#1 |
I *am* a Dremel
Usb over network
I intend to buy my house and have usb network adapters in each room.
Apart from So far all I kind find is Lantronix UBox 2100 Is there anything cheeper i.e single usb port?
__________________
4 Men went to mow, Went to mow a meadow, 4 Men went to mow, Went to mow a meadow, ![]() ![]()
#2 |
I Mod, Therefore I Own
How come you want USB adapters in every room?
__________________
i5 750@3800 - MSI P55 GD65 - Asus GTX670 DirectCU II - 4GB OCZ DDR3 @1440 7-7-7-18 - Be Quiet! Straight Power E9 500W - Nanoxia Deep Silence One - X-FI Xtreme Gamer - Samsung 830 128GB - Spinpoint F3 1TB - WD Caviar Blue 640 - LG Flatron W2252TQ - Razer Deathadder - Thermaltake Contac 29. |
#3 |
I got some 4GB new RAM
Same as deders, why?
__________________
Win 7 64-bit - Silverstone RV02 - Q6600 @ 2.4 - 4GB Kingston Hyperx 8500 - Asus Striker II Formula - BenQ G2220HD - BFG GTX260 @ Core-700, Shader-1500, Mem-12000 with an Artic Cooler GTX Pro |
#4 |
Hypermodder
Agreed, I can see little point in this.
#5 |
I *am* a Dremel
Because I have devices in each room ! that can't be put in the same place.
__________________
#6 |
Hypermodder
Can't you locate the devices in one room then access them via the network?
#7 |
I *am* a Dremel
there isn't the space. The pcs are laptops, the modem is in a different room, the printer in another, Camera and Kindle in yet another, and storage in hidden in another.
as there no desk/office its easer to use network nodes spread around the house.
__________________
#8 |
Hypermodder
For storage you would be better off getting a device that is specifically intended for it, same with the printer (would be surprised if you couldn't get a box that would do both). Though you will need to check compatibility with the printer.
Plug the kindle in to the laptop, same for the camera if it's a digital still camera. |
#9 |
Have you tried turning it off/on ?
USB over network is quite expensive
your looking £200-300 for hubs USB1.1 is very cheap though can get adapters for £15
__________________
FFXIV - Blackstarr Strife on FabulServer. Add me fellow bit-techers. ![]() Got new hardware, put XP on it ?, then you dont deserve help |
| Tags |
| adapter, network, server, usb |
| Thread Tools | |
