#1 |
I'm a cat, not a furry.
Project: ModCron
I have started this in another forum. However, I thought I'd share it here.
I bought this case at a local thrift store. PIII 866, 128MB PC100 SDRAM, 20GB HDD. Not bad, but..... Just look at the size of this thing! I paid $20 for it! ![]() And from the front: ![]() Shhhh.... This is how you add things! ![]() Look at that expansion room! ![]() Can anyone say "stealth hot-swap bay"? And it's so simple to open it, if you know where to look: ![]() Talk about spacious! Don't know what the blue thing is, PCI cooler? ![]() However, it's simple to open. Note this: ![]() And this. ![]() To this: ![]() And again. ![]() The board and cooler.. ![]() Now, the PSU cage is totally nice. ![]() Remove this screw.... Yank on this.... ![]() Whoop. Gotta pull cables. ![]() Once again. Totally AWESOME!!! ![]() Better mugshot of the cooler. ![]() The RAM. 1GB total. ![]() Well, this is how things are mounted. ![]() A special type of screw goes on the front two spots, and a third mounts it. This is your OS HDD bay, because it's an always-on, needs the ventilation. ![]() Your power board. ![]() Left side panel? ![]() One or two screws to remove. Meh, a bit bland. Might make for OK wire routing, haven't checked for that. ![]() Toolless PCI bay. ![]() From the inside. ![]() Simply remove the screw.... ![]() To get this. ![]() Final treat. The sound card. Creative: the best producers of audio products, period. ![]() Model number.
#2 |
Tempo HP case on the left.
![]() Window hole (kinda blurry sorry) ![]() New back side, with stealth floppy ![]() LCD (work in progress) ![]() In the tempo case: ![]() Fan (in action!) Plus front audio/USB ports (both in progress) ![]() And again: ![]() In action, back in its home. The other case had horrible ventilation. ![]() Insides: ![]() My desk. ![]() What's this keyboard? ![]() A Sejin Electron Inc. SWK-8697WT keyboard, with PS/2 reciever! ![]() ![]() The reciever: ![]() And, finally, my power-saver/anti-hijacker tool: ![]() Mouse teaser, for my laptop: ![]() Unfortunately, I lost the left button ![]() Well, I don't have food, but I'll treat you to something: ![]() Genesis on a 40" LED TV. |
#3 |
Screen shot goodness
![]() ![]() ![]() ![]() Don't know what happened to the last one O.O |
#4 | |
OK, this has gotten some SERIOUS upgrading, thanks to TGS!
Pix to come...
__________________
| Tags |
| modcron |
| Thread Tools | |
| View Mode | |
