewhere un-natural, and make the mouse feel clumsy. I don't have the dragging little finger and falling off ring finger. My mouse has 3 buttons on top, as a result I have 3 fingers, the middle on the wheel. This leaves the ring finger on the right button and the little finger moved far enough across to not be able to reach the desk unless I try to.
__________________
Athlon X2 4000+ @ 19.7GHz
Ninja_182 is offline   Reply With Quote
Old 27th Mar 2011, 17:56   #6
Almightyrastus
Rule #9
Almightyrastus's Avatar
Almightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming Saiyan
I have the older Kone model here and it is pretty awesome. The only negative points I could mention are the retention method for the weight is a little flaky, hopefully that has been improved in the Kone+ and the cable and plug feel a little cheap and nasty.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 27th Mar 2011, 19:28   #7
wardogz
Minimodder
wardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysiswardogz can run Crysis
Personally, i'll stick with my Razer Naga, I NEED all those buttons!, even for FPS', Mouse for most of the actions, aiming and a wireless frag n stein, to steer and jump/sprint etc, never have to touch the bulky Sidewinder KB, just sit back in comfort and frag
wardogz is offline   Reply With Quote
Old 27th Mar 2011, 23:53   #8
CashMoney
What's a Dremel?
CashMoney has yet to learn the way of the Dremel
I've been using the original kone for well over a year now, best mouse I've used (and as a gamer, I've used a LOT!). As for the tracking unit, it does make a difference. I don't use a mouse mat, but it never occurred to me that my new desk (a gloss black kitchen worktop) would be a problem compared to the matt pine wood of my old desk. The top is gloss black with gloss water splashes like pattern on it. The mouse was skipping and stalling everywhere. I was resigned to breaking out a mouse pad when I remembered the TCU in the software. Sure enough, 1 calibration later and the mouse is as true on my new desk as it was on my old one. When I bought my Kone though, it was on special at 39, and admit I wouldn't have considered buying it if it was over 40, not for what to me was an unknown brand. Glad I did though!
CashMoney is offline   Reply With Quote
Old 28th Mar 2011, 13:21   #9
doggy
Cave Canem
doggy's Avatar
doggy has yet to learn the way of the Dremel
I have this mouse and love it. I had been a Deathadder user for a long time and decided to try something new. I have pretty large hands and find most mice uncomfortable after long periods of use which i why i initially used the Deathadder due to its size but this is even bigger than the Deathadder.
I would be impressed if anyone tells me they can actually play any sensible game @ 6000dpi - I seem to be stuck at 800/900 for most fps games and 1600dpi on wow.....
__________________
Silverstone Fortress FT02B-WRI - Intel i5 2500K - Sabertooth P67 - 2x 2GB Corsair XMS3 DDR3@1600 9-9-9-24 - Thermaltake Frio - Antec Trupower New 650 - MSI N560GTX Ti Hawk - Xonar DX - OCZ Vertex-2 60GB - Spinpoint F3 1TB - Roccat Kone+ - Razor Blackwidow Ultimate - Razor Carcharias
doggy is offline   Reply With Quote
Old 28th Mar 2011, 14:02   #10
DLDeadbolt
Space Cadet
DLDeadbolt's Avatar
DLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming SaiyanDLDeadbolt is a Super Spamming Saiyan
I've got the Kone, and have had to get it replaced/repaired once already, and am about to replace it again (1st time both buttons front pressure-sensor/switch broke [there are 2-3 each], and now this one the scroll wheel has broken, along with the button right above it)
As much as I like the size, weight (use the heaviest weight) and feel of the Roccat Kone, I doubt I will be back.
DLDeadbolt is offline   Reply With Quote
Old 28th Mar 2011, 14:50   #11
ledbythereaper
Multimodder
ledbythereaper has yet to learn the way of the Dremel
I have a rev2 Kone, weight holder is broken, more will randomly turn it's self off and need to be plugged back in, the Roccat logo that lights up is peeling off aswell. Shame as it's a good mouse, just horrible horrible build quality so I'm back to using my Razer Lachesis which hasn't failed me for the past 3 years.
__________________
PC: Intel i5 4960k @ 4.5Ghz/16GB RAM/Zotac GTX980Ti/5TB HDD space/Xonar
XBL Gamertag: Reapercore
PSN Tag: Reapermoo
ledbythereaper is offline   Reply With Quote
Old 30th Mar 2011, 01:15   #12
duster
What's a Dremel?
duster has yet to learn the way of the Dremel
The LED light source on mine broke recently. Before that the weight holder broke too. It's a nice mouse but the build quality is shocking - Roccat need to lift their game.
duster is offline   Reply With Quote
Old 3rd Apr 2011, 15:50   #13
xioros
What's a Dremel?
xioros has yet to learn the way of the Dremel
I have the kone + and I like it.
Using it for a couple of days now and huge improvement from my previous one ( RX1000)
xioros is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
